My Sony Grand Wega KDF-E60A20 purchased in 2007 keep going off for 15-20seconds then return to nl screen for a few minutes then repeat dark again. Any suggestion?
  • 10,594 Answers
Its time for new lamp as current lamp is reaching to an end of its working life and causing these symptoms.
Lamp replacement procedure is written in user manual and its easy.
Please buy Sony original lamp for good picture in tv.
Hope this info will help you, let me know if you have additional question.
Thanks.
Posted on Apr 25, 2010
While tv is on, at times screen just blacks out ...then comes on again.....audio remains but picture fades in and out....often
Replace lamp in tv because symptom shows lamp is near to end of its working hours life and causing that problem.
If lamp has not been replaced in tv in last 2-3 years, its time to replace it to solve the issue.
Lamp replacement procedure is easy and written in user manual.
Thanks.
Aug 29, 2010 | Sony KDF-E60A20 60 in. LCD HDTV
I have a Sony WEGA KDF-E60A20 for 4-5 years. A few mintues after i turned it on, the screen goes blank with no sound. It comes back after 1-2 minutes. It goes blank again after 2-3 mintues. It just keeps...
It's the lamp. I do have an article on this in my Tips & Tricks regarding lamps, but replacing the lamp is a sure fix. I hope this was helpful, best wishes.
Apr 29, 2010 | Sony Grand WEGA KDF-60WF655 60" Rear...
Sony KDF-42WE655. Screen goes dark.
Replace your lamp if you had it more the 3 years.
Nov 08, 2009 | Sony Grand WEGA KDF-42WE655 42" Rear...
I have a Sony WEGA KDF-E60A20 the screen goes dark with no sound intermittently. Will replacing the lamp solve the problem?
i have the same problem and i am finding out that the lamp replacement is the problem but make sure when replacing bulb to wear latex gloves and clean all of the dust out of the tv to extend the life of the new bulb. hope this helps
Oct 12, 2009 | Sony Grand WEGA KF60WE610 60" Rear...
KDF-E60A20. Picture and sound go off for a few seconds, repeats
It was as simple as replacing the lamp. It took just minutes and the TV works like new. I had to adjust he picture for the increased brightness level.
Oct 11, 2009 | Sony KDF-E60A20 60 in. LCD HDTV
Sony 60" Grand Wega has Picture go BLACK and NO SOUNDS!!!
My Sony Wega KDF-55XS955 55" was going on for 1-2 minutes then going black with no sound and after a few minutes would come back on. After reading all the posts and talking with a repair guy I replaced the bulb and that fixed the problem.
Aug 24, 2009 | Sony Grand WEGA KDF-55XS955 55" Rear...
Picture is dark
Adjust video settings:
  1. Press Wega Gate
  2. Select Settings
  3. Highlight Video
  4. Press + to select
  5. Adjust/increase the brightness.
  6. Press Wega gate to exit.
If picture is still dark, you need to replace the lamp again. Sony recommends that you replace the lamp:
  1. After approximately 8,000 hours of use.
  2. When the screen becomes dark or the color becomes unusual.
  3. When the lamp indicator on the front of the TV flashes.
Aug 22, 2009 | Sony Grand WEGA KF60XBR800 60" Rear...
I have a sony grand wega model# kdf-e60a20. the picture is dark and I have changed the brightnes settings on my tools, but it has not fixed the dark pictures. can you poss tell me what is wrong
sir,
do u have manual? refer the manual of last page it give some trouble shooting tips..apply it and check. if it not worked if u have warranty call the customer care of your televison.
also check this link
thanks
good luck
Dec 13, 2008 | Sony KDF-E60A20 60 in. LCD HDTV
KDF-E60A20 Going on and off by itself..no blinking lights
it works!! First i took off the front panel. Just check your manual for instructions, very easy to do. If you do not have a manual just down load one from google.. The instruction are easy to follow. The screw they have you loosen with a alan wrench is attached to the plastic, so you do not have to worry about dropping it inside the tv. Removing the lamp was simple. once out you will notice on either side are two small mesh screens. One of mine was 80% blocked with dust, the other side was only 30-40% covered. I used a vacuum to remove the blockage, i did not want the dust and dirt to go inside the bulb. i then cleaned all around the lamp. Reinstalled, and we are go to go. The kids are happy and i am happier since my wife not be buying a new TV.
total cost of repair $.00
time required to fix, less than 15 minutes.
Also when my TV was loosing sound and picture and then return. I did turn off my TV, then turned on. I nothiced a red blinking light. Mine flashed 5 times. After some reserch, 5 times is video related, bulb or video board. google red flashing light with the model you have and you will find what all the codes mean.
So if yours is flashing 5 times try the above, it might work for you and it is well worth the time before you call a tech and drops hundreds of dollars.
hope this helps.
Dec 05, 2007 | Sony Grand WEGA KDF-60XS955 60" Rear...
Televison & Video Logo
156 people viewed this question
Top Televison & Video Experts
Electro Med Services...
