Question about Sony Handycam DCR-DVD92 DVD Camcorder
When the AC/power adaptor is plug into the camcorder the light for charging does not com on and when I try to power up the camcorder it will not come on.
  • susanwolfe Apr 19, 2008
    I bought a new charger and have checked all connections. Problem persists. What's next?
    Guru:
  • 377 Answers
Hi dear
please, check your adapter first,
ok
Posted on Apr 07, 2008
SOURCE:
My sony handycam DCR-TRV340E is not charging at all, dont know if its to do with the battery or the AC power adaptor
First, check that the camera switch is in the off (charging) position.
If this is OK, Check the battery output connections for voltage: use a multimeter.
To check the charger, put a load resistor across the output terminals (about 1000 ti 2000 ohms) and again, using a multimeter, check there is a charging voltage. Alternatively, if the camera operates OK with the charger attached and switched on the charger is OK, AND, the problem is then in the charging circuit from camera to battery. If the battery checks OK as in the beginning, then you will need a Sony repair man who needs to know all the results from your testing above.
May 27, 2014 | Sony Handycam DCR-TRV340E Digital...
Just bought one 2nd hand, I can't find the charger input :-)
This camera uses a separate battery charger. It won't charge in the camera. As you didn't get the charger with the camera, you will have to obtain one. I found lots of them by searching for "DCR-DVD92 charger" on Amazon.
Nov 06, 2010 | Sony Handycam DCR-DVD92 DVD Camcorder
Sony handycam dvd92 battery warning light comes on even after battery is charged. bought new battery same problem
Yes the good old DVD camera, you like millions of others get this problem with that model, it is looking like DVD disk cameras have a 84% break-down problem, we need to get Sony to start to make proper cameras that use 8mm tape again, it is a media which does work well.
Jun 22, 2010 | Sony Handycam DCR-DVD92 DVD Camcorder
I have a sony handycam DCR-DVD92 NTSC camera. I
You need to download the onboard memory on to a memory card .
Jan 23, 2018 | Sony Handycam DCR-DVD108 DVD Camcorder
Camcorder won't charge up
Its problem of DC-IN jack where you hook ac charger. This jack needs to be replaced.
Let me know exact model of camcorder to provide you part number of DC-In jack.
Jan 17, 2009 | Sony Handycam DCR-HC24E Mini DV Digital...
Sony handycam DCR-DVD205: use new ac adapter or reinsert
Remove the battery insert your AC adaptor turn on your DVD CAM if it work fine reinstall the battery set CAM to off position the amber light should be on to indicate battery is charging
You got that msg depend what function you use if the CAM calculated the battery not enough to run or finish this task it display that msg for you to use AC adaptor to ensure no power corrupted such in formating the disc
Some time system control is faulty even you use AC adaptor it still display this msg I hope that is not in your case
Let me kown how you go with this problem
Nov 30, 2008 | Sony Handycam DCR-DVD205 DVD Camcorder
Finalize cd-rw on Sony HandyCam DCR-DVD92
hi dear
you can finalize your dcr in record position
going to disc manager find the finalize
and finish
oke
Mar 28, 2008 | Sony Handycam DCR-DVD92 DVD Camcorder
Sony DCR-DVD92 drive error
i have a canon camera with a similar problem.
it would not allow me to finalise unless the power adaptor was connected to the camera.
not sure if this will help you?
cheers, joe
Mar 08, 2008 | Sony Handycam DCR-DVD92 DVD Camcorder
Charging the handycam
Is the charger plugged into mains? If so, check that all the connectors are firmly attached, if you still have a problem, it may be your AC adaptor.
Dec 30, 2007 | Sony Handycam DCR-DVD108 DVD Camcorder
have you looked at sony's website?
http://esupport.sony.com/US/perl/model-tutorials.pl?mdl=DCRTRV19
Dec 11, 2007 | Sony Handycam DCR-DVD92 DVD Camcorder
Sony Handycam DCR-DVD92 DVD Camcorder Logo
160 people viewed this question
Top Sony Video Cameras Experts
Larry Stiles
Larry Stiles
Al Rush
Ekse
Are you a Sony Video Camera Expert? Answer questions, earn points and help others
