Question about Jandy Lite 2 Natural Gas Pilot Light Heater
Model LG Lite 2 pilot is lit but the burners will not light. pressure switch is working corectly, on off togle switch is working, all wires are good(tested with ohm meter) what could be wrong?
  • 990 Answers
If this is a standing pilot you will want to check your voltage out put from the pilot. For this you will need a milivolt meter. The pilot should supply 500-700mv (1/2-3/4v) It only takes 200mv to open the pilot valve but needs another 300+ to open the main half of the gas valve. This would be the first thing I would check. If this is the problem you will need to replace the pilot assembly. If your getting the power you need from the pilot then it is probally your gas valve itself. Good luck.
Posted on Apr 25, 2010
Pilot light stays lit but burners do not ignite
check to see if pressure switch wires are tight and pressure to pressure switch then check safety circuit make sure wires to gas valve are tight
May 23, 2014 | Jandy Lite 2 Natural Gas Pilot Light...
Why won't the burners light if my pilot is lit
check safety circuit pressure switch should have 24 volts on both wires if not bad switch or copper tube plugged or loose wires to gas valve
May 11, 2014 | Jandy Lite 2 Natural Gas Pilot Light...
Raypak problem, Pilot is lit, can jump TH to TH to lite, goes out when jumper is removed.
check how many millivolts the pilot is generating. if pilot stay lit and burners wont fire u have a problem with one of the safties, lose wire connection, tstat control
May 28, 2013 | Raypak Pool & Spa
I have a lite 2 the pilot is lit but the bruners wont lite up
pump must be running. or filter is plugged. or pad pressure switch it's located on the plumbing inside of the heater and has 2 wires going to it., you might lightly tap it with a screwdriver LIGHTLY ! or just replace it there a fairly cheap item around $20
Jay the pool pump motor repair guy longwood fl
Jan 14, 2013 | Jandy Lite 2 Natural Gas Pilot Light...
Laars lite 2 pilot stays lit but burner will not fire
make sure pressure switch tube is not plugged see if both sides of pressure switch have 500 milliamps make sure gas is on
May 20, 2012 | Jandy Lite 2 Natural Gas Pilot Light...
Jandy lite 2 pool heater will not light main burner
make sure pressure switch is ok and the safety circuit if ok you might have a loose wire also check for cob webs
Jun 30, 2010 | Jandy Lite 2 Natural Gas Pilot Light...
Have pilot but burner will not start. Gas line is
There is an internal pressure switch for this unit that must sense water pressure before the gas valve solenoid is energized so that burner will light. If the air line to the pressure switch is leaking or has failed or is blocked it will not light at all. Additionally if you have had mice or smaller rats get into the unit, check the wiring to the pressure switch for any signs of damage. They can cause havoc! (Personal experience)
If you need further assistance please include your exact model number of your pool heater in your response.
Thanks for using FixYa.
Kelly
Jun 11, 2010 | Teledyne Laars Laars Lite 2 Pool Heater...
Pilot will light but main burner will not light
if burner lights after jumping valve you have something wrong in thermostat loop. disconnect the 2 thermostat wires on gas valve and use multimeter on continuity setting. if all wires ,connectors and components are good,you will get a tone.since you have jumped out each component in thermostat loop with no success ,i would suspect a bad wire or oxidation on a terminal .
Sep 24, 2009 | Teledyne Laars Laars Lite 2 Pool Heater...
Pool Heater Light main burner then goes out
take millivolt reads while main burner is on.i suspect you will see a drop in voltage until you get to point where it will no longer operate burner(around 200mv).if this is the case you probably have poor pilot characteristics due to dirty pilot,pilot out of adjustment ,obstruction or insufficient gas pressure
Jun 21, 2009 | Lite On Laars Lite 2 Heaters: 250,000BTU...
Pilot stays lit, but burners underneathe do not light up or burn.
Check pump is working, if so could be stuck flow switch or gas valve fault get unit serviced
Aug 31, 2008 | Lite On Laars Lite 2 Heaters: 250,000BTU...
Jandy Lite 2 Natural Gas Pilot Light Heater Logo
415 people viewed this question
Top Jandy Pool & Spa Experts
David Spradling
David Spradling
Craig Butler
Craig Butler
Jay Finke
Jay Finke
Are you a Jandy Pool and Spa Expert? Answer questions, earn points and help others
