Question about LG LRBN22514ST Bottom Freezer Refrigerator
Don't seem to be getting cold - LG LRBN22514ST Bottom Freezer Refrigerator
    Scholar:
  • 126 Answers
BEHIND THE REFRIGERTOR BACK PANEL THERE IS A BLACK KIND OF ROUND THING CALLED A COMPRESSOR IT SHOULD BE WARM. IF IT IS COLDYOU MAY NEED THIS.
http://www.searspartsdirect.com/partsdirect/showPart.pd?partNumber=6871JB1215A&productGroupId=0046&supplierId=795&brandId=x&documentId=P0506019&keySuffixId=A&modelNumber=x&keyId=000501A&pageId=00001&productTypeId=x&searchModelNumber=LRBN22514ST&subCompDesc=Cabinet%20assembly&brandDesc=LG&modelDesc=REFRIGERATOR&blt=11
IF IT REALLY HOT YOU MAY NEED THE SAME PART. MAKE SURE THE FAN IS RUNNING NEXT TO THE COMPRESSR. IF IT NOT THE REST OF THE TEST WILL NEED A MULTIMETER TO CHECK FOR 120 VOLTS AC
Posted on Apr 25, 2010
Refigerator and freezer all of the sudden don't seem to keep cold enough
The back wall of your freezer covered with snow? If it is I would suggest you replace the heater and a thermistor - Heater: WR51X10101 Thermistor: WR55X10025. If no snow then it is probably the main pcb: WR55X10656
Mar 24, 2013 | GE GSH22JFT Side by Side Refrigerator
Engine overheats and heater blowing cold air
You have air trapped in system , change thermostat , bleed air from system , let it run hot while adding coolant with blower full blast on all front and rear heaters .
Jan 23, 2013 | 2001 Audi A6
GE Profile Refridgerator side warm, freezer ok?
Fridge gets cold air from freezer to cool it. Your freezer is fine but not enough cold air is getting into fridge compartment. U have some dampers or louvers that direct air flow to fridge and if they are not set properly cooling will not be adequate. Check those out.
Sep 19, 2017 | GE Profile CustomStyle PCF23NGT Side by...
I have a Brivis buffalo 26 unit...the heating is on but it's blowing cold air the pilot doesn't seem to be light but I don't know how to relight it!
Try adjusting your thermostat, contact point possibly melt and welded by electric sparks. Replace thermostat control if contact won't get open.
Sep 02, 2011 | Heating & Cooling
Airconditioner makes loud noise when on coolant seems to be ok any suggestions
best to get gauges to check and make sure sometimes right before they go out they will blow good cold air sometimes seem better but actually going out don't let it lock up for not making sure
Jun 27, 2011 | Chevrolet Cobalt Cars & Trucks
The temperature in our refrigerator (Whirlpool Gold GD22DF) is not low enough this morning. Things don't feel cold. I've moved everything to a cooler and removed a small block of ice in the vent...
possibly the air damper motor has failed and needs tech help . you can possibly get by blocking the air damper open slightly but permanent fix needs done
Oct 08, 2017 | Refrigerators
1998 GMC Savana 3500 5.7L. Truck starts ok when cold. After running, very difficult to start have to pump the pedal and hold to the floor. Fuel pressure jumps to 62psi when pump runs, drops to 58 and holds...
HOW MANY MILES ALOT IT REALLY SOUNDS LIKE YOUR O2 SENSOR OK LOCATED ON THE EXAUST PIPE CLOSE TO ENGINE UNDER THE HOOD THEY CONTROL YOUR FUEL MIXTUER FOR HOT AND COLD LIKE A CHOKE . IF ITS BAD THE ITS FLOODING IT OUT WHEN HOT AND YOU GET ROTTEN GAS MILAGE BECAUSE YOUR FUEL PRESSURES ARE FINE REGULATORS EITHER WORK OR THEY DON'T AND IT THEY DON'T YOUR TRUCK WON'T RUN O2 SENSORS GOING BAD DON'T ALWAYS GIVE A CODE OR A DASH LIGHT BECAUSE OF THE BAD GAS MILAGE AND BLACK SMOKE WHEN IT IS WARM ITS PRETTY OBVIOUS WHAT IT IS OK GOOD LUCK POHLCAT
May 03, 2011 | 1998 GMC Savana
Freezer cold /refrigator warm . we have a side by side unit a couple of years old the freezer seems to work fine but the refrigator is warm .It don,t seem to make any funny noises and the back is clean
When the compressor is running, if the fan by the compressor and the fan inside the freezer are both running, and there is no frost on the back wall of the freezer (if there was frost would indicate a defrost issue) then check the air dampener. It is located at the very top left back side of the fresh food section. If it is not opening up, no air will flow from the freezer compartment (where all the cooling takes place) into the refrigerator section.
Jul 04, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
I have exactly the same problem
you need to change the cartridge, it is a temp control and is going bad so it keeps you from burning yourself it is like a mixing valve and is givng more cold water, that way you don;t get burned,,
Jun 18, 2009 | Grohe Integrated 1/2'' Shower Thermostatic...
LG LRBN22514ST Bottom Freezer Refrigerator Logo
116 people viewed this question
Top LG Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Mike
Mike
Are you a LG Refrigerator Expert? Answer questions, earn points and help others
