I have a RCA, model number HD61LPW42. I've replaced the color wheel and the ballast. TV will not come on. I've heard that you had to reset something but not sure what. No picture, no sound. Light by power button comes on and flashes green. Any suggestions?
  • mfluellen Apr 25, 2010
    It worked before replacing ballast. Could it be anything else?
  • 12,061 Answers
Http://load1.givemefile.net/download.php?id=1165712
Above is a rear projection TV service manual, so you can troubleshoot & repair your set.
www.tvtechcenter.com/board/.../rca/ATC311%20Training%20Manual.pdf
Above is an RCA Rear projection training manual, this is what the engineers use to troubleshoot and repair. Please have a look at what you'd need to do to repair, ....
With this symptom, it is impossible to tell what the exact "Cause" of this symptom is. The LED's do not tell us what is wrong, sometimes it may indicate the "Area" in your case it is the X board. BUT thats NOT where the "Fault is" thats just the part that is affected. These days unlike the "Old" analogue days it just isn't realistically possible to fix anything but the most basic of problems with todays sophisticated units. This is quite apart from the Safety aspect, any unit that can cause a firs or have an explosion, or both, is NOT to be treated lightly, and and the repairer, of the unit is legally responsible, another thing to think about. Also, one must have tools, a Multimeter, a soldering iron, a deslodering iron, an oscilloscope, a signal tracer, tools, and most important of all, a Service Manual, without which, there is no way to even begin to understand and fix it, and more importantly Program it, AFTER it has been fixed. As these days a TV, is a PC, a Tuner, and an HDTV Monitor, and more, all in one. in the "old" days TV"s were more, rudimentary, and built to last for 20 years, and a "Parts" supply was set aside. They usually used to fail for only a few reasons, and they while still difficult, were less difficult to repair. Electrical knowledge was transferable, and they could be and would respond to, This-is-the-symptom-This-us-the-Fix, But that no longer applies, as now, it can be a Fault on I squared Bus, or "Sensor" failure, or it simple may have "Crashed" just like a PC, It could be a Diode go bad, and that will stop the whole thing. You see, in the day, the sets were Very "Fault Tolerant" because they were Analouge, and a faulty, component, or more sometimes, the set would always diplay something usually, and when they didn't it was one of anly a few things, sure there are always the horrid ones, and there are pleanty of those, but all in all it was quite easy. But with Digital Electronics, it either goes, or it doesnt, there are usualy few half measures. I mean thats the definition of logic either going or not. So it can take very little to completely paralyse a set, and generally give the only sysmptom, it can, by not working, usually No picture, or the like. So you, see the list is endless almost for any given SYMPTOM, as that is what is being seen, not the cause, as I keep going on about. Also any fault, usually involves the Power Supply, it is either the cause, the cause of the damage, or it is damaged. or ALL of them. Then after you have done the electronic repairs, you then must program the set to work, and align, and set up in general, any one of those settings missed or done wrong, back to square one.
So, it is nearly always my professional opinion that one should always get a "Quote" from the manufacturers recommended service center, I cannot stress how important that last point is. It is even worth the cost of shipping. you see an authorised service agent, will have trained staff, trained on their brand, also they have first hand access to parts, original parts. This will actually save you money and ensure you can actually get it back fixed. Of course asking for a "Quote" also gives on the option of repair or replace. Often my clients,do not go through with repair, unless it is moderate, but in some of the more costly jobs they see it, as do i, that a replacement, with a warranty, is a better option. As an aside here, one could then tear the TV down, and sell the Known Good bits. You'd be surprised who needs parts, i myself often must by from third party sources to effect a repair. So money could be recouped, somewhat,and help out someone else. Anyway thats my 10c worth.
Posted on Apr 25, 2010
    President:
  • 1,768 Answers
You may have a power supply issue.
the reset that you mentioned is for tech user on the board by using a test module.
This points to a repair at the board level in each case. A tech will be able to determine this with test where the issue is on the main board.
I hope this helps.
Rca HD61LPW42 -- we just replaced the color wheel. now we get a picture but only for a few seconds. then it turns off and after a few seconds restarts. this goes on indefinitely. a couple of times...
Hello
If the power light blinks slowly,
you've tried to turn on the TV during
the lamp cooldown cycle. Wait
approximately 30 seconds, and the TV
will turn on automatically.
If light blinks, pauses for about a
minute, and blinks again: the lamp is
trying to turn on (TV will turn on
when successful). If TV doesn't turn
on and sequence continues, the lamp also
needs to be replaced.
To order lamp call 1-800-338-0376.
Have your TV serial number
and lamp type available (you'll
find this information on the
sticker that's on the right side of
the TV).
OK.
Jul 24, 2011 | Televison & Video
I have an RCA HD61LPW42 tv and I would like to know how to change the color wheel
My RCA (model HD61LPW42,CHASIS ATC311M1) it make all programs funcions of channels but it dont sintonice the channels ,it receives audio and it cuts and nothing of video signal. i dont know if my problem is on the tunner or the dgital board , can you help me!!!!!!!!
Feb 13, 2010 | RCA HD61LPW42 61" Rear Projection HDTV
I'd like to know where I can get a replacement wire to connect the lamp ballast to the J4 input in my rca HD61LPW42 rear projection TV. I've gotten no response to an email I sent RCA a week ago. These...
hey mcd5brady, what was the solution to your last problem w the tv? ( replaced bulb and ballast but still no picture) my tv has same problem and dont know what to do next. any info on a solution would be greatly appreciated! post back or email. dellbino@aol.com
thanks
Jan 09, 2010 | RCA HD61LPW42 61" Rear Projection HDTV
No picture but sound
most likely the color wheel needs replacing.
Aug 08, 2009 | RCA HD61LPW42 61" Rear Projection HDTV
RCA HD61LPW42 - no picture
I haven't worked on an RCA DLP but have on Samsung DLP, based on your description it sounds like the color wheel is bad. Take the back off and turn on TV make sure its not a fan making the noise ,but most likely its the "wheel" it is inside the light engine probably right next to where the lamp is plugged in. If the whine comes from this area definitely the wheel.
Apr 26, 2009 | RCA HD61LPW42 61" Rear Projection HDTV
Wont turn on
light engine... lots of money... https://www.encompassparts.com/webwiz/wwiz.asp?wwizmstr=WEB.SEE&partnumber=5396908&smodel=HD61LPW42
Mar 19, 2009 | RCA HD61LPW42 61" Rear Projection HDTV
RCA HDLP 50W151 scenium color wheel
They make two different color wheels for the Rca DLP are you positive you got the right one. As usually its a straight forward install no adjusting needed. Post the chassis number off the back of your set and I will try to help you out with it.
Apr 07, 2008 | RCA HD61LPW42 61" Rear Projection HDTV
Color wheel and lens
if u are not a technician, better have it check by a qualified one. because doing so might create more problems. service center have special tools and equipment for aligning and replacing these stuffs. just concern
Jan 14, 2007 | RCA HD61LPW42 61" Rear Projection HDTV
Televison & Video Logo
Top Televison & Video Experts
