Question about Sony Playstation 3 (PS3) Console
Primary And Secondary DNS
I am having so much trouble setting my ps3 up onlie
can u tell me how i can find out my Primary And Secondary DNS ?
  • 1 more comment
  • Anonymous Mar 25, 2008
    when i try hooking up my ps3 the ip connects then i have a dns error what can i do to correct
  • Anonymous Mar 27, 2008
    go to start type command then type ipconfig /all but i am getting 3 dns numbers
  • Anonymous Apr 08, 2008
    hi i have a netgear router,i cannot connect ps3,it is failing on internet dns error?????any1 help
  • 21 Answers
Are you using a Cable Modem and a Router? I get problems like that when my Router is not working well. In which case I reset the Router (by unplugging it). Try connecting the PS3 straight into the Cable Modem, bypassing the Router.
Posted on Mar 25, 2008
Dns error
Power off your modem and then power it back on.
If this doesn't work you need reconfigure your PS3 network (regardless of wired or wireless) by using the manual option.
Enter the following DNS addresses: 208.67.222.222 or/and 208.67.220.220
The first set of numbers is Primary DNS
The next set is Secondary DNS
Mar 21, 2010 | Sony Playstation 3 (PS3) Console
I am trying to set up wireless internet with PS3 Keeps coming up with DNS error Any suggestions?
if you have established wireless connection on the PS3 then please assign static DNS on the PS3.
Primary DNS 4.2.2.2
Secondary DNS 4.2.2.1
Hope this helps.
Sep 23, 2009 | D-Link DSL-G604T Wireless Router
DNS error
you can get the dns setting by connecting a computor to the broadband the steps are
  1. goto 'start'
  2. goto 'run'
  3. type 'cmd.exe'
  4. in the commmand prompt type 'ipconfig' , it gives all the details about your broadband.
DNS error generaly means that there is nothing wrong with your system but ther must be a problem with your internet provider..
Aug 04, 2009 | Sony Playstation 3 (PS3) Console
Same problem as everyone else :"DNS error and some numbers"
Go to internet settings and manual set up then try these dns settings.
primary dns 4.2.2.2
secondary dns 4.2.2.1
~I find i dont always need to use the secondary one.
hope this helps :)
Jul 07, 2009 | Sony Playstation 3 (PS3) Console
Random DNS Error
You may need to manually configure your PS3 connection on the console. Let's see.. I can suggest to first go to your Settings Menu -> Network Settings -> Choose:"Settings and Connection Status List" this will display a pretty detailed information about your connection to your local gateway (router).. Check specifically for Primary and Secondary DNS. In my experience, using the PS3's auto setup for the connection seems to enter the default gateway's ip (labeled "Default Router" on PS3 Status Screen) in place of the real DNS entries..
Question
: Sooo how do you check your primary/secondary DNS for your network? Answer: On your PC, open a web browser and enter your default gateway ip into the browser.. log into your router (assistance can be found in your router manual or by calling your router manufacture). You should see a status page of sorts that displays your ISP's primary/secondary DNS entries.. Simply transfer those two IPs to your PS3 manually to correct the DNS issue.
Hopefully that should resolve your issue!
Jul 10, 2008 | Sony Playstation 3 (PS3) Console
PS3 says DNS error (80710102) when i try to connect to the internet with a wired connection
try this
So what I found out was to put in the IP address you find in ipconfig/all but add one to the last octive. Example if yours is 172.16.1.25... then in your ps3 type in 172.16.1.26
Then I was using the primary and secondary DNS numbers that my computer was giving me in ipconfig/all. Do not use those. For your primary DNS number use the number for your default which should be a right below your subnet mask number. For the secondary DNS number just leave it blank. 0.0.0.0
Then you have to upgrade to version 1.50 (which just came out yesterday actually). Get a memory stick with at least 100mb space on it. Make a new folder that is names PS3. Inside that folder make another new one that is called UPDATE. Both must be in capitol letters. Then go to PlayStation.com - PLAYSTATION®3 - Network - updates and click on "download now"... Then click save and save it to your memory stick in the UPDATE file, which should be in your PS3 file.
Then after all is done... plug that into your ps3 in one of the USB ports for the controllers. In the main screen go to SETTINGS and then go to SYSTEM UPDATE. Go to UPDATE VIA STORAGE MEDIA. PS3 will search for your media stick and it should say on the screen The latest update data was found... Version 1.50. Click OK and follow the rest of the instructions. After it is completely done... go back to the internet connection setup and go through all the menus to make sure all your numbers are the same as I stated above. Then at the end run the connection test. It should work!
Jun 24, 2008 | Sony Playstation 3 (PS3) Console
PS3
The way this was resolved for me (and I know someone else mentioned it in an other post here), was to enter the DNS server addresses manually in the PS3 network settings AND use tetertiary DNS server from my ISP as either the primary or the secondary DNS server. Voila... I am upgrading my PS3 software as I write this.... ..btw, this also fixed the similar problem I had with my PSP..
Jan 14, 2008 | Sony Playstation 3 (PS3) Console
Playing on line
Jan 13, 2008 | Sony Playstation 3 (PS3) Console
Ps3 hook up to the internet
I have a problem. I have everything hooked up and when i go for a connection test it says my connection has failed because there is an DNS error. What is a DNS? and what do i have to do to fix it?
Sep 08, 2007 | Sony Playstation 3 (PS3) Console
Sony Playstation 3 (PS3) Console Logo
391 people viewed this question
Top Sony Video Game Consoles & Games Experts
Zhenya Ogorodnikov
shaun taylor
juanmireles1
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
