Question about Rancilio SILVIAespresso&cappuccino machine
I recently cleaned my rancilio silvia by backflushing. However, I forgot to flush the system afterwards (the boiler was on) and I think the cleaning powder has baked somewhere and caused a blockage because no water comes through the group head. I can get water out the steam wand OK. Is there a product that will dissolve? Not sure just descaling will work because there isn't an end to end flow. Anybody got any suggestions how I can remedy short of taking the think apart?
2 Suggested Answers
  • 1089 Answers
SOURCE: no water through group head
Hi
More than likely your 3 way valve is stuck. It is located behind the front panel and when the 2 screws are removed it slides to the right. Unplug your machine before working on it. The 3 way valve is on the left and you can remove the dispersion tube on the bottom(unscrews) 14mm nut holds the solenoid on and you can slide the solenoid down the shaft. The big nut at the top of the shaft will unscrew and there you will fin the solenoid inside with a big spring. If its not stuck it will slide out and you probably need a new 3 way valve, but more than likely its stuck. Some times just tapping the nut on something hard will unstick the solenoid. Clean good and reinstall.
Posted on May 26, 2009
Brewer shooting steam instead of water in Rancilio silvia
Machine may be full of limescale and pipes are blocked... Do you know if the water in the area is Hard? Maybe it needs a descale cycle, although it may be too late for this. May need to open it up and clean out the boiler manually.
Feb 23, 2013 | Rancilio Silvia Espresso Machine
Rancilio Silvia coffee machine worked once and the
Remove the top panel one of the thermostats on the tank tripped, reset thermostat, and turn machine on.
Dec 25, 2009 | Rancilio Silvia Espresso Machine
Leaking between base stand and body
You are correct. There might be something keeping the solenoid from closing. Yes you husband should be able to fix it. Have him clean out the solenoid.
Sep 28, 2009 | Rancilio Silvia Espresso Machine
No water through group head
Hi
Jul 07, 2008 | Rancilio SILVIAespresso&cappuccino machine
Rancilio silvia espresso coffee machine
Esprosso Parts http://www.espressoparts.com/ sells all parts for the Rancilio Silvia, including some customized and modified parts.
Mar 29, 2008 | Rancilio Silvia Espresso Machine
Silvia
there are two class of expresso coffée: one produce crema and the other none. A 9 sec shot, means you are putting ground coffee that are way too coarse. The Silvia requires coffee grounf extremely fine, near powder texture.
Hope this help
Dec 28, 2007 | Rancilio SILVIAespresso&cappuccino machine
Rancilio silvia
Youve probably run your boiler dry and blown your thermostat/s. You'll need to have them replaced. You may get away with only having to replace one. It will cost about $80(AUS) to have done or less if you source the parts and do it yourself (not recommended).
Sep 08, 2007 | Rancilio Silvia Espresso Machine
Rancilio SILVIAespresso&cappuccino machine Logo
35 people viewed this question
Top Rancilio Coffee Makers & Espresso Machines Experts
vilhj
Level 1 Expert
Are you a Rancilio Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
