Question about GE Profile Spectra JGBP90 Gas Kitchen Range
My GE profile oven has the odor of lighter fluid. Any idea what causes this? The oven is not dirty. It's an electric oven with a gas range.
jsrock516
  • 5911 Answers
SOURCE: GE Profile Spectra JGBP85
Yes, it could very well be an igniter. The igniter can still glow and not work. The reason being that the igniter (depending on type) needs to produce .25 to .37 amps in order for the gas valve to open. If this potential is never reached, the igniter will glow, but gas will never flow. Or, gas will eventually flow for a weak (slow) igniter and will take forever to ignite. Which could be the reason for your low bake temperature. The burner does not stay lit all the time during the bake cycle. It will cycle on and off as needed to maintain the oven temperature. If the igniter is taking a long time to relight the burner, it could take a long time to heat. The broiler has a separate igniter and probably doesn't get used as often as the bake igniter. You can test the theory by swapping the igniter between the bake and broil burners and see if the problem moves to the broiler. Make sure you secure power to the range BEFORE attempting to remove the igniter, however. You should not have to turn off the gas to do this. Everything should be accessible through the oven door and broiler. I tell you this, because a new igniter (depending on the type you have) can run as much as $100. It will probably be worth the effort just to be sure. I hope this helps you.
Posted on Jul 15, 2007
buffalonyman
  • 1865 Answers
SOURCE: Oven digital display does not work after an electrical surge
You may want to put in a claim against the power company, a spike may have burned out the control board
Posted on May 05, 2009
SOURCE: Lower oven burner will not light.
Hi I have a older GE that the oven won't light. It is a gas range that is electric ignited. The top burners do work but the oven will not light. Is it pricey to have this fixed?
Posted on Jun 08, 2009
  • 23 Answers
SOURCE: The oven of GE Profile range simply stopped igniting
If it is a ge it would have a glow bar ignitor, either a flat rectangle shaped or a round ignitor. That is want the problem is 95% of the time. It is pretty easy to do. The floor of the stove will come right out and it probably has two screws in the back corners you can see. Remove them and the floor will lift out and you can see the burner and the ignitor.
Posted on Jun 20, 2009
MNTECH
  • 1543 Answers
SOURCE: My GE range and oven won't go on but the oven
Sounds like you are only getting 120 volts to the range. If your house has fuses, check for one of the 50 amp ones out. Best if you have a way of testing voltage. Could be a loose / poor electrical connection at the range power recepticle where the cord plugs in, or where the cord connects to the range. Of course it could be in the range wiring or possibly in the range control, but that is not as likely. Get a voltage meter and find out where you are loosing the other half of your 240 volts.
Posted on Sep 06, 2009
Gas smell when oven is on and heating.
This sounds like a gas leak at the gas control valve for the oven, probably somewhere just past the control valve. If the leak was before the valve, you would either hear or smell gas leaking all the time.
The line could simply be loose at the fitting or the gas valve could be faulty. You could also have a leak somewhere at or before the oven burner assembly.
At any rate, this condition can be dangerous. The oven gas leak (any gas leak) should be diagnosed by a competent technician and the cause(s) of the gas leak determined as soon as possible and corrected.
Jan 13, 2010 | GE Profile JGSP48 Gas Kitchen Range
When I use my gas range it smells like lighter fluid. Only when it is on, when off the odor goes away. It is a dual stove with electric oven and gas top. It started with one burner and now all 5 of them...
I am having the same problem with our stove in our new house. We just moved in and everytime I turn a burner on it smells like charcoal lighter fluid. Anyone know what this is?
Nov 14, 2009 | Kenmore Kitchen Ranges
Self cleaning oven
Three to five hours is the norm depending on how dirty it is.
Jul 28, 2009 | GE Profile JB968 Electric Kitchen Range
May 28, 2009 | GE Profile Spectra JGBP90 Gas Kitchen...
Apr 29, 2009 | GE Profile Spectra JGBP90 Gas Kitchen...
I have a GE Profile Gas Range with a double oven. The bottom oven takes 20 minutes to warm up to 300 degrees. Is this normal? I was told the bottom oven is electric, which I haven't used electric in years,...
my oven does the same thing. i do not believe that the oven is electric though. the only electric part on my oven is the control board. if the oven was electric it should heat up much sooner than that,
Apr 14, 2009 | GE Profile Spectra JGBP90 Gas Kitchen...
GE gas range igniter continues to spark, won't shut off.
Often times, just leaving the range unplugged for a time will solve the problem, which is most often caused by water or a cleaning agent getting into an igniter switch behind a burner knob. After the switch drys out it usually starts working again. In the mean time, you can still use the burners by lighting them manually with one of those long lighters, but you will not be able to use the oven or broiler without electricity. If the range continues to spark after being left unplugged for more than a day or two, you will have to determine which switch behind the burner knobs is causing the problem. Please don't bother rating, as anything but a Fix-Ya will lower my score. Thanks.
Feb 18, 2009 | GE JGBP28 Gas Kitchen Range
Ge xl44
GE XL44... Oven does not work. It was working just fine one day & then would not work. Everything else works fine. Stove has electric ignitiion. Could it be it is not working on the oven? Any ideas?
Jan 02, 2008 | GE Profile Spectra JGBP90 Gas Kitchen...
GE Profile Spectra XL 44 gas oven
If you can smell the gas when you turn on the oven, it may be on a separate igniter that has gone bad. I would check this first. If you are not getting gas to the oven, there is possibly an issue with the supply line.
Sep 25, 2007 | GE Profile JGSP44 Dual Fuel (Electric and...
GE Profile Spectra JGBP90 Gas Kitchen Range Logo
77 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Ismael Rodriguez...
 Fix Your Board
Fix Your Board
Are you a Kitchen Range Expert? Answer questions, earn points and help others
