Question about Maytag Neptune MAH5500B Front Load Washer
Won't wash code LR showing up - Maytag Neptune MAH5500B Front Load Washer
  • 15,935 Answers
The LR error on your non-spinning Maytag Neptune is usually, though not always, accompanied either by a burn spot or a blown fuse on the Motor Control Board.
Maytag upgraded the motor and motor control board because this problem was so prevalent. Big rash of these a few years back... and insludes replacement instructions with the kit.
The LR code means "locked rotor" - the control is not seeing the motor turning.
The image below contains the wiring diagram for this washer as you requested but there are some other things to consider.
Usually when the LR code is displayed the motor has stopped turning for some reason.
By definition the LR code means the control has tried to turn the motor but was unable to.
The error code can be caused by to large of load, to much soap/suds in the water or a problem with the spin bearing.
The cause of the LR message can be little problem like suds or a major problem like the spin bearing and sometimes it's difficult to pin down.
You don't mention in your question if the LR code occurs every load or once a week.
Try running a rinse and spin cycle empty and see if the washer completes the cycle.
The 2nd image contains the information on how to enter and run a diagnostic cycle which may help pin the source of the problem down.
This test completes all functions of the washer is a short time. It will fill, tumble, drain and spin all is a few minutes.
At the end of a successful test cycle a PA should display which means "Passed" and is what you want to see.
Image 1: http://media.fotki.com/1_p,sqwrrqkkqkstsftxgtqsskgwtqkq,vi/kkwrfdskkxkgbffwfww/1/1303472/5961857/image53872img-or.gif
Image 2:http://media.fotki.com/1_p,sqwtrsgdwsqtqsqxgtqsskgwtqkq,vi/kkwrfdskkxkktggsfsw/1/1303472/5961857/image53908img-or.gif
From another source...
"Installing replacement motor, motor control harness, and motor control circut board.
Pretty easy install. On a scale of 1 to 10 I'd call it a 3.5.
If you can use a screwdriver, a wrench, and have played with legos before, you can probably do this job.
It took me about 3 hours to do, but this was with inferior tools, and two smoke breaks included.
Minimum tool requirements: Adjustable-head cresent wrench (8 or smaller handle), phillips head screwdriver, utility knife.
Recommended tool equirements: Small ratchet with socket set, ratcheting screwdriver with phillips head and small socket attachments, brew.
The instructions are pretty clear.
Once you pull the front panel off, there are two braces at 45 degree angles on the lower corners of the washer.
The instructions don't ask you to, but I would remove the brace on the left to make life easier.
This gives your arm more room to work and makes it easier to pull the motor out the front.
They ask you to remove the wiring harness from the motor first and then pull the harness out with the control board.
My wrench was too big to get to the bolt to remove the harness from the motor.
All I did was cut the harness - since they supply a new one - then pull out the control board, then pull out the motor.
As far as getting the pulley off, slip it on and off at the large wheel, this is much easier than taking it off at the small motor drive shaft.
The only other thing of note is to make sure you look at the diagram for the conectors a few times before you snap it together.
There are a few ways you could hook it up wrong so pay attention. There should be no loose ends when you finish.
Also, I couldn't get the flange back on on the rear acess panel when closing it up, but it doesnt seem to serve muc purpose besides asthetics, so I tossed it.
The $200 for the parts and shipping was well worth it. I saved about $150-250 to do it myself...."
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question (*&YU
Posted on Oct 01, 2010
2 Suggested Answers
blueextc3221
  • 15935 Answers
SOURCE: error code LR showing on display and washer will
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question#$
Why is my Maytag washer showing lr code again?
If you live in North Hollywood, CA and need washer repair service call us at (626) 460-0903 or visit our website Washer Repair North Hollywood CA 747 248 4544 Samsung
Sep 03, 2017 | Washing Machines
Lr code went into service mode but wont respond to commands model #fav6800aww
Tom,
The LR error code can be a tough one to troubleshoot but I'll see what if any help I can be.
The LR code stands for Locked Rotor.
If you Power Cycle the 120VAC to the machine will the error code clear?
What cycle was the machine in when you took the error code wash, spin?
If you remove the front panel and with the 120VAC power cord removed from the service outlet can you rotate the Clutch Pulley CCW (Spin direction) or CW (wash/agitate) direction.
Sounds like you have the FAV6800A/FAV9800A Service Manual.
Let’s see if the drive system is free and not locked up…………Rich
Jul 30, 2010 | Maytag Neptune FAV6800AW Top Load Washer
Will not spin cloths dry. Lr Problem
HERE IS a TROUBLE CODE CHART that you can download and SAVE for this to go by. I suggest to save it too for future reference
http://www.applianceaid.com/neptune8.html
May 29, 2010 | Maytag Neptune MAH5500B Front Load Washer
Motor won't engage. Error code LR comes up, but the drum, belt, and pin coming out of motor spins freely. May I get possible ideas for troubleshooting PLZ ?
code LR is a Locked Rotor on the motor,but you say the motor runs,then you need to open the top cover by removing the screws inside the detergent cover after unplugging the unit,inside ther should be a tech diagnosis sheet to help you diagnose your problem,just from this its either a bad tach sensor or pick-up coil on the motor that senses the motor speed during all washing cycles,if this sensor is bad it will show up as if the motor isn;t running or a LR code
Apr 03, 2010 | Maytag Neptune MAH5500B Front Load Washer
Display error code of Lr on control panel
L means "Lid or Door Lock" problem
r probably means 'release' I couldn't find it anywhere... so I'd guess that Lr means the machine did not detect that the Lid Lock released and cycle end (which means either the sensor is bad or the Lid Lock dosen't lock the Lid).
Either way, something with the Lid Lock system ais not right. Be glad it releases ;-)
Mar 27, 2009 | Maytag Neptune MAH5500B Front Load Washer
Code lr appears on washer
use normal cycle instead of clean just follow say instructions ..lr is code for remove clothes from tub for clean cycle problem even with no clothes they still show code ..it's a program problem that whirpool is aware of last i heard they were working on solution but instructing cust to just use normal cycle instead
Nov 17, 2008 | Kenmore Elite 45986 Front Load Washer
Fills with water but wont wash or spin
The code LR stands for locked rotor you will need a new motor and motor control kit pretty expensive and only covered under you warrenty for a year!
Aug 11, 2008 | Maytag Neptune MAH5500B Front Load Washer
Maytag Neptune MAH5500B Front Load Washer Logo
Top Maytag Washing Machines Experts
Bill Long
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
