Question about Dynex 4-Port 10 Mbps Ethernet Hub
Have to unplug and plug back in on 1 computer to running w/7.
On my new windows 7 Laptop, I have to unplug the E cable....then plug it back in to find my home network, or the hub.
  • 472 Answers
It can only be due to loose connection so try and change the cable first.
secondly, you can try to reset the hub and reconfigure it again
Posted on May 19, 2010
I got error on printer LBP2900 when connect to my laptop (windows 7) It show communication error but usb connection and software installation no problem. Any idea about it?
Most likely it is a corrupt software installation.
You can try the easy things first: 1) Unplug the USB cable from the computer 2) Reboot 3) Plug the USB cable back into the computer, see if the communication error happens again
If that doesn't work, time to reinstall the software: 1) Go to Control Panel > Add Remove Programs OR Programs (depending on which version of Windows you have) 2) Remove every piece of software related to your printer 3) Unplug the USB cable from your computer 4) Reboot 5) Disable any Anti-Virus or Firewall software that you have running 6) Re-run the printer installation software
Jul 04, 2011 | Computers & Internet
My printer is not communicating with my printer
If your printer connects through usb please do the following
Please do the steps if you are using windows
1: Switch off the printer . unplug the usb cable from the computer and printer
2: (For Windows Xp computer )
Now Click start > Control panel > Printers and faxes > delete all printers that shows here
(For Windows 7 computer )
Now Click start > Control panel > Devices and Printers > delete all printers that shows here
3: Plug the printer usb cable back to the printer and computer and switch on it.
4: Check whether your printer is detecting and installing . After the installation windows will give out a message " Your new hardware is ready to use"
5: (For Windows Xp computer )
Now Click start > Control panel > Printers and faxes > check whether a new printer is added here. If there try to take a print out.
Now Click start > Control panel > Devices and Printers > check whether a new printer is added here. If there try to take a print out
check it out.
Thanks
Mar 26, 2011 | Dell A940 All-In-One InkJet Printer
My dvd rw is not working.. i mean.. its not reflecting on my pc..
1) Computer off, and unplugged from power.
2) Computer on a table open the computer case
3) Observe Anti-Static Precautions.
4) Unplug the power cable (15-pin), and the data cable (7-pin) to the DVD-R/W drive.
5) Press the Power On button in, and hold it in for a count of Five seconds.
Let go of the Power On button.
Do this procedure TWO more times.
6) Plug the power cable, and data cable back into the DVD-R/W drive.
7) Close the computer case, and plug the computer back into power.
WAIT 1 minute, turn the computer on.
After Windows loads you should see a pop-up, "Found new hardware", and perhaps another one, "Found XXXX DVD-R/W optical drive"
Number 5 above clears the CMOS Error Codes out, and resets BIOS settings back to the factory default settings.
Unplugging the optical drive, (DVD-R/W drive) ,and performing number 5, kind of slaps BIOS around, and makes it recognize the drive is attached, and also Windows.
Makes Windows match of one of it's thousands of generic drivers for the DVD-R/W drive.
Oct 26, 2010 | LG GH22NS50 22X DVDRW SATA Drive OEM...
Dynex Easy Transfer XP to Windows 7 not working
Remove old drive from computer and install in new computer using ide ribbon. It will connect as a secondary unit and you can then using windows explorer transfer any data on old drive to new one.
Jun 19, 2017 | Dynex Computers & Internet
UPGRADE DRIVER FOR MAXTOR 3100 EXT HARD DRIVE
Probably not the right answer for your problem. Mine is an external 1 TB Simple Drive. Mine wouldn't respond at all. I unplugged the power cable from the back of the hard drive and replugged it in and instantly it worked (with the computer and hard drive plugged in). I had tried rebooting the computer, plugging/unplugging over and over into the computer and that didn't work.
Jun 17, 2010 | Maxtor Personal Storage 3100 (M01E100) 100...
I have windows 7 and downloaded windows live movie maker in order to put my home movies on DVD. I have a new firewire cable connect but when I go into "import from device" in the movie maker no devices are...
Try the followings.
1. Shut down the computer.
2. Start again.
3. Turn off the camera.
4. Unplug the firewire cable.
5. Open the camera.
6. Plug the firewire cable.
7. Try to use the software now.
I think it will work
Regards.
Apr 13, 2010 | Sony DCR-HC28E Camcorder
After a few minutes conected to the Internet I get an disconnectd running the network trouble sheeter I get the erro mesage that the network cable is unplugged or broken. I replaced the Ethernet cable and...
You might want to open up your device manager on your xp computer and click on network adapters and double click on your nic and copy down the settings under the advanced tab then do the same on the Windows 7 machine and change the values to the same on the Wnds 7 nic adapter.
Jan 28, 2010 | Dell Studio XPS Desktop Computer
Windows Vista not Booting Up
1) Press and hold the power button for 10 seconds to turn off the computer
2) unplug the power cable and remove the battery from the laptop
3) Press and hold the power button while the power cable is unplugged and the battery is not connected so as to discharge the computer
4) Place the battery back again and plug in the power cable.
5) Look for the F8 key on the keyboard.
6) Turn on the computer and start tapping F8. Do not stop tapping F8 until you get to a menu.
7) Use the up and down arrow keys. Highlight Safe mode. Press enter
8) Log in to system.
9) Do a System Restore to the date before you left the computer.
Mar 22, 2009 | Dell Inspiron 1720 PC Notebook
Netgear614 to compac pc laptop
hello!
-- who is your internet service provider
-- what is the operating system of your computer?
-- is this working fine before or is this a brand new router
you may try this and see if this help solve your problem
Step 1: Shutdown the computer.
Step 2: reset the router while power on then Unplug the router’s power cable.
Step 3: Unplug the Broadband modem’s power cable and wait for 30 seconds.
Step 4: Plug in the Broadband modem’s power cable and wait for its lights to appear stable.
Step 5: Plug in the router's power cable once the modem’s lights appear stable.
Step 6: Power on the computer on and configure the router settings Step 7: test the Internet connection.
May 04, 2008 | NetGear WGR614 Wireless Router
Ive installed xp on my acer travelmate 4100 laptop
hello!
Apr 22, 2008 | Acer D-Link 2.4GHz Wireless Router 802.11b...
Dynex 4-Port 10 Mbps Ethernet Hub Logo
162 people viewed this question
Top Dynex Computers & Internet Experts
Prashant M
Prashant M
micky dee
Are you a Dynex Computer and Internet Expert? Answer questions, earn points and help others
