Question about Poulan 42-Inch Steel Deck 17.5 HP Briggs & Stratton I/C Engine With 6 Speed
Deck belt keeps coming off - Poulan 42-Inch Steel Deck 17.5 HP Briggs & Stratton I/C Engine With 6 Speed
    Top Expert:
  • Poulan Master
  • 12,650 Answers
Check the pulleys and mandrels if any are loose or binding repair or replace as necessary check the alignment of the deck and drive pulley if the support bolts are loose or out of alignment tighten or adjust as necessary
Posted on Apr 25, 2010
STX46 belt keeps coming off the mower deck, John Deere
check to be sure the pulley isn't damaged. there should be belt keeps that help hold the belt on the pulley. be sure the belt isn't stretched and the deck is not damaged. be sure the belt is on correctly.
Aug 06, 2016 | John Deere Garden
Tensioner belt keeps slipping off front pully
Everett, Do you mean drive belt keeps coming off front pulley?
Possible causes, accumulated dirt/debris above deck or on trans axle, damage,stretched,wrong size belt, belt tensioner seized/missing spring if equipped, belt retainers/guides/keepers damaged /missing/ adjusted to far from pulley, damaged/worn pulleys, loose engine, belt way out of alignment,etc.
Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
What Are the Causes of Belt Coming Off Riding Mower
Drive belt keeps coming off when shift into reverse
Need help with mower deck belt keeps coming off Craftsman LT2000...
belt keeps popping off
Jul 20, 2016 | Garden
Toro 17-44 can't keep deck belt from coming off
is the deck adjusted level?is it the right belt?
Apr 23, 2012 | Garden
Cub cadet belt keeps coming off the deck
Link to see video of the Fix for cubcadet deck belt coming off can be viewed here: http://www.youtube.com/watch?v=Pd4nYovcnvY
Apr 21, 2012 | Cub Cadet Garden
I have a troy bilt pony and the drive belt to engage to blades keeps coming off. I have replaced the belt and the pully what else could it be?
well i would take a long look at the spring which holds the tension pulley in place. if it is weak, or not connected correctly, there will be inadequate tension and the belt can come off. I would also take a look at whatever fasteners keep the deck in place as if it is not kept to the rear, there again will be too much play in the deck belt.
Apr 05, 2011 | Troy Bilt 175HP Manual 42" Riding Mower
Replaced deck belt and it keeps coming off,whats wrong?
The belt tensioners on top of the deck need adjusted, or you make have to adjust the pulleys to tighten the belt. Sometimes if you have the deck lowered to low to the ground, uneven terain can cause that. If you have everything adjusted correctly, simply raise the deck another notch and mow.
Aug 09, 2010 | Yard Machines 155 Torque Briggs Stratton...
Why does the drive belt keep coming off?
This is usually caused by a stretched belt or a broken or disconnected bracket causing the deck to go out of alignment. Also check to insure your belt guides are in place (usually close to the pulley on the deck) they assist in keeping the belt in the groove, there should be two, close to the pulley.
Apr 28, 2010 | Poulan 42-Inch Steel Deck 17.5 HP Briggs &...
Have a 2006 145 automatic riding mower. Belt keeps
idler or adjustment pulley bearings worn allowing belt to ''run off''as it wobbles.stays on.check spring tension of idler.
Sep 20, 2009 | Garden
Deck Belt keeps coming off
I assume you mean the engine pulley by "front pulley"? Is the belt guide still in place? It bolts to the side of the frame and runs out to the engine pulley to hold the belt on when it's disengaged. Sound like your's may be missing/broken off
Jun 15, 2009 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Poulan 42-Inch Steel Deck 17.5 HP Briggs & Stratton I/C Engine With 6 Speed Logo
243 people viewed this question
Top Poulan Garden Experts
Roland W VanLue
Roland W VanLue
Phil Walker
Phil Walker
Are you a Poulan Garden Expert? Answer questions, earn points and help others
