Question about HP PSC 1210 All-In-One InkJet Printer
NOT PULLING THE PAPER THROUGH
Not pulling paper through
  • 4,041 Answers
Hello there
Please try yhis may work
This may work for you, it has worked for many here I given this advice so gave it a try it could work for you. Generally when this happens, something has fallen into the printer, or a piece of paper has been jammed in there.
First step, remove the ink cartridge, and turn the printer upside down and gently shake it, see if anything comes out.
If nothing goes, or you can't hear anything rattling around, get a piece of cardstock paper (60lb or heavier) and gently push this through the printer, to see if it will help push out what might be stuck in there.
And gave the rode that the ink slides on a good clean and maybe a bit oil on cloth and wipe the rod with it.
Also clean The purge unit, called a spittoon assembly in an HP, Lexmark, Caonon and other inkjet printers, is where the print head assembly parks when not in use, also its other job is to clean and make sure the print head is clean and open for printing.
That is where you'll find the print head assembly parked on top of it.
It also has an electrical pump to milk the print heads and test for ink flow.
So clean all under where the heads are parked and on IP6600D models you can take out the heads just by clipping them out, and then clean well.
Please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
All The Best: Pineworks
Posted on Apr 25, 2010
Mp495 Pulling one side before the other causing it to jam
The roller maybe sticky and cause the paper not to feed evenly. Clean the rollers with methylated spirits.
Mar 04, 2012 | Canon PIXMA MP495 InkJet Printer
Sharp F02950m not pulling paper
Does it give you a sound that it wants to pull a paper if so then the rubber like responsible for pulling the paper is dirty and needs to be cleaned with a properly wrung wet clothe.
if it does not give you a sound that it want to pull the paper then the problem is with the clutch or the solenoid in the pick-up system. one or both need to be replaced
Jul 14, 2011 | Sharp FO 2950M Plain Paper Laser Fax
I have a paper jam with a samsung CLX 3175FN. Can't get the stuck paper out! Turning on and off didn't work.
If the paper is jammed inside the machine follow these steps:
1. Open the front cover and pull the toner cartridge out, lightly pushing it down.
2. Remove the jammed paper by gently pulling it straight out.
3. After removing the jammed paper, make sure there is no additional paper in the paper path.
4. Insert the toner cartridge and close the front cover.
If the paper is jammed in exit are follow these steps:
1. Open and close the front cover. The jammed paper is automatically ejected from the machine.
2. Gently pull the paper out of the output tray.
- If you do not see the jammed paper or if there is any resistance when you pull, stop and go to the next step.
3. Open the rear cover.
4. Carefully remove the paper by pulling in the direction.
- If the paper tears, make sure that all of the paper fragments are removed from the printer.
5. Close the rear cover. Printing automatically resumes.
Nov 17, 2010 | Samsung Office Equipment & Supplies
My psc 1100 series paper jam. How i can fix
Hi
You need to switch off and unplug the printer. Now open the rear access door by pressing in on the left side of the access door and then pulling it toward you. Now check for any paper jams. From the rear access door opening, gently pull any jammed paper out.
Note-- All paper jams must be removed by pulling the paper out the back of the all-in-one using the rear access door. Pulling the paper out the front of the all-in-one rotates the paper feed rollers in the wrong direction and can lead to additional problems.
Reattach the rear access door by inserting the two pins on the right of the door into the holes for them, and then pressing in gently but firmly on the left side.
Daniel Scott
Jun 10, 2010 | HP Office Equipment & Supplies
Xerox XD120F copy machine not pulling paper through to make a copy. Might grab paper and then jamb.
If the paper is not pulling out of the tray, you should replace the feed rollers. They are easy to replace.
If it is pulling the paper about 2/3 of the way through the machine, you would most likely have a broken fuser heat roll gear, again cheap and easy to replace.
Feb 15, 2010 | Xerox WorkCentre XD120f Copier
Lexmark p6350,awful grinding sound when pulling paper into machine.also pulling paper too one side.
look to see if any paper is stuck... and pull it out... if no paper... then chances are you have a bad gear... call a service tech...
Dec 20, 2009 | Lexmark P6350 All-In-One InkJet Printer
When feeding my paper it keeps pulling the paper
You need to replace the feed rollers. One side is probably worn. You should be able to buy a rebuild kit for it. Try ebay.
Nov 02, 2009 | Lexmark X2600 InkJet Printer
Grabbing the paper pulling it in at the left hand side
1) Try to adjust lateral directing limiters for paper.
2) See attentively inside device no there stranger subject such as pencil or piece of the torn paper. Use the lighting of the lamp or flash-light.
Mar 06, 2009 | Canon PIXMA MP210 Photo All-In-One Printer
The rollers are not pulling paper through
- the roller not pulling paper through
- orange and yellow lights are flashing
Nov 02, 2008 | HP DeskJet 960c InkJet Printer
HP PSC 1210 All-In-One InkJet Printer Logo
85 people viewed this question
Ben Johnson
