Pc starts up and shuts down repeatedly and no video
Just installed a supermicro P4sct ll w/3.4ghz cpu and 4gb pc3200 400 ecc memory, connected are the IDE drive and everything was a snap. after pushing start button, pc runs for 15-20 seconds and shuts down then reboots again and again, no screen to go into setup and no beeps of any kind.Tried using a single stick of ram and tried every troubleshooting technique, I can't see where it may be short circuiting, if you can help, must appreciated.
    Sergeant:
  • 349 Answers
First be sure that the ram (ecc)you have purchased is compatible with your motherboard and that it will take a total of 4 gig,make sure you earth yourself out on the case before going inside the pc (static electricity can damage electronic components)check that you have not accidentally loosened any data or power cables, check cpu & fan is seated correctly and working : then
  • put back the old ram and try booting up,(if still no good),
  • put things back to the way it was before the changes,
  • make sure everything is working as before (refer to the above)
  • trying the new ram, if ok
  • change cpu
  • this will identify if it is the ram the cpu, or some other problem
it is a good idea when upgrading the pc to do one thing at a time so that it is easier to identify any problems that crop up.
let me know how you get on
good luck
Terry
Posted on Mar 25, 2008
When i put 2Gb of ram..My PC keeps shuting down...is there any fix for that!?!?!?! Please help me
Every pc/laptop will only accept a certain amount of memory. Your probably overloading it. Check in your system info to see how much it can take. Also, make absolutely sure that you have the right memory stick for you pc!
Mar 21, 2014 | Acer Aspire E500 PC Desktop
My laptop is too slow even if i am just surfing internet like FB. can the memory be upgradable? up to how many gb?
you can upgrade up to 2GB (DDR2)
Your computer has 1 memory slot you remove the memory and install a new one.
you can use either
2GB 800MHz DDR2 Non-ECC CL6 SO DIMM
or
2GB 667MHz DDR2 Non-ECC CL6 SO DIMM
Jun 22, 2011 | ASUS Eee PC 1000H Laptop
P4vp-mx can support dual core proscessor, 2gb. ram and 512 video card
http://www.asus.com/Motherboards/Intel_Socket_478/P4VPMX/#specifications
1 x AGP 4X (0.8V, 1.5V only) (graphic card AGP)
Memory 2 x 184-pin DIMM Sockets support max. 2GB PC2100/PC1600 non-ECC DDR SDRAM memory
Memory 2 x 184-pin DIMM Sockets support max. 2GB PC2100/PC1600 non-ECC DDR SDRAM memory 2 x 184-pin DIMM Sockets support max. 2GB PC2100/PC1600 non-ECC DDR SDRAM memory
and if you click on the CPU Support List you see that it does not support Dual core processor :(
May 06, 2011 | ASUS P4VP-MX Motherboard
Hyhcan i fit a bigger processor to the asus K8V-MX Motherboard and more ram
Your motherboard can take any AMD Athlon CPU (this does not include the newer multi core or Athlon 2 CPU's), as well as up to 2 gigabytes of DDR400/333/266, ECC, non-ECC, un-buffered memory. That memory has to be split between 2 dimms as the motherboard will not work with a single dimm of that size. Also, ensure that when you do put memory in that the 2 memory sticks are exactly the same.
Mar 17, 2011 | ASUS K8V-MX Motherboard
I added 2x4G mem to the Asus M4N98, but the computer doesn't see it. Help?
Here is the memory spec for your board
4 x DIMM, Max. 16 GB, DDR3 2000(O.C.)/1333/1066 ECC,Non-ECC,Un-buffered Memory
Dual Channel memory architecture
*AMD AM3 100 and 200 series CPU support up to DDR3 1066MHz
**Due to OS limitation, when installing total memory of 4GB capacity or more, Windows® 32-bit operation system may only recognize less than 3GB. Hence, a total installed memory of less than 3GB is recommended.
***Refer to www.asus.com or the user manual for the Memory QVL (Qualified Vendors Lists)
Feb 11, 2011 | ASUS M4N98TD Socket AM3 Nforce 980a SLI...
Sony pcv rx550 beep codes?
Hi , here are the codes. listen closely.
Beeps
Error Message
Description
1 long, 2 short Video adapter error Either video adapter is bad or is not seated properly. Also, check to ensure the monitor cable is connected properly. Repeating (endless loop) Memory error Check for improperly seated or missing memory. 1 long, 3 short No video card or bad video RAM Reseat or replace the video card. Repeating High/Low
CPU Either the CPU is not seated properly or the CPU is damaged. May also be due to excess heat.
Check the CPU fan or BIOS settings for proper fan speed.
Phoenix BIOS beep codes
Beeps Error Message Description 1-1-2 CPU test failure The CPU is faulty. Replace the CPU. Low 1-1-2 System board select failure Replace the motherboard. 1-1-3 CMOS read/write error The real time clock CMOS is faulty. Replace the CMOS if possible. 2-x-x RAM failure Replace the RAM module if possible. 3-2-4 Keyboard controller failure The keyboard controller has failed. Replace the IC if possible. 3-3-1 CMOS RAM power bad Replace the CMOS battery or CMOS RAM if possible. 3-3-2 CMOS configuration error The CMOS configuration has failed. Restore the configuration or replace the battery if possible. 3-3-4 Video memory failure There is a problem with the video memory. Replace the video adapter if possible. 4-3-1 RAM test failure System RAM addressing circuitry is faulty. Replace the motherboard.
Good Luck
Mark
Sep 17, 2009 | Sony VAIO Digital Studio PCV-RX550 PC...
hi
i think your memory timingg pro.if u hace two ram in your pc then try just one ram.
ccheck your motherbord dont touch the cabinet.
also check power cable, smps.
scan your pc with quick heal , avast and symantec antivirus with update definition.
i think most of your ram problem.check your single ram.try this.
Mar 22, 2008 | Computers & Internet
Silly question perhaps...
Ooh! That motherboard uses RIMMs, not regular DDR memory. And you'll need a matched pair to get it to fire up and permit access to the BIOS. Checking eBay I see you can get a pair of 256 MB modules for less than $10, so your curiosity won't cost you too much.
Sep 22, 2007 | SuperMicro P4DCE+ MOTHERBOARD
Computers & Internet Logo
150 people viewed this question
David Payne
David Payne
