Question about Frigidaire 24 in. FDB635RF Built-in Dishwasher
Does not start when i shut door, and turn the dial. worked fine yesterday
  • 523 Answers
Check the power and wires
Posted on Apr 25, 2010
DDW1802W ran fine yesterday. Panel light os, no start. Door seems to latch okay. It's not an overflow switch issue. No burnt smell.
dishwasher wont turn on. power is ok. when you turn the dial with the power switch on it clicks motor turn on pumps do not turn on wont fill or empty power light does nnot light up latch seems to be fastening proper is there a reset switch
Apr 09, 2011 | Danby 17 in. DDW1802W Designer Series...
Hi I have kenmore elite dryer, model 110.85091400, it was working just fine Yesterday I opened the door to add a sock in it , I thought I pressed pause before opening, shut door and pressed start. It...
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor going bad...
Here are a couple of tips that I wrote will help you to figure out why your dryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
Aug 22, 2010 | Kenmore Dryers
Will not turn on
A dryer can not start for many reasons...
This tip that I wrote will help you to figure out what is happening...
http://www.fixya.com/support/r4460438-dryer_repair_dryer_will_not_start
heatman101
Apr 05, 2010 | Dryers
The door lock isn't engaging.
you may have bent thr hing on the door if you lean on them on top they will bend try a little lift on the door then close
Sep 11, 2009 | GE WSXH208A Front Load Washer
Heater temp on mercury '98 mountaineer only blows hot
Everything that is heat and cooling in a vehicle is controlled by vacuum from the engine. It appears to me that your blend door vacuum line to the temp control switch is either off or cracked/broken and not making things work the way you want/expect. It's the vacuum friend.
Jul 01, 2017 | 1998 Mercury Mountaineer
could be the blend door motor or the door could be broken these are common
May 09, 2009 | Mercury Mountaineer Cars & Trucks
Dryer wont start
http://shared.whirlpoolcorp.com/assets/pdfs/literature/Use%20and%20Care%20Guide%20-%208522243.pdf
if possible, with the door open, push the limit switch the door normally hits to let the drier know the door is shut. That switch may be bad.
Dec 27, 2008 | Whirlpool LEQ9858P Electric Dryer
Kenmore 90 Series Electric Dryer will not run
chech to see if your belt is broken. It may have a belt switch
Oct 28, 2008 | Kenmore 62602 Electric Dryer
Dryer shut off towels were not yet dry, turned dial to restart dryer acts as if it isn't getting power I closed door and pushed start button. Nothing! Checked breakers and power cord at outlet all checked...
Hello mdonettaYou said,
Dryer shut off towels were not yet dry, turned dial to restart dryer acts as if it isn't getting power I closed door and pushed start button. Nothing! Checked breakers and power cord at outlet all checked okay. Any ideas.
yes, try unplugging the power cord or turning off the breaker for 5 minutes. Either will due. Some times the system needs to be reset!
If this does not work there are internal fuses that can be replaced!
Let me know how it goes!
Huuum
Sep 19, 2008 | Dryers
Frigidaire 24 in. FDB635RF Built-in Dishwasher Logo
127 people viewed this question
Top Frigidaire Dishwashers Experts
Mike
Charles T Nevin
Charles T Nevin
Are you a Frigidaire Dishwasher Expert? Answer questions, earn points and help others
