How do I set up a VCR to operate on my analogue TV. Everything I've looked at says 'refer to manual for tuning in the channel' but my manual doesn't tell me anything. Did have everything set up but something went wrong and lost all channels. Have since tuned in the TV channels OK
  • 1 more comment
  • jcee52 Apr 25, 2010
    I have a TEAC LCDV2250SD TV and an NEC VN-212 VCR
    My VCR is an NEC VN-212 and my TV is TEAC LCDV2250SD
    Sorry but still nothing happening. Don't worry I'll go and see my technician tomorrow. Thanks for your help anyway
    Brigadier General:
  • 6,966 Answers
Hi and welcome to FixYa,
Initially, it would depend on how the VCR is connected to the TV. If it is using a single coaxial patchcord, then it would be Ch 3 or 4 for US versions and a UHF channel for most European models. If an audio / video cable is used, then it would be an AV mode such as when RCA plugs/cables are used or even SCART.
Offhand, postback the brands and model numbers of the TV and VCR as well as how they are connected. It may not be a VCR issue as tuning is more of a TV concern.
Good luck and thank you for asking FixYa.
Posted on Apr 25, 2010
  • 1,512 Answers
Hi there
What model of VCR and TV do you have please. I need to know this to be able to assist you .
regards robotek
  • Graeme Ross
    Graeme Ross Apr 25, 2010
    To "tune in a channel" for the VCR on the TV, put in a tape and press play. Then set the TV into auto tune mode and it will "find" the channel that the VCR operates on and include that into your channel presets.
    Once you have the TV tuned into the VCR's particular channel, you can then (or they may already be there) tune in the TV stations on the VCR as well.
    You can also use the Video and Audio connections on the rear of each unit to connect them together using an RCA A/V lead( get from a TV retailer or electronics hobby store)
    • video out(yellow) on the VCR to Video IN on the TV(yellow as well)
    • Audio out(red and white) on the VCR to Audio IN on the TV(same colours)
    Then select AV on the TV and you have access directly to the output of the Video. Happy to answer any questions that you may have.
    regards
    robotek
How do I retune my Samsung smart TV 40"with 3D
Country (Area)
Broadcasting > Channel Settings > Country (Area)
Select your country so that the TV can correctly auto-tune the broadcasting channels. This depends
on the country or region.
When the PIN input screen appears,enter your 4 digit PIN number.
Digital Channel
Change the country for digital channels.
Analogue Channel
Change the country for analogue channels.
Manual Tuning
Broadcasting > Channel Settings > Manual Tuning
Scans for a channel manually and stores in the TV.
If a channel is locked using the Channel Lock function, the PIN input window appears.
This function depends on the country and region
Page 147 of this User Manual located on this page will give you more information. (Sorry it wouldn't let me link the PDF manual directly)
UE40H6240AK UE40H6240AKXXU Support SAMSUNG UK
Sep 09, 2014 | Samsung 40" 1080p 3D Slim LED Smart TV...
How do I get my Sky channel back on analogue after re-tuning freeview
Go in to analogue tuning. Tune just the analogue side of the TV.
Sep 05, 2014 | Televison & Video
The picture doesn't hold. The picture shows just snow on the tv.
VCRs are analogue. So their tuners won't pick up digital TV signals, and their output from the aerial socket is analogue too. You'll have to make sure your TV is on the analogue TV tuner and then tuned to the VCR output channel if you want to use the aerial connection for viewing. It's probably a lot simpler though to use the VCR's AV output to the TV.
If you connect a TV receiver (Aerial/cable/satellite) to the AV input on the VCR, then switch the VCR to that AV input, you will see and be able to record programmes.
Aug 25, 2014 | Televison & Video
I need instructions for hooking my VCR to my TV set,
using a scart cable, connect the tv socket on the vcr to the scart - in socket on the tv.
good luck.
May 10, 2011 | Philips Televison & Video
I have an older but operable Sanyo VWM-700 4 head hi-fi VCR to connect to an older but operable 13" TV just to watch workout video cassettes(via cable, no cable box necessary).How are the connections made...
You connect the Antenna to the VCR, you connect the AV OUT from VCR to AV IN on TV.(Yellow, Red & White) (Doesn't matter as long as color to color) Then you TUNE the VCR to the channels and the TV simply acts as a monitor. You must tune the TV to the OUTPUT from the VCR. If ya play a tape and look for the signal on the TV, to "Tune it in" to the VCR. first. then go to tuner.
Jan 26, 2010 | Televison & Video
HOW DO I CONNECT A VCR AND WHAT DO i SET THE INPUT ON.
If you have connected using the coax (aerial) ten the problem will be that the vcr is analogue and the tv is digital(if you have an older digital tv it should have an analogue tuner so you can set it to analogue and tune to the vcr) I suggest using a scart cable from the vcr to the tv, then you just press av on the remote(on some you can just change the channel down from 1 to the av inputs).
Jan 02, 2010 | Insignia 32" 720p Flat-Panel LCD HDTV
I am unable to pick up sky and set it to a position on analogue tv settings. The Tv is sanyo ce26ld90b.
If first we could ensure some connections are tight before moving into TV settings.
You have told me that you are using sky over an analogue connection. Make sure that these are plugged in at both ends (sky box and TV) and that your sky box is on.
Now using your TV remote, enter the TV settings (there should be a button for this specifically on your remote), and opt for Tuning and manual tuning. The layout for most TV settings are similar.
By manual tuning, you are able to select the number on which you want to view a channel (in the analogue case, Sky as a whole is considered one channel on your television)
Now you should be able to use the left and right keys on your remote to tune up and down a range of frequencies, one of which Sky will be on. Once you have found this frequency, you should store it to the channel you have selected.
To my mind, the only thing that would then cause this to reset is if you turn off your TV from the mains each time you finish using it.
Aug 23, 2009 | Sanyo Televison & Video
Sharp VCR vc-a41 tuning to TV
do you have cable? if yes both tv and vcr should be on ch #3 (to record).......ok no cable you are already set up look at tv right....just need to record..you need your vcr remote.....turn on vcr...press the menu...go to ch settings..auto scan will look for and lock in your channels...also make sure the air/cable selection is on air (unless connected to cable)....hope this helpful....feel free to rate
Oct 14, 2008 | Sharp VC-A410U VCR
How to tune an old Television
If you are in the US, the TV set has to be on channel 3 or 4, if your in the UK, the TV would have to be on a UHF channel. It should say on the RF output of the VCR what station you must tune to ,or in the instruction book of the VCR. Good Luck
Mar 25, 2007 | Philips 26PW6341 26" TV
Televison & Video Logo
44 people viewed this question
Top Televison & Video Experts
