How do you change a tail light in 2005 Buick Lacross I can not find a way to get into the bulb.
I have a 2002 lesabre and suspect it is the same. The light assemblies are bolted to the car from the inside of the trunk. Mine has three sections. Left side of trunk, across the back of the trunk and right side of the trunk. Open the trunk and look thru the small holes in the back for nuts that hold on the sections. They may require a deep socket to reach. Also not all the nuts need to be loosened. Trial and error. Once the nuts are removed the light assemble is freed from the car. Don't let it fall and scratch the car. The wires will help hold it in place. The light holders usually turn/twist and pull out. A little bit of a pain, but not too difficult. Again the deep sockets are probably required.
