Question about Toymax Magnavox 37MF331D 37 in. LCD TV
When I press power, light blinks for about 15-20 minutes, then goes off. Press power again, on solid for 30 seconds, then goes off. Press power again, TV finally comes on.
    Problem Solver:
  • 15 Answers
Your television is in need of repair. Hard to tell what exactly needs to be repaired but when the power light blinks in that way then this is the TV's way to tell you it needs to be serviced.
Posted on Apr 25, 2010
Posted on Jun 02, 2010
Replaced lamp on mitsubishi wd62527 worked for 10 minutes then shut down. Now red lamp light is on
If the red indicator light on the front of your HDTV is glowing a solid red, you should first unplug the AC cord from the wall power outlet and wait for 60 seconds before reapplying power to the HDTV.
After you turn the TV on, if it doesn't power up, try holding the power button down for at least 8 seconds. That's supposed to force a system reset. If your model has a system reset button, use that instead. Press the reset button for about 20 seconds...release it and press it again for 20 seconds, release it again and the led will blink just for a minute or two. You should now be able to turn the TV on.
If after several attempts, the HDTV has not fully powered on and the LED on the front of the HDTV is still glowing solid red, you may want to reseat the lamp.
If reseating the lamp has not resolved the issue then your next step is to order a replacement lamp.
Apr 05, 2015 | Mitsubishi Televison & Video
My Linksys Wireless G Light is not on
Is the power light on the router blinking ?
If the power light is blinking and the WLAN light is not lit up then you will need to reset the router.
There is a small reset button on the back side of the router, where you connect the cables.
Press it and hold it down for 30 seconds. You will need a pen or paper clip.
Release the reset button and wait for 1 minute. Make sure that the power light willl be solid on the router.
Once the power is solid and steady, unplug the power cable of the router. wait for 5 seconds and plug it back in.
When you reset the router, it will come back to the factory default settings and you will need to set up the router again.
Click here for step by step instructions to set up the router.
Oct 03, 2010 | Linksys Wireless-G WRT54G Router
Power indicator is blinking and wireless netwok name disapreered and cannot connect
You said that the power light is blinking. The chances are your router is not workikng more.
Try to reset the router. P{ress the reset button on the router.
Release the button and wait for 1 minute. See if the powerlight becomes solid. If the power light is still bliking then reset the router again.
Once the power light is solid on the router then try to reconfigure the router from the beginning.
Click Here for step by step by instructions
Jul 12, 2010 | Linksys Wireless-G Broadband Router
I am not able to pring out labels , it sayse "error condition ribbon out and then Printer Idle V60.13.0.13Z The power light is green and solid the error light is blinking the check ribbon light is on solid...
The printer thinks it is out of ribbon. If the condition exists and there is still ribbon in the printer, then try pressing the CALIBRATE key to have the printer readjust for the label / ribbon. If that does not help then press the SETUP key, press PREVIOUS until you see a setting called RIBBON LED. Make sure there is a value there - should be somewhere around 30-40. If it is above 100, then lower the setting to 30. Then press SETUP again and press SAVE for a permanent save.
Hope that helps !
Apr 24, 2010 | Zebra 110Xi III Plus Thermal Printer
Router/power light constantly flashing cannot make any connection to computer
try to reset the router. On the router you will find the reset button. press it and hold it down for 30 seconds. release the reset after 30 seconds. wait for 1 minute. unplug the power and plug it back in. wait for 1 minute and check if the power light stays solid.
If not then try to reset the router again.
check the IP address on the computer. If you are getting a valid IP address then try to open the set up page of the router.
If you are not getting the valid IP address and power light is not solid then I think you will need a new router.
Click here for more information about the router
Mar 09, 2010 | Belkin (F5D7231-4) Wireless Router
I need the codes to program my Innovage Jumbo Universal Remote for Dynex television
As there are no specific codes for the Dynex TV you have the choice of either using the Auto or Learn method. The following are instructions for both:
AUTO Method
1. Press & Hold (about 3 sec.) the [DEVICE] button on the JUMBO Remote....llight will stay solid.
2. Now just press the [POWER] button (only) ONCE while pointing at the device...it will start sending codes approximately every second. (Don't keep pressing the power button as instructions indicate.)
3. TIMING IS EVERYTHING HERE. (It may take 5 minutes to find your devices code.)
4. AS SOON AS the power goes off...press the [ENTER] button on the JUNBO Remote.
5. Now pressing the [POWER] button should power up/down the device.
---- any buttons not programmed will have to be handled using the LEARN method ---
LEARN Method
1. Press & Hold (about 3 sec.) the [DEVICE] button on the JUMBO Remote....it'll stay solid.
2. Press the [LEARN] button on the JUMBO Remote. (light will immediately blink rapidly.)
3. Now Press the {NEEDED} button to program. (light will stay solid)
4. Now (1 to 2 inches away) have the ORIGINAL Remote pointed at the JUMBO Remote and press the {DESIRED} button on the ORIGINAL Remote.
5. It blinks rapidly while sending...then a slower steady blink once "LEARNED" correctly.
*** Not all buttons work properly with the "LEARN method". Some you will need to "associate" with an alternate button on the JUMBO Remote. *
Mar 02, 2010 | RCA RCU600M Remote Control
WRT610n router power led light blinks and i cant
If the power light is blinking on the router , then it might not be working properly.
You will need to press the reset button on the back side of the router for 30 seconds. release it. unplug the power cable. plug it back in. wait for a minute and check if the power light is solid.
do the same thing and check if the power light is solid.
If the power light is solid then you will need to set up the router again.
If the power light is still blinking, then connect the computer to the router and check the IP address on the computer. If the IP address is 192.168.1.100 then try to open the set up page of the router and check the settings of the router.
Click Here for step by step instructions
Dec 01, 2009 | Linksys WRT610N Wireless Router
Reset password for linksys wireless-g router
Press and hold the reset button for 60 seconds, after you release the reset button wait until the power light stops blinking. If it does not stop blinking, then unplug it for 30 seconds and plug it back in. After that type in at the address bar, 192.168.1.1
Feb 08, 2009 | Arris SURFboard SB5101 Cable Modem
All lights blinking
Try:
1. Power Unit off
2. Open front cover
3. Press and hold GO and turn power on
4. When all 3 lights lit release and press GO twice
5. All lights turn solid
6. With all solid, press GO 5 times
7. Ready light GOes red
8. Close door and you're all set
May 05, 2008 | Brother HL-2040 Laser Printer
Toymax Magnavox 37MF331D 37 in. LCD TV Logo
798 people viewed this question
Top Toymax Televison & Video Experts
matt martin
matt martin
Paul
Are you a Toymax Televison and Video Expert? Answer questions, earn points and help others
