Question about Linksys Wireless-G Broadband Router
Can't find AOSS button on my router - Linksys Wireless-G Broadband Router
  • 355 Answers
The AOSS button as for as I know is only on the Buffalo brand routers
HERE is the link to the Buffalo website explaining the AOSS feature so your Linksys router will NOT have an AOSS button at all
Buffalo Solution
The AirStation OneTouch Secure System (AOSS™). With AOSS, users can set up the securest wireless network possible, easily and quickly. AOSS automatically detects and configures other AOSS enabled wireless devices and clients and seamlessly negotiates the most secure connection possible between your wireless devices.
Posted on Apr 25, 2010
What is the aoss button
The AOSS is not such a button but more a feature of your wireless router. If you enable this you must make sure that your router is compatible with it AOSS. It is kind of like a special kind of wireless signal that only certain routers and devices can use. It is likely that you will have a standard wireless router rather than one that supports AOSS but if you have a router that supports AOSS you can use it as it is a little more secure than a standard connection.
Hope this helps
Mar 06, 2011 | Sony PlayStation® 3 (60 GB) Console
Where is the aoss button at on psp
HI. This question and issue is one of the most misunderstood attributes of the PSP unit. Essentially; The AOSS Button and indicator are on your router. This is not on the PSP hand held device, at all. With that said; There were some earlier models that actually had this particular button on the top right side of the device. This has been removed and is not part of the newer PSP designs.
In order to connect an AOSS-enabled client(PSP) to a compatible router, you first will need to press the router's AOSS button for 3-5 seconds; which illuminates a flashing amber indicator on the unit. This puts the router into "AOSS mode," during which it can accept configuration requests from AOSS clients. Make sure you align your PSP Parallel with the router to get Max signal strength.
NOTE_ There are some routers on the market(low level), that are not equipped with this feature.linksys models will be one of those none AOSS compatible brands, among others.
Nov 30, 2010 | Video Game Consoles & Games
How to get the AOSS to work?
AOSS stands for Air Station One-Touch Secure System. It is a proprietary method of security that automatically configures the SSID and WEP key for wireless routers made by Buffalo Technology and a wireless device connecting to it. You can use the AOSS setup method with any AOSS compatible router. AOSS capable routers will have a button on the router identified with the letters "AOSS." Review the documentation for your router to verify if it is AOSS capable before continuing with your setup. Routers with AOSS are able to automatically detect the Nintendo DS and reconfigure the settings for both to establish a connection with each other. Routers with this feature will have a button on the router identified with the letters 'AOSS'. If you are not sure if your router is AOSS capable, please refer to your router's manual. Important If you already have other wireless devices configured to use your AOSS access point, you may have to reconfigure them after setting up the Nintendo DS to connect to it. If you feel this may be the case, we recommend using the "Search for an Access Point" function of the Nintendo DS.
Nov 25, 2010 | Nintendo DS Console
AOSS is what you would see on some high end routers. if your router doesn't support this method or have this button you can't set up your psp using it.
The psp does not have an AOSS button. AOSS (AirStation OneTouch Secure System) is used for wireless setup of devices like your psp for your network. Your router will have a button on it for this. If it does not then it more than likely does not have the ability to set up the devices in this manner.
here is the steps for setting it up if you did have this feature on your router.
1)To use this set up for the PSP go to Settings>Network Settings> infrastructure mode>new connection>automatic - AOSS. At this point the PSP will tell you to push the button on the router and that you have two minutes or else the attempt to connect will stop.
again this only works if your router has the AOSS button. and it is not found on your psp.
May 12, 2010 | Sony PlayStation Portable (PSP) Console
Where is the aoss button on a ps3
AOSS is what you would see on some high end routers. if your router doesn't support this method or have this button you can't set up your ps3 using it.
The PS3 does not have an AOSS button. AOSS (AirStation OneTouch Secure System) is used for wireless setup of devices for your network. Your router will have a button on it for this. If it does not then it more than likely does not have the ability to set devices up in this manner.
1)To use this set up for the PS3 go to Settings>Network Settings> Internet Connection Setting> (Method) Custom> (Select Connection Method) Wireless- (WLAN Setting) Auto - AOSS. At this point the PS3 will tell you to push the button on the router and that you have two minutes or else the attempt to connect will stop. and again this only works if your router has this button. and it is not found on your ps3
May 02, 2010 | Sony Playstation 3 (PS3) Console
Were is the aoss button on the psp
You should find the aoss button near the power on/off button. Older PSP models dont have aoss button in which case you need to set it up with the router.
Jul 10, 2009 | Sony PlayStation Portable (PSP) Console
WHERE IS THE AOSS BUTTON O A PSP
No, there is no AOSS Button on the PSP. You have to have a router. This router is hooked up to your computer and is around a $100.00 but you have to have DSL or something like it to run a phone line though. If you do not have this you can go to a Holiday Inn or Wal-mart parking lot who has this router hooked up already. You can access to the internet there.
May 26, 2009 | Sony PSP (Piano Black)
Weres the aoss button
Normal 0 false false false MicrosoftInternetExplorer4 st1\:*{behavior:url(#ieooui) } /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} I think there is no AOSS button on your PSP. AOSS is a wireless solution made by www.buffalotech.com. Most new wireless routers/access points has this capability. AOSS is on the wireless router/access point and not on the PSP.
AOSS will automagically determines and configures the connection of a PSP to a wireless access point by pressing the AOSS button on the wireless access point.
Apr 09, 2009 | Sony PlayStation Portable (PSP) Slim...
What is the aoss button/
To set up Wireless correct? Well apparently there is none and you have to set up the wireless connection manually, you do this by going into your network settings. This is where you set up your network options.
May 26, 2008 | Sony Playstation 3 (PS3) Console
Where is the aoss button on psp
The aoss button is not on your psp Its on your stick, hold down the left on your stick. <> It will start blinking. if you dont know what i mean still.There are to lil simbles on your left of the psp They are very small. up just a little bit is a stick.sometime you use the stick to operate your game.(move) Click the left of it. If you dont get that then your ******* stupid
Mar 18, 2008 | Sony PlayStation Portable (PSP) Console
Linksys Wireless-G Broadband Router Logo
1,201 people viewed this question
Top Linksys Computers & Internet Experts
Prashant M
Prashant M
Are you a Linksys Computer and Internet Expert? Answer questions, earn points and help others
