Question about Panasonic SA-HE100 Receiver
I am digitizing vinyl. I cannot figure out how to connect this HE100 to my computer. phono has only in. turntable will not run through tape, which has record/audio out connections. it seems silly and dangerous to connect to my computer through the speaker wire. Various sets of instructions just say connect--as if it would be obvious.
  • mekersten Apr 25, 2010
    I figured this out. Phono in, tape out. not logical, but correct.
    Brigadier General:
  • 8,546 Answers
Perhaps you should break this down into its TWO components:
1) Define the Phono source you're using. Is it an old-school turntable that REQUIRES a Phono Preamp conenction on the receiver to generate a useful level and quality of audio: or do you hae a new-age TT that can supply its own pre-amplified signal to ANY Line Level input; or do yuou have a newer-age USB TT that could connect directly to a PC via USB?
2) Anything that can connect to or pass through the receiver can be used as an input on a PC Sound Card via it's Microphone Input (if not via a specific analog or digital input). Run an RCA cable from the receiver's Tape_ or VCR-Out to an adapter that fits the Microphone Input if there is no RCA-style audio input.
Posted on Apr 25, 2010
I have a Yamaha RV-V450 receiver. Where can I hook up my turntable. I have tried many different options. I can hear very faintly the record playing but only after turning the volume up. I am having trouble...
Turntables generally do not have a strong enough signal to drive an amplifier. You can check on the back of your turntable and see if it has a switch to change from phono to line level. Most do not, but a few will.
If your turntable does not have this switch, you will need to purchase a phono amplifier to boost the signal to standard line level. You can get these on ebay for around $15.
You connect the turntable to the phono amp input and then connect the phono amp output to any of the inputs on the back of your receiver (aux, cd, etc).
NEW BOZAK Phono Preamp Pre Amp Record Player Vinyl LP Album Amplifier eBay
Dec 30, 2017 | Yamaha Audio Players & Recorders
My DCP501 has no phono input, only tape. How can I connect my turntable to DCP501?
The newer receiver amplifiers have not provided an input for the low voltage phono cartridge, a pre-amp is required that has the proper impedance to match up with the phono cartridges.
The attached photo is an example of one of many that are available sense the old vinyls are coming back.
Hope this helps?
Nov 11, 2016 | Motorola DCP-501 Receiver
Can I connect a tape deck *and* a turntable to the Sony STR-DE595?
If your turn table has a magnetic cartridge it will not work,Becuase the ner recievers are not equip with a phono preamp, They are equip to only use a crystal or ceramic cartridge in the turn table.
Sep 29, 2012 | Sony STR-DE595 5-Channel Amplifier
I've connected my turntable to my stero system. When I try to play a lp the sound is terrible. I've replaced the needle. Did not help. Any ideas?
is the vinyl clean vinyl is supposed to sound weird thats what its all about. if the records not clean it could make it sound ****
May 21, 2011 | Numark ttUSB Turntable
I am trying to record my old vinyl records to a CD. I expected that the RCA leads from my turntable would just plug into the back of the RCD-W500C, but the manual indicates a somewhat complex cabling...
Complex? Traditional turntables need PHONO preamaplifiers (in receivers) to PREAMPLIFY the minute signal they produce to something useable.
"PHONO" is the only designated connection on a receiver that is literal and exclusive. Nothing but PHONO will work right on it and old-school turntables would require it to preamplify the tiny current produced by a Phono cartridge.
Just curious, priorto the arrival of the RCD, how did you play or listen to the turntable?
Feb 26, 2011 | Sony RCD-W500C 5-Disc CD Recorder
I just bought the t.55 usb turn table and am having trouble playing it. Do you need an amp?
hi,
yes you need an amplifier with or without phono input.
your turntable has three types of output
1.phono output (can connect to the phono input of an amplifier which has a phono input)
2. line level output [can connect to ( aux,cd,tape,tunner what u prefer) an amplifier which has these inputs]
there is a selection switch for phono or line level output on the back side
3. and usb( to computer)
Jan 06, 2011 | Stanton T55 USB Turntable
Connecting Pioneer SX-737 Receiver to computer problems
I've been recording LPs for over a year now.
I've got the turntable outputs plugged into the phono inputs on the receiver amp.
I'm taking the Y cord (pair of RCA connectors at one end, mini plug at other) from the Tape Record (these are what you'd use to send a signal to the tape deck for recording) on the amp to the "line in" on the sound card. You may want to look up the specs on your sound card to make certain that you've got the plug in the correct socket. There may be a "line in" and a "microphone" socket. Use the "line in"
What recording software are you using? Audacity is free and is ok. I'm using Goldwave (costs ~$50) and highly recommend it. MUCH better than any other package I've tried. Just google "goldwave" to find it.
The recording software should have an option for selecting / specifying a source. If you have "microphone" selected and the y cord going into the "line in" socket, yoiu won't get anything.
Dec 20, 2008 | Audio Players & Recorders
We have teh truntable properly connected to the computer but the computer isn't recognizing the turntable. The turntable turns, but we get no sound through the computer.
hi, first you have to take a pre amp phono, or a mixer for your phono....to amplified the signal coming from your vinyl...please check first..tnx
Nov 28, 2008 | ION Audio Vinyl Recording Turntable
Output from Denon D-700?
Hi ...
If there's a tape monitor in/out on the D700,turn the tape monitor on and connect the "Play out" phono jacks on the 700 to the line-in on the computer. Spark up the turntable and you should be able to listen to the vinyl on the PC while recording.
Nov 21, 2008 | Denon AVR-1803 Receiver
I need to connect my turntable to my reciever via Pioneer GR-470 pre-amp
no need for phono, you can go to radio shack and get a selection switch to make things easier.
Sep 19, 2008 | Pioneer GR-470 Home Equalizer
Panasonic SA-HE100 Receiver Logo
90 people viewed this question
Top Panasonic Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Panasonic Audio Player and Recorder Expert? Answer questions, earn points and help others
