Question about Acer Aspire 3610 Notebook
I have an acer aspire 3610 that will not charge new or old battery it operates perfectly when plugged in.
  • 30 Answers
That area of motherboard is damaged. voltmeter testing to batteries first
Posted on Apr 25, 2010
I used it the night before it was fine i plugged in the charge and it wont turn on at all
laptop charger for acer aspire 3600 3680 series 3650 3610
www.amazon.com/LAPTOP-CHARGER-ACER-ASPI...
Amazon.com, Inc.Amazon.com: LAPTOP CHARGER FOR ACER ASPIRE 3600 3680 SERIES 3650 ...When I was looking for a charger cable for my laptop, i was not sure whether I ... it was really good and worked, it heats up a little bit but for now its working ...
When your acer aspire 5738 z laptop adapter is not working ...
docslide.us > Business
Aug 18, 2015 - When Your Acer Aspire 5738Z Laptop Adapter is Not WorkingA ...Quicker Charging of Laptop Battery with an Acer Aspire 3600 AC Adapter ...
batteries-store.pblogs.gr/.../when-your-acer-aspire-5738z-laptop-adapter-...
Jan 14, 2016 | Acer Aspire 3600 Laptop Charger...
Acer 3610 screen goes black
It can one of many problems.(did anyone open it,does l/p get hot, is battery charging)
Plug in external screen
how did the problem start
need more information
May 06, 2012 | Acer Aspire 3610 Notebook
Acer aspire battery critically low but not using battery, it shuts off anyhow
If thelaptop battery is more than 3 - 4 years old then the battery could be worn out.Rechargeable batteries have a finite number of charge and discharge cycles andwill lose their charge capacity over time, i.e. won't charge to 100% andgradually the charge reduces until the battery won't charge up at all. OR Thebattery shows a 100% charge but when the adapter is disconnected the batterydrops off to zero capacity in a very short time. If the battery drops to anunacceptable charge level then the battery needs to be replaced.
Mar 04, 2012 | Acer Aspire 3610 Notebook
The battery won't charge on acer aspire 3610. I replaced battery with a new one which arrived with 65% charge. I fitted it and laptop worked until no charge left. The charger is plugged into mains and...
check the output of the charger and see if it is charging if so the conector might be bad does the plug wiggle when it is plugged in? it should feel very solid
Nov 27, 2009 | Acer Aspire 3610 Notebook
New AC Adapter Will Not Charge Battery/Operate Computer
Most probably static electricity killed some circuitry inside your laptop.
Nov 12, 2009 | Acer Aspire 3610 Notebook
I have an Acer Aspire 3610 notebook. It wont charge
How old is your battery? When you use your laptop, do you run it on just the battery or do you use your a/c adapter and battery? If you're going to use your laptop for an extended period of time, it's recommended to remove the battery and run off of a/c power alone. This helps to extend the life of your battery. Over time, using both a/c and battery will cause your battery to charge/discharge, which dramatically shortens the life of the battery.
You may simply have a dead battery.
Another alternative is that you have a bad power unit, which is what the a/c adapter plugs into on your laptop. My guess is that you most likely have a dead battery.
Oct 07, 2009 | Acer Aspire 3610 Notebook
Battery not working
Check to make sure the new battery doesnt have some clear plastic that covers the terminals. SOme new batteries have something covereing them when they ship to prevent it from gathering dirt/grit or coroding, or touching anything metal.
You will have to probably charge it for several hours the first time as it needs a deep cycle charge. It depend on the battery type.
Be sure to read any material that came with it, or at least give it a quick glance, it may not be compatible or have some locking mechanism.
It may look exactly like the old one but if it has slightly different pins, it may not work.
Dec 17, 2008 | Acer Aspire 3610 Notebook
Acer Aspire 3610 plugged in closes down
I would suggest you just plug it in and do not power on the laptop for a few hours. Then try. If it persists reboot into safe mode and disable hibernation then reboot
Dec 06, 2008 | Acer Aspire 3610 Notebook
Does not turn on
ummm, get a new hard drive, get the motherboard checked for cracks and just get the battery replaced(or charge the battery)
Sep 01, 2008 | Acer Aspire 3610 Notebook
BATTERY CHARGE
you need to change your battery. Most likely the circuit in the battery is no longer functioning properly
Apr 07, 2008 | Acer Aspire 3610 Notebook
Acer Aspire 3610 Notebook Logo
129 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
