Question about Maytag Neptune MDE5500AY Electric Dryer
One of the plastic pieces inside the dryer drum is loose. How do I remove the dryer top so I can tighten the screws>
    Scholar:
  • 126 Answers
OPEN THE DOOR. INSIDE THE OPENING ARE FOUR SCREWS 2 ON EACH SIDE. REMOVE THESE. EACH SIDE OF THE FRONT PANEL KIND ROLL OF FROM INSIDE TO OUT AT THE TOP. OR JUST PULL. BRING THE FRONT PANEL OUT TO A 45 DEGREE ANGLE. CLOSE THE DOOR AND LIFT UP ON THE FRONT PANEL. AT THE FRONT OF EACH TOP CORNER THERE ARE HOOKS HOLDING DOWN THE TOP. THEY ARE SCREWED IN PLCE WITH A 5/16 TH HEX HEAD SCREW. REMOVE THOSE AND THE TOP CAN LIFT UP.
Posted on Apr 25, 2010
    Habit-Forming:
  • 131 Answers
Frist all you need a t20 bit,an unplug dry to lose the screw on both side of the front panel they are locate when you open your dry door,take the screw out remove panel.there are 3 drum baffle, locate the screw that lose on the baffle,use a 1/4 drive socket N 5/16 socket to tight the screw on the baffle ok
Squeak coming from the rear center of the machine while running. Tempo of squeak is fast ... 4 per second. How do I get inside to tighten a belt or WD40 the drum wheel?
to remove the front panel, remove the four screw on the inside of the dryer, two on the left white plastic pieces, two on the right the door hinges, the hinges lift up and out once screws are removed, panel lifts off, you will see how the top is held down, two screws one on each side. Here is a web site that will help with the rest, Good Luck Tim
Oct 20, 2010 | Maytag Neptune MDE5500AY Electric Dryer
Inside the dryer there are 3 bars that stick out to help tumble the clothes. One of them has come loose and I'm not sure how to tighten it. It appears to be attached with screws that come thru the drum...
With the front off look up in the top left and right corners for some screws that hold the top of the dryer to the side panels. Depending on your model, there can be different styles. The old maytags used 3/8 in screws up inside the corners and the newer models had 5/16 screws right up front.
Once you get the front of the top loose you will be able to lift it like the hood on a car to gain access to the drum.
Rotate the drum by hand to put your loose fin at the top and tighten up your screws. Sometimes the screws will round out the holes on the drum too much and you may want to put a washer on the screw to secure it better.
Oct 07, 2010 | Maytag Dryers
Inside the drum, one of the metal things is loose. It appears that it is held on with screws, so they are probably loose. Could you tell me teh easiest way to access the outside of the drum so I can...
The top cover needs to be lifted to the rear of the dryer to access the outside of the drum and tighten the baffle screws. But before the top cove can be lifted, the front panel must be removed first. Disconnect power to the dryer prior to servicing to avoid the risk of electric shock.
Open the dryer door and remove the four screws located vertically along the inside lip of the door opening. These screws hold the front panel to the front shroud assembly.
Once the four screws are removed, grasp and press in on the upper edges of the front panel posts then twist it inward to release the clips holding it to the cabinet. Tilt the top of the front panel and move it away from the dryer.
The top cover is held on each side of the cabinet by two hold down brackets. Locate and remove the 5/16" hex-head screws holding each bracket then swing the bracket to the outside and unhook it from the slot in the top panel lip.
Open the door then lift the front of the top panel and tilt it toward the rear of the dryer.
Rotate the drum until the baffle screws are on top to tighten it. Reinstall the top panel and the front panel by following the removal steps in reverse order.
May 25, 2010 | Maytag Atlantis MDE7400AY Electric Dryer
Fin inside dryer drum loose and rattles can it be
get to out side of drum and tighten screws
Apr 25, 2010 | Dryers
The paddle has come loose inside my dryer how can I get the lid open to get to the back of the drum
take the 2 screws out of the door and take out the other 2 screws opposite the hindge screws,close the door,now grab the sides where you took the screws out of and pull forward and this will remove the front panel,take out the 2 top 5/16 screws one on each side that go through the metal holders,they are the screws closest top the top lid,remember how the holders hook into the top cover and the catch is in the middle of each piece,now lift the top and spin the drum so the baffle(paddle) is on the top and you can get at the screws to tighten them,the top doesn't lift to far up so you might have to lay down and tighten them from the floor,this is how i've done it ,hope this helps
Jan 21, 2010 | Maytag Neptune MDE5500AY Electric Dryer
Rattle inside dryer drum
remove the front cover and then you can access the top cover screws to open top then you can locate and tighten screws
Jul 27, 2009 | Maytag Neptune MDE5500AY Electric Dryer
Inside of drum baffles coming loose on maytag neptune dryer
Hello.
Remove the door and the plastic pieces on the opposite side. Take the front panel off. There will be one metal bracket on each side holding the top panel down. Remove those brackets and lift the top. Turn the drum where the loose baffle is up top and tighten loose screws or replace missing ones.
Jul 18, 2009 | Dryers
Money (change) caught inside interior drum plastic pieces.
Remove the top lid.
Rotate the drum until a vane is at the 12 o'clock position.
Remove the screws from the drum holding the vane in place.
May 10, 2009 | Kenmore 63942 Dryer
My clothes are catching between the drum and casing(?), the drum seems to be loose. My dryer is a GE profile/prodigy
suspect front tub support/bearing ring worn remove top by removing screws under front edge of top lift top 1 screw each side of front on inside front ring attaches to front panel look for worn plastic ring and pads
May 31, 2008 | Dryers
Maytag Neptune MDE5500AY Electric Dryer Logo
197 people viewed this question
Top Maytag Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
