Question about Fujitsu Siemens LIFEBOOK T4010D Tablet PC
A cleared bios
I have accidentally cleared so now my laptop does not respond, please help me to know how i go about it
  • JACOSPA Mar 23, 2008
    the bios is cleared so nothing appears when i switch on the laptop
    Genius:
  • 3,587 Answers
As I've mentioned a few times here..you'll need to load the bios from a disk, most likely a cd..by going to the link I sent you, and burning it into a cd..slide that into the computer, and restart it..
Posted on Mar 23, 2008
    Genius:
  • 1,913 Answers
Hi
go to bios go to cmos setup set time details.
and go to boot option set first device to hdd.
then save settings restart sys
  • kishor khatri
    kishor khatri Mar 23, 2008
    hi
    put away your lapaatop cmos cell from its case for 15 minutes then u get display my dear
I have a fujitsu stylistic q702 hybrid tablet notebook pic I forgot my bios password The computer will load up windows 8 but if I try to enter bios menu on startup I am asked for a password
I can't find a decent manual for your laptop but there will be 2 pins on the motherboard that will say BIOS Clear. Short these 2 pins and turn the computer on. This is the only way to bypass the BIOS password. This operation will clear the BIOS and reset to factory defaults. After the BIOS is cleared, turn the computer off and take off the short.
Jan 27, 2014 | Tablets & eReaders
I have a acer travelmate c110 and I am trying to connect to a wireless connection but the wireless switch is not on and I do not know how to turn it on. Please help.
There should either be a physical switch somewhere on the side of the laptop or by using the FN + a certain key to activate it. Look at the F keys for an image similar to wireless then try that. If the above does not work, its probably turned off in the BIOS. Access BIOS and turn it on.
Mar 28, 2010 | Acer TravelMate C110 Tablet PC
M4-s435 bios password removal
This information is intended for experienced users. It is not intended for basic users, hackers, or computer thieves. Please do not try any of following procedures if you are not familiar with computer hardware. I'll not be responsible for the use or misuse of this information, including personal injury, loss of data or hardware damage. So use it at your own risk.
A. By Using the Motherboard Jumper:
In most motherboards CMOS battery is soldered, which makes it difficult to remove the battery. In this case we use another method.
Almost all motherboards contain a jumper that can clear all CMOS settings along with the BIOS password. The location of this jumper varies depending upon the motherboard brand. You should read your motherboard manual to check its location. If you don't have the manual then look for the jumpers near the CMOS battery. Most of the manufacturer label the jumper as CLR, CLEAR, CLEAR CMOS, etc.
When you find the jumper, look carefully. There will be 3 pins and the jumper will be joining the center pin to either left or right pin. What you need to do, is remove the jumper and join the center pin to the opposite pin. e.g. if the jumper joins center pin to left pin, then remove it and join center pin to right pin. Now wait for a few seconds and then again remove the jumper and join the center pin to left pin.
Make sure to turn the PC off before opening the cabinet and resetting the jumper.
B. By Using Software:
I have found that BIOS/CMOS Password Recovery Tool is the most effective.:
BIOS/CMOS Password Recovery Tool is a program that works instantly to remove any lost or forgotten BIOS/CMOS password. Simply boot your PC to DOS and execute the program, and get access to forgotten BIOS/CMOS passwords in just seconds
BIOS/CMOS Password Recovery Tool Service: http://www.biospasswordrecovery.com/
Feb 16, 2010 | Toshiba Tecra M4-S435 Tablet PC
Got lifebook second hand its a p1120 i need to reformat windows but cant acsess bios i need to change password can u help
YOu can reset bios password with 2 method.
(1) open back cover of laptop then find motherbord .Pull cmos cell from motherbord for 15 minutes then again put it in it's position .then it not ask for password.
(2)You can clear password with jumper settings find jumper on motherbord named clear cmos it has 3 pin .1-2-3
Put jumper in 2-3 position then again put it in 1-2 position then check .
Let me know if you need more assistance.
Thanks.
Dec 19, 2009 | Fujitsu LifeBook P1120 Tablet PC
Password problems on a Toshiba Protege m200 laptop
If you cannot access the machine after if has been powered up, it is still possible to get past the BIOS password.
  1. The BIOS password is stored in CMOS memory that is maintained while the PC is powered off by a small battery, which is attached to the motherboard. If you remove this battery, all CMOS information (including the BIOS password) will be lost. You will need to re-enter the correct CMOS setup information to use the machine. The machines owner or user will most likely be alarmed when it is discovered that the BIOS password has been deleted.
  2. On some motherboards, the battery is soldered to the motherboard, making it difficult to remove. If this is the case, you have another alternative. Somewhere on the motherboard you should find a jumper that will clear the BIOS password.
  3. If you have the motherboard documentation, you will know where that jumper is. If not, the jumper may be labeled on the motherboard. If you are not fortunate enough for either of these to be the case, you may be able to guess which jumper is the correct jumper.
  4. This jumper is usually standing alone near the battery. If you cannot locate this jumper, you might short both of the points where the battery connects to the motherboard.
If all else fails, you may have to clear the BIOS password by resetting the RTC (Real Time Clock) IC (Integrated Circuit) on your motherboard.
Many RTC's require an external battery. If your RTC is one of this type, you can clear the BIOS password just by unsocketing the RTC and reseating it.
Good luck and more power
nicole
Oct 03, 2009 | Toshiba Satellite R15 Tablet PC
Don't know how to get rid of hard drive password on toshiba lapto
A hard drive password can only be removed by the person who knows the password because then it can be cleared thru the BIOS.
Otherwise the only other way around it is the buy a new hard drive so it doesn't have a password and you can then reinstall the operating system on the hard drive and then put the drivers on it and any other programs that you want on it.
Apr 07, 2009 | Toshiba Portege M200 Tablet PC
Toshiba Portege 3500 Win Xp Bios password - How Can I flash bios?
Go to your friend. Download and burn this cd http://www.9down.com/Hiren-s-BootCD-9-8-Keyboard-Patch-73110/
Boot your pc from it and use BIOS / CMOS Tools from it.
After that use the patch
Mar 08, 2009 | Toshiba Portege 3500 Tablet PC
Bios setup password
Hi!! Usually DELL Latitude or Inspiron passwords are storedi n eeprom memories that has to be read or writen to remove / bypass the BIOS password!!! Password generate a hash code that will appear after 3 wrong password attempts and it has a 5 digit decimal format "xxxxx" You can get the hash code by pressing F2 or F10 when you turn on the laptop to enter Bios and then when password prompt appears hit F12 to get the hash code.
You can generate a unlock code or master password with the service tag "xxxxxxx" 7 digit, this code appears at the password promtp screen or at the bottom of the laptop with a white sticker.
I got Latitude D620 Bios password Unlocked at http://www.laptoprebirth.com They can calculate a master password with the hash code. Hope it helps
Oct 27, 2008 | Panasonic TOUGHBOOK CF-18 Tablet PC
Fujitsu Siemens LIFEBOOK T4010D Tablet PC Logo
147 people viewed this question
Top Fujitsu Siemens Tablets & eReaders Experts
Martin Murray
Jason Morris
Lakshman P
Are you a Fujitsu Siemens Tablet and eReader Expert? Answer questions, earn points and help others
