Question about Whirlpool RF378 Electric Kitchen Range
Whirlpool range electric
Our range when plugged in and off the broiler element stays on??
  • Whirlpool Master
  • 43,501 Answers
Here is a tip that I wrote about that problem...
http://www.fixya.com/support/r4404788-electric_oven_problem_oven_will_not_shut
heatman101
Posted on Apr 25, 2010
3 Suggested Answers
SOURCE: electric range broiler element popped and burnt
Did you replace burnt fuse/tripped breaker?
Posted on Apr 09, 2009
  • 89 Answers
SOURCE: Broiler element stays on. I had to trip the
a wire in the back of your stove is grounded... open rear panel after unplugging and look for burnt wires going to the element. the wires will be a higher grade than most..
most likely there is no problem with the broil element itself, but the problem could possibly be located in the oven switch (if it is not digital)
Posted on Oct 09, 2009
Whirlpool Range #RF114PXSB , both bake and broiler elements won't go on
If the burners have the same problem check your power, it sounds like one of the phases is out. There is a common wire to both units, it is aparently open.
Aug 24, 2014 | Whirlpool RF114PXSB 30-in Electric Range
Whirlpool electric range oven broiler not working
Hello. This is a common failure for this range. Replace part number
9762215, price varies but about $100 average.
Apr 07, 2014 | Kitchen Ranges
Whirlpool Range model RF386PXGQ2 broiler won't shut off
Hi.
If the element does not turn off, possible faults are:
Shorted temperature probe.
Test temperature probe reading impedance. If impedance is zero or lower than 0.500 Ohms, the the probe is shorted. A good probe reads about 1KOhms.
Contact at element. A contact in element wiring harness may cause the element to stay on. Do continuity test between ground and element and on wiring harness.
Defective control module.
If problem is none of the above, then it is the oven electronic control(ERC). The ERC can be tested reading voltages.
Testing must be done by a trained technician.
Dec 13, 2011 | Whirlpool RBS305PD Electric Single Oven
Lower heating element will not heat up
check the element for continuity if there is continuty on the element then you need to replace the electronic control. you can also take the two wire from the bake element and move them up to the broiler element and try to turn on the broiler using the bake button this will confirm bad board or element.
make sure to unplug the unit will doing the wire change and then plug it back in
Mar 13, 2010 | Whirlpool RF365 Electric Kitchen Range
Oven erupted like a blow torch why?
The broiler element burned into. Look at the top element and you will see a spot where it is rough, melted or burned. Replace the element by removing the two screws at the back of the oven and pull the wire out a little and unplug the element and plug the new on it.
Dec 26, 2009 | Kitchen Ranges
Oct 09, 2009 | Whirlpool Kitchen Ranges
Broiler element won't heat. oven won't hold
check the broiler element for "Hot-Spots" where its dis-colored and is ready to break
Oct 07, 2009 | Whirlpool RS696 Electric Kitchen Range
Broiler element Whirpool Accubake electric oven not working
Hello
Welcome to Fixya
My name is Huum,
You need a new top element
http://www.pcappliancerepair.com/model-display.php
You can find the diagrams,schematics, and parts for your range at this site
Please remember to leave a rating before you leave
Dec 11, 2008 | Whirlpool RBS275PD Electric Single Oven
Whirlpool RF378 Electric Kitchen Range Logo
108 people viewed this question
Top Whirlpool Kitchen Ranges Experts
Dan Webster
Dan Webster
Ismael Rodriguez...
Are you a Whirlpool Kitchen Range Expert? Answer questions, earn points and help others
