Question about Magellan GPS
Cannot enter lat/long into GPS
I cannot get satellite coordinates or latitude/longitude to enter. I get error message that they are incorrect. I have used the magellan triton 200 before and it worked very well. This is a new one and I can't get it to work.
SOURCE: Toggling between lat/long and grid references
I eventually solved the problem by firstly doing a restoration of default settings. This allowed me to toggle but it was between two different presentation styles of latitude and longitude. To restore the grid co-ordinates option I went to main menu, the Setup, then then toggled to location and re-selected UTM UPS as the location format.
Posted on May 05, 2008
SOURCE: latitude longitude
Create and save a waypoint for any location then update that waypoint with the lat/long you were given (just click on the lat/long and key in the new coordinates).
Posted on May 15, 2008
  • 638 Answers
SOURCE: navigation
You'll have to do this online
http://www.cellspark.com/UTM.html
Posted on Sep 28, 2008
  • 638 Answers
SOURCE: How do I enter gps coordinates into my Etrex H
Mark a waypoint, and then edit the waypoint's co-ordinates. You can also create a waypoint in Mapsource and then transfer the waypoint(s).
Posted on Oct 09, 2008
SOURCE: TomTom One 3rd Edition - Latitute Longitude are Wrong
Are you sure that you have set the latitude and longitude units correctly? Under Preferences go to Set Units, press done until you come to latitudes and longitudes. You have three choices, Degrees in decimal form, Minutes, or Minutes and Seconds. Printed maps might use any of these forms of latitude and longitude. Avation maps are usually different than ground maps. Hiking maps also use either of the three forms.
Posted on Dec 31, 2008
How to put in cordinance
Navigating to latitude and logitude is not supported on all devices. If it is supported on your GPS model, from the main MENU, tap CHANGE PREFERENCES, then tap SET UNIT, select the Latitude and longitude format in the Coordinate display screen and tap DONE.
Then from the MENU - tap Navigate TO ... select Latitude and Longitude, enter the coordinates and tap OK
Aug 14, 2013 | Tomtom GPS
Can gps coordinates be used with TomTom go live 750
If you mean, can you enter latitude and longitude coordinates on your GO 750 LIVE GPS device .... yes.
First you'll want to set your unit to accept coordinates. From the main menu, tap Change Preference, then select "Set Units" and select a Latitude and Longitude format in the "Coordinate display" screen, and then tap Done.
To navigate to a location using latitude and longitude coordinates, follow the steps below:
  1. From the Main menu, tap Navigate to...
  2. Tap Latitude Longitude.
  3. Enter the coordinates and tap OK.
May 09, 2013 | Tomtom GO 750 LIVE GPS Receiver
Can I set the TomTom to "go to" a longitude/latitude location?
Yes.
Feb 08, 2012 | Tomtom GO GPS
My Garmin nuvi 1300LMT can't find my home address and my maps are updated....HELP!
I have a Garmin nuvi 1390 and live in the country, so my Garmin was unable to locate my address. I'm not sure if this will work on your model, but it may be worth a try. What I did is this: I turned on my Garmin at my house and let in acquire the satellites, I then went to the Tools menu and chose "Where Am I?" It should now display your location using longitude and latitude. If you can save this location and name it as "Home", or at the very least write down the longitude and latitude coordinates and then use the "Where To?" function, select Coordinates, type in the coordinates and save it. You should be able to save it with any name you choose.
Hope this helps.
Dec 28, 2010 | Garmin nuvi 1300 Car GPS Receiver
How do i get coordinates in Latitude@ longitude
To find a place using coordinates:
1) On the Menu page, touch Where To.....Coordinates.
2) Touch Format to set the coordinates format
3) Touch each box to change the information.
4) Enter the coordinates for your destination, and touch Next.
5) Touch Go
Nov 17, 2010 | GPS
How do you enter coordinant into GPS to find a
the 1212 will not do what you want it to do...its just not capable of taking longitude and latitude.you can get copy of your manual for your 1212 here
.probably the easiest way around this problem, is to get the address somehow (was there a phone number provided with the rv location list)
if you know the approximate location, you can use google maps to zoom in and get a street address
google maps here
you could also use google earth if you have it..if not, you can get it here very cool even if youll only use it once.
you can enter longitude and latitude in google earth
let me know if you need more help
good luck
May 05, 2010 | GPS
Can my TomTom XXL 540-S be used with GPS coordinates?
If you are referring to Latitude and Longitude , yes. You can use those co-ordinates to navigate to a destination. This especially works fine in countries where the Avenue and street information is not available. Google maps can give you the latitude and longitude coordinates. You can fed those into the GPS and navigate. Please note, you will need the maps of the region involved. Click (Tap) on the main screen. Tap on: navigate to Tap on : arrow Tap on: Latitude longitude Enter latitude and longitude using keyboard, Latitude first and longitude next. Be careful while you do this and do not forget to enter the directions North, West etc.
Apr 27, 2010 | Tomtom XXL 540S GPS Receiver
Where do i find the satalite coordinates for bell expressvu in california
For Nimiq 91W- ExpressVu Standard based on Los Angeles coordinates are Longitude 91... 34 N Lat, 118.25 W Lon
For Nimq 82W-ExpressVu HDTV and international based on Los Angeles, Longitude is 82... 34 N Lat, 118.25 W Lon
http://www.kusat.com/install/calculator.php
Dec 08, 2009 | Toshiba Satellite R10-S802TD Tablet PC
Downloading latitude and longitude
Do you want to enter them manually, or via USB?
To enter a location manually, using only GPS coordinates, try the following: Create any entry in your address book - it doesn't matter what you enter since you will be totally changing it anyway! Then 'edit' the address book entry that you just created, putting what you want in each data field. Finally, edit the GPS coordinates for this address book entry (note that you have to overwrite the whole entry, beginning with N, S, W, E and then the numbers). Save your changes and now you have an address book entry for that rig.
I do not know how to download this directly using the USB connection - sorry.
Jun 29, 2009 | Lowrance iWAY 600C Car GPS Receiver
Latitude longitude
Apr 17, 2008 | Garmin eTrex Legend GPS Receiver
GPS Logo
215 people viewed this question
Top Magellan GPS Experts
Will Halftowaite
Are you a Magellan GPS Expert? Answer questions, earn points and help others
