Question about Samsung SyncMaster 2253BW LCD Monitor
I have problems viewing dark websites. My screen dim's, I can still read everything, it's just very dark. It also makes a humming noise. Is it something I can adjust. Cheers, Michelle
  • differencede Apr 25, 2010
    Thanks for your help... its probably helpful if I had included a bit more information. The screen dims when I view a dark website, or if I have a lot of black on the screen. Once I move away from the dark site, or reduce the window so there is more white showing, then the dimming stops...
    I have reset factory default and it's still happening...
    Cheers
    An expert whose answer gotĀ voted for 100 times.
    Novelist:
  • 141 Answers
There is a small row of buttons on the bottom right of the front panel of the monitor. From these buttons it's possible to adjust: Gamma correction, Brightness, Color balance, H/V position, Color temperature, and Contrast. By pushing the menu button your choices should be diplayed on screen. If there is a choice of "factory default" try that and it will take all adjustments back to as they were when it was set up when new. You won't find buttons to match the adjustments I mentioned above. There may be just 3 buttons but by way of the on screen menu they are enough to acheive what you want.
From past experience I'd say it's possible someone has been playing around with the buttons and upset it's settings.
If you continue to have problems I can download the manual and guide you from there.
Posted on Apr 25, 2010
Testimonial: "No focus problems at all. The screen (as you said) is awesome. Thanks for your help."
  • goodbye goodbye Apr 25, 2010
    I'm beginning to think perhaps you have a power supply problem. I assume you tried to adjust Contrast and Brightness as well. If this didn't solve the dimming I would be taking the monitor along to a qualified service tech who has plenty of experience with LCD monitors. I didn't realise the dimming varied with what was being displayed on the screen. With the older CRT monitors the symptoms would be a shrinking of the picture depending on screen content. With the LCD it's a different system completely and dimming could be the CRT equivalent. Even the buzzing could point towards the power supply as well. A shame too, what you have is a very nice monitor and well respected as a good reliable unit with excellent picture quality.
    I always try for the easy customer fixit routines first. I don't jump in and say " take it to a repair shop" first up. But I'm afraid in this instance it would be the best choice if the brightness and contrast don't have any effect. Tell me, are there any focus problems as well? I ask that purely for personal knowledge reasons.
    Thanks Michelle I sincerely hope you get better soon and leave all those nasty problems behind you.
    God Bless Stu
Why is my heated auto dimming driver side and rear view mirror getting dark when driving
Look in the fuse box for the fuse it will likely have other things on it but nothing to high voltage .
Pull the fuse and see what happens .
Honestly I have never heard of this .
Unless the mirrors lit or damaged somehow from to much heat damaging the coating on the back of the glass making it not a mirror any more .
This sounds like a factory defect
Feb 19, 2016 | 2004 Chevrolet Avalanche
Why does my screen go dark when I am making a call
It should go dark when you put throne up to your face. That keeps it from getting to warm on your face. If you don't want it to go dark, you can turn the auto dim off in settings under display. It will use more battery, but it shouldn't go dim. Then that may be under another setting.
Aug 26, 2014 | Cell Phones
Monitor dims when we turn lights off in room.
You need to give a more detailed description of the problem.
The LG 47LH90 is an LED backlit TV with 'local dimming' technology. This means that there are lots of white LEDs behind the screen and these can be controlled in groups to allow localised areas of the screen to be dimmed to produce better contrast between light and dark. It is very likely that when the room is dark, this local dimming is more noticeable. The actual individual LEDs cannot be controlled and so the area that is dimmed will generally be greater than the area that is required to be dark 'blooming effect'. In addition, LED backlit displays only maintain their contrast through a tight viewing angle. If you sit too farto the right or left, then light from non-dimmed LEDs will leak through and the screen will look lighter.
In short, there may not be any fault with your TV.
Jul 12, 2011 | LG 47LH90 47 in. HDTV LCD
Tv went grayscreen, flickering. turned off, then
When you had gray screen and flickering you had only one problem - color wheel. After "putting everything together" you have totally different problem, caused by multiple possibilities like: forgotten connectors, cut/jammed cables/wires, lamp not being inserted properly, lamp door not being set properly, disconnected color wheel, etc. Try to open rear cover and redo what you have done. Remove optical block, check everything visually and slowly put everything back. If still no luck - then only skilled TV repairman may (or may not) help.
Mar 10, 2010 | Samsung Televison & Video
The screen on my Compaq Evo N610c is dim
You could have a faulty inverter or a CCFL lamp, To determine if you have a LCD screen, inverter or video card problem, read this and follow these instructions.
Defective CCFL backlight, it may have the following symptom: Screen flashs on red/pink and off. Picture stays on in red and slowly be come normal. Picture flickering with dim display or appear black. Picture flickering on and off. All these symptoms indicate that the LCD backlight lamp (CCFL Lamp) has reached the end of the life and all you need to do is replacing the CCFL lamp.
Connect an external monitor to your laptop and power the monitor up first then the laptop, if you see the normal Windows images then the video card and laptop is OK and the problem is definitely the backlight. Dim image and/or dark display on the laptop's LCD screen indicates a faulty LCD backlight and it could be the inverter that supplies high voltage to the CCFL lamp or it is the CCLF lamp is nearly burnt out or burnt out, most likely this is the case.
The inverter can be replaced easily but the CCLF lamp is more time consuming and requires soldering skills.
Check out
www.lcdparts.net
for parts, repair service and DIY info.
Jul 11, 2009 | Compaq Presario Notebook
The humming noise from my hitachi 42hds69 television seems to have gotten a little louder. This humming sound is more prevelant on various stations. The humming sound seems to be normal/better on dark...
usually it means your screen is going bad unless it is a fan or some mechanical part thats humming if it comes from the screen itself the screen panel going bad.now you can check cables and eveything else for this a signal loss type of short but if you have allready checked all cables or recievers or connected devices for this then its a simple main panel humm means a bad screen panel sorry to say but i hope this helps..
Jun 24, 2009 | Hitachi 42HDS69 42 in. Plasma Television
Screen IS black, BUT EVERYTHING ELSE IS OK
there is a invertor in LCD. it makes your lcd bright white shine. if it doesnt work you can have dark view. i mean something going on the lcd but you cant see clearly. take to tecnic service your computer.
i hope it works.
May 27, 2009 | Dell Inspiron 1501 Notebook
My Icebox Flipscreen Computer/TV/DVd/CD/Radio won't turn on...
I had the same problem with my unit. Amber light was on and humming sound comming from speakers. Motherboard had to be repaired by ICEBOX dealer that sold me my unit.
Their website is www.lordantech.com
Feb 26, 2009 | Computers & Internet
Laptop screen illumination
The fault could be a faulty CCFL lamp or inverter.
Check out
www.lcdparts.net
Nov 03, 2008 | Gateway SL9550-30165318 Notebook
Samsung SyncMaster 2253BW LCD Monitor Logo
332 people viewed this question
Top Samsung Computers & Internet Experts
Computer Repairing
Computer Repairing
Are you a Samsung Computer and Internet Expert? Answer questions, earn points and help others
