Question about Garden
Pump won't kick in no pressure
I worked a month ago. engine runs fine, but the pump wouldn't get a load on it today. we tried cleaning out every thing we could in the waterflow department and there was plenty of pressure at the job site. troy bilt 7.25 hp 3000 psi pressure washer.
5 Suggested Answers
  • 61 Answers
SOURCE: troy bilt pressure washer will not build or reach high pressure
check the non-return valves in the pump block. if these are damaged or dirty you pressure will be greatly reduced. they are located behind the 3 lage brass hexagonal caps.
I hope this helps
Posted on Sep 20, 2009
SOURCE: oil for a troy bilt 2550 psi pressure washer pump
What fluid and how much is required in the Troy-Bilt 2550 power washer pump?
Posted on Apr 18, 2010
SOURCE: troy-bilt 2200 psi pressure washer
I have a Troybilt Model 2200 PSI Pressure Washer in which I have used only 2 times in the past 2 1/2 years. Went to use it this past weekend and the pump in not working. Water shoots out of the side. I bought this brand and model as I thought Troybilt was suppose to be so good. Went back to where it was purchased and had no success but to say I could buy another pump or take it in to be repaired. I believe that this power washer should be replaced at no charge. 2 uses does not constitute a few hundreds of dollars.
Have you to heard anything concerning pump problems on this particular model? Thanks for any advice. .
Posted on Jun 08, 2010
SOURCE: Need to know where oil
I have the same model...... it should be just underneath the unit.... it will look like a square head recessed. I used the ratchet set extension and it fit just right. I literally had to tilt the darn thing upside down to find it. Then once it was loosen a bit, I put the machine upright on the wheels again, and slip a plastic pan underneath as I finished unscrewing the oil plug, Out came the black goo.
Posted on Sep 26, 2010
I HAVE A RYOBI PRESSURE WASHER 3100 PSI WITH HONDA ENGINE PURCHASED FROM HOMEDEPOT USED IT 2 WEEKS AGO RAN PERFECT TRYED USING YESTERDAY AND I HAVE NO PRESSURE THE UNIT IS ONLY 10 MONTHS OLD ANY SUGGE
  • I have the exact same pressure washer..bought 10 months ago from Home Depot with the same problem..no pressure. Have you had any luck finding out what the issue is?
Jul 22, 2014 | Ryobi Gas Pressure Washer: 3100 psi 2.5...
I have a 1993 Jeep Wrangler, I just replaced the Fuel Pump several Months ago and it worked great until about a month ago, now I seem to have an issue where I have to spray Primer in the Engine to get it...
the fuel pressure regulater on the pump sounds like its draing back
hood a gauge and watch the pressure should only lose a small amout of pressure in 5 mins after shutting down the engine
Aug 25, 2013 | Jeep Cars & Trucks
Kenmore 417.43142200 final spin is slow
obviously the timers contacts are bad so replace the timer.
May 16, 2017 | Kenmore 43142 Front Load Washer
2004 Saab 9-3 Aero. replaced fuel pump aprox four month ago ( @ Aprox 100,000 miles), the last two fuel fills I have smelt gasoline in and around car (no visable leaks). Check engine light came on 1 week...
While a fuel filter won't normally cause the check engine light, it could cause other errors that would trigger the error light to come on.
Since fuel filters are easy to change and not very expensive, I would change it and see would happens. But you might also want to run a pressure test on your fuel pump also.
Jul 08, 2011 | 2008 Saab 9-3
I have a 2006 Pontiac GT G6 Coup. When we first bought it back in Nov. 2010, it was fine. After a month or two, the clock would reset almost everytime the car was started, radio stations would NOT get...
sounds like a problem with the ignition barrel.the wiring is loose or the connectors are loose or the barrel is faulty,unless thse are all run from the onboard computer.
May 31, 2011 | 2006 Pontiac G6
F150 97 4.2 V6. Runs fine at idle but when in
its posible that the inside lining of the tank is coming off and plugging the fuel pump strainer,or at least thats what happened to my f150,and its not getting enough fuel pressure.
Nov 14, 2009 | 1997 Ford F150 Regular Cab
2003 Neon air coditioning shutter
the AC servo that kicks up the engine idle speed when the AC is no..Is stuck or faulty...Replace it.
Apr 05, 2009 | 2003 Dodge Neon
Garden Logo
113 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
