Question about Philips Magnavox MCS225 17 Radio/Cassette/CD Boombox
How do I record a cassette on my Philips Magnavox?
2 Suggested Answers
  • 814 Answers
SOURCE: Dont know how to finalize dvd after recording on magnavox vcr/dvd
You can find a copy of the manual on the web link provided here:http://tv.manualsonline.com/manuals/mfg/magnavox/mwr20v6_1.html Print a pdf copy for yourself. If you need more help the customer care for you dvd/vcr player is at this telephone number. 1-800-605-8453 give them the model number of your dvd/vcr unit and they will be able to help you. I hope this information helps you with your problem.
Posted on Jun 02, 2009
DVDR/VCR Combo_ZV450MW8a. When I insert the VHS cassette...
Had the same problem. took cover off, cleaned the recording heads. Also look on the left and right of casett chassie.You'll see to thin green strips sticking up with a black elctronic device. Chech to see if it is aimed at the clear plastic pin near the little black plastic gear in the middle. mine was out of alignment on the left one. Works know. Good luck
Jan 24, 2010 | Philips Magnavox MWR20V6 DVD Recorder/VCR
How do you fix a dvd player to record
Hi
A DVD player cannot be fixed to record unless it is a DVD recorder. If your problem relates to recording DVDs on your VCR dual player i.e you want to record DVDs on to a Video cassette please do clarify the information and we will be happy to assist.
Thanks for using FixYa.
Sep 26, 2009 | Philips Magnavox DVD/VCR Dual Player
How do I connect the Magnavox to my cable?
If you are talking about the Magnavox ZV427MG9, this unit is a Digital Video Disc Recorder and Cassette Recorder. There are no connections for the RF cable (analog) that is normally connected to the back of the TV from the cable company or satellite receiver. However, you can use RCA connectors, S-Cable and other cables to connect to your TV if your TV has these types of IN and OUT connections available. Most TVs made in the past 5-7 years have these types of connections.
Aug 14, 2009 | Philips Magnavox DVD+R/+RW Recorder/VCR
May 10, 2009 | Philips Magnavox MWR20V6 DVD Recorder/VCR
Recording from a vhs cassette...
This dvd/vcr unit is having a problem with component failure. It is probably in the main power supply section, since the unit shuts down. This can happen in these products due to the qulaity of component use in the product runs. The components usually have 5% to 10% failure rate. Which is usually taken care of by the product warranty. Unfornately this is a common problem with big manufactuers and large production runs. You need to have the unit tested and serviced at a service center. The service center will have all the service information to repair you unit. The Magnavox Customer support telephone is 1-800-605-8453. Tell them the model number of you unit and about the problem with the unit shutting down during use. They will be able to tell how to your unit serviced. I hope this information helps you with your problem.
Light for timer does not come on
Remember that you have to insert the cassette or the balk Dvd after set up the timer, if this is a cassette, remember if don't have broken the small piece that prevents to erase it. If everything is Ok, make shure in the recording program process that if there is a final instruction like "confirm" or "done"
Nov 10, 2008 | Philips Magnavox DVD/VCR Dual Player
My vcr won't play back
I have a Magnavox zv457mg9 DVD&VCR combo ,and the vcr records for a short period(10minutes) and then cuts off. This happens each time I try to record on the VCR. Any suggestions??
Feb 26, 2008 | Philips Magnavox MWR20V6 DVD Recorder/VCR
Viewing a recorded DVD+R on PC
I am assuming you have an actual dvd drive of some sort installed in your computer. The problem you may be having is a missing codec. This problem can be solved by downloading a VLC player which has most needed codecs pre installed. This program is freeware and can be easily found online. I hope this helps. Good Luck!
Jan 28, 2008 | Philips Magnavox DVD/VCR Dual Player
Philips Magnavox MCS225 17 Radio/Cassette/CD Boombox Logo
44 people viewed this question
Top Philips Audio Players & Recorders Experts
Gyula Lacz
Are you a Philips Audio Player and Recorder Expert? Answer questions, earn points and help others
