Question about John Deere 420,1020,2010,2020,2510,2520 Tractor Float
Noise in the area of the mag clutch on a gt262 with the clutch peddle released
Noise when you press the clutch peddle.
you will have to take it apart again then see if it all alined right
Jan 06, 2014 | Garden
2e clutch problems
One finger on throw bearing may be off. Hope knot.
Gear doesn't engage
When the problem acures again.Have someone step on the peddle,then release does the clutch leaver in the bell housing go back allso,if not loosen the line at slave cylinder,does it go back now,if not might be binding at trans input shaft.if it does release tighten line again pump peddle 3 times and go after master cylinder line.with peddle released does fluid squrt out.has the fluid ever been changed.like all fluids they absorb moisture that freezes or creates dirt from rust and binds the system.i would flush with DOT3 or DOT4 BRAKE FLUID.
Nov 21, 2012 | Cars & Trucks
What are the signs for burnt out clutch?
When you press the clutch peddle down and engage 1st gear then release the clutch peddle and rev the engine, the vechile doe not move. This means the clutch is either worn out (burnt out) or it is adjusted incorrectly.
Dec 03, 2011 | Cars & Trucks
Me and a mate have been trying to bleed my clutch on my 80 series for 5 hrs and carnt get anywhere. What the hell am I doing wrong? I can do everythingt else other then 1 of the simplist job
Just follow the procedure in the right order. Fill the clutch reservoir on the master cylinder to the max and leave the lid loose. Fit a transparent plastic pipe on the bleed nipple on the clutch slave cylinder bleed nipple. Put the other end of the pipe into a jar to catch the waste fluid. Put some thick grease around the base threads of the bleed nipple, this stops air being sucked in via the threads whne the nipple is slackened off. Loosen the bleed nipple by 1/3 of a turn. Have your mate slowly depress the clutch peddle. When he has reached maximum travel have him hold it there while you turn the bleed nipple a third turn back to tight. Have your mate release the clutch peddle, clutch fluid from the master reservoir should now fill the the master cylinder. Have you mate press the peddle a quarter way and then release the bleed nipple a 1/3 of a turn. Have your mate depress the clutch peddle all the way to maximum travel. Again tighten off the bleed nipple before releasing the clutch peddle. Keep doing this process until no more air bubbles can be seen in the fluid in the pipe attached to the bled nipple. Every four cycles or so check on the fluid level in the master reservoir and keep topped up with fresh fluid. When everything completed tighten the bleed nipple, it is not necessary to tighten the hell out of it as at some point you may need to do this again. Wipe everything down pump the clutch peddle a few times to be sure of correct operation and no leaks.
Jul 01, 2011 | 1991 Toyota Land Cruiser
Clutch peddle constantly vibrates up and down and smoke is coming from the engine area, also there is a high pitch sqeaking noise. any ideas?
If your clutch is pulsing you are feeling the crankshaft moving back and forth. The noise is related and this noise could ver well be a spun main brg. Serious ckg needs to be done. Drain the engine oil and note any sign of oil burning, being overheated and any bearing Material presence.l
Oct 20, 2009 | 1997 Audi A4
Is it my clutch or gearbox or something else
hi sounds like the clutchs release bearing when you press the pedal noise the noise appeared but when in neutral noise is not there this is second one tonight with simular problems for this year and model yates210456
Sep 29, 2008 | 2000 Ford Escort
Whining
hi these boxes tended to be a bit noisey anyway but a simple test for the release bearing and first motion shaft is easy first make sure g/box oil level is ok
start engine ,take your foot off the clutch peddle compleatly you have a whine, put your foot on the peddleVERYlightlynoise should change ,if the noise is more of a rattle than a whine it is coming from the clutch release bearing if it a definate whine it is either the spigot bearing in the flywheel or the first motion shaft
Jul 11, 2008 | 1999 Toyota 4Runner
John Deere 420,1020,2010,2020,2510,2520 Tractor Float Logo
48 people viewed this question
Top John Deere Garden Experts
Phil Walker
Phil Walker
Tim Whalen
Matt Olenzek
Matt Olenzek
Are you a John Deere Garden Expert? Answer questions, earn points and help others
