Question about Casio G-Shock G7100D-1V Wrist Watch
Hi, I have a Aqua Starz #8028 watch and I dont have my manual. Its tiime is seven minutes fast and I need to change it to normal. How do you do it?
  • 299 Answers
Am....guys i want to know if my watch going 2 minutes back it will be forward after 28 minutes???and how can i fix it?? **its 2 minutes back 4 hours now.my watch is a jaga wr100m orange
You aren't making a lot of sense with this post either. This is a normal quartz watch. It isn't connected to a time server, so you need to correct it.
In the image, the watch says it is 9:41. If the correct time is actually 9:43, you advance it 2 minutes. You say 'back', but the better terms for a watch or clock are 'slow', or 'fast'. Your watch is 2 minutes slow, or two minutes fast? If the correct time is back, (the watch is fast) you need to advance 28 minutes.
Post here as a COMMENT, DON'T start a new post!
Feb 08, 2017 | Watches
I need to change the time on my nike wk0006 watch, but nike doesn,t sell it anymore...WHAT DO I DO!!!!????
TRY!
Make sure the watch is facing the correct way. Put the watch on your wrist as you normally would, or pick it up by the strap with your left hand. You should see that the Nike swoosh is right side up. You should be able to read the time.
Find the left side of the watch. This will be your left when the watch is facing you correctly the same way that you would look at it to read the time. You will see at least two buttons. One will be labeled "mode" and the other will be labeled "set."
Press the "mode" button. Press the "mode" button. Continue to press the "mode" button until you have scrolled through the options and are on the correct setting. The correct setting should be "time."
Hold down the "set" button. You should see the currently set time on your watch and the hour should be flashing. You should see a plus sign (+) and a minus sign (-). If your current time says three (for example) and you want to read five, press the button that corresponds with the plus sign. If you want to go backwards, press the button that corresponds to the minus sign. When you are finished hit next.
Change the minutes. Now the minutes should be flashing. Repeat step four: press the button that corresponds with the plus sign to increase the minutes. Press the button that corresponds to the minus sign to decrease the minutes. Hit "next" when you are finished.
Hit "done." Congratulations, you have now successfully set the time on your Nike watch. Now your watch should read the correct time. If you want to get really crazy, you can repeat the steps above to change the date on your Nike watch.
Sep 28, 2014 | Nike Triax WK0006-001 Watch
My Rolex watch is 15 minutes fast
is it manual or battery if batter replace it if manual windit up more
Dec 17, 2013 | Rolex Watches
Have Rado 193. am trying to sync analog and digital time. Manual says turning crown slowly adjusts minutes. Does not - only hours change
You can adjust the analogue hands without changing the digital ONLY when you have set the watch to 24hr fornat. Do this by going to the second Timezone screen (T2) and pressing the crown once briefly. If A or P appears, the time display is in 12-hour mode. If no letter appears, the time display is in 24-hour mode. To change mode, press crown briefly a second time.
Now go to the basic display where no digital info is shown. Pull the crown out. Now slow turning will adjust the minutes and fast turning the hours, but only of the hands. Therefore you can synchronize the two. After they show the same time, press the crown back in and adjust both times together using the crown as normal on the standard "Time" digital screen
Dec 28, 2010 | Rado Maxi R21347712 wristwatch
Need manual for g-force watch global atomic
Hi, Since you didn't specify the model or module number of the watch, try this link:
http://world.casio.com/wat/download/en/manual/
Take the four-digit module number from the back of the watch, enter it, and download a PDF of your watch setting-instructions.
I hope this helps you. Thanks, Bill
Sep 07, 2010 | Watches
Athletic wrist watch stuck in 24 hour mode
Maddening, isn't it? Fortunately the solution is here:
http://www.ehow.com/how_5593310_set-athletic-works-watch.html
1 There should be four buttons: mode, reset, start and light. Find the mode button and press it three times until it is in the set time mode.
2 Find the reset button, which usually is located on the bottom right side of the watch face, and hold it until the time starts blinking.
3 Press the start button to change minutes.
4 Press the reset button again to switch to hours.You will know it worked when the hour starts blinking instead of the minutes.
5 Press the start button to change the hour. The watch can handle two modes: standard and military. As you press start, the hour will change from AM to PM, noted by an "A" or a "P" in the top right. When you get through 24 hours, the watch will change to military time and an "H" will be displayed instead of "A" or "P." Keep pressing start to go through another 24-hour cycle and it will revert back to standard time.
Apr 30, 2009 | Watches
WATCH SET
For Timex sport 1440 indiglo
page through mode (bottom button ) til u get to time
When time shows up hold down lap/rst button on right untilset starts flashing
use mode buton at bottom to find element you want to change (let's stay minutes)
put st./stop button at top to get to number (minute) you want
hit lap/rst to get out.
Mar 11, 2008 | Watches
Casio G-Shock G7100D-1V Wrist Watch Logo
204 people viewed this question
Top Casio Watches Experts
Kazim ERGUNEY
Kazim ERGUNEY
Ansel Alberto
Ansel Alberto
Are you a Casio Watch Expert? Answer questions, earn points and help others
