Question about Tomtom GO 710 Car GPS Receiver
Unit turns on but displays the symbol of pulling out the card and a red X goes over it. After a few cycles of this display it shuts off.
  • 1 more comment
  • bwrunge Apr 25, 2010
    The card is in the GPS while this is happening
    Reset button is reset, memory card is in, it is not sensing the memory/map card.
    Is it possible that the card is bad and the gps won't read that it is in when installed?
  • 518 Answers
The unit is telling you to insert a memorycard
Posted on Apr 25, 2010
  • 2 more comments
  • colin butcher Apr 25, 2010
    Wow this is a tricky one then. Just try too reset this unit maybe that will help things
    Ok, i have one more idea before your unit may need repairing,
    Turn off your device, then remove the sd card and make sure the small lock switch on the lefthand side is in the unlock position, which is normally up. If this does not work i think maybe it will require a repair as i cannot think of anything else that could cause this, very sorry, Colin.
    Unless your device requires more memory, what size sd card have you got installed? Colin.
    I guess anything is possible, do you know anyone that has the same device that you could try your sd card in?
Senville mini split displays a "defrost" symbol????
It's a heat pump and that is how they work. But it shouldn't be cycling so much unless you live in Minnesota? The colder it is outside the more chance that the outside coil will freeze so it will go into defrost. It may be low on charge or have leak as well. Call a tech to verify.
Apr 13, 2014 | Senville 18000 BTU Ductless Air...
With a new set of batteries in camera the red battery low symbol
Try cleaning the contact points in the battery compartment. If one or more of the contact points are soiled, the camera will react like that. If the problem is due to a short circuit, the batteries will get very hot, if they are discharged after a few seconds.
Mar 02, 2010 | Fuji FinePix S7000 Digital Camera
Iphone 3GS- only get the apple loading screen.
If iPhone won't turn on, or the display freezes or doesn't respond
  1. Press and hold the Home button for at least six seconds, until the application you were using quits.
  2. If that doesn't work, turn iPhone off and turn it on again. Press and hold the Sleep/Wake button on top of iPhone for a few seconds until a red slider appears, and then slide the slider. Then press and hold the Sleep/Wake button until the Apple logo appears.
  3. If that doesn't work, reset iPhone. Press and hold the Sleep/Wake button and the Home button at the same time for at least ten seconds, until the Apple logo appears
More resets:
Try This:
1. Remove Sim Card
2. Hold in 'Home' button and 'On/Off' button together until Apple logo appears
3. Replace Sim Card
4. Hold in 'Home' button and 'On/Off' button together until normal phone screen appears.
Also, Try this:
1.) Shut down the iPhone 3G.
2.) Start up iTunes
3.) Hold down HOME button on the iPhone 3G
4.) While keeping the HOME button depressed, plug in the Sync cable
5.) A message will pop up to ask if you want to reset.
6.) Just click YES and the reset process should start.
Nov 29, 2009 | Apple iPhone 3G
Monitor starts then goes off, no signal
I would check the LCD against another monitor. It does not have to be a LCD, a regular monitor will do.
This will tell you 2 things, 1. The Video card is good or bad, 2. The Cable is sendinf a good signal.
If when you startup the monitor, you see a display and then after a few seconds it display's a no signal message, this is consistant with a Bad cable or cable ends. or Bad VGA card from computer.
Hope this helps. Good luck..
P.S. If you have move the PC, you may want to open the unit, and re-seat the Card. If the card is not making a solid connect on the board, it will display these syptoms.
Sep 05, 2009 | HP w1907 LCD Monitor
VHS won't work
Had the same problem on my JVC vcr/dvd combo unit.
You need to turn off the timer function. I did this by making sure my remote was in the "VHS" mode...turn the swith from TV to the right (found on the remote in the upper left corner...an then hit the "vcr" button. Then point the remote at the VCR unit and hit the No. 4 button (timer turns off). Your unit should not have the red timer displayed and you should be able to play your tapes okay.
Hope this helps.
Jun 11, 2009 | JVC HR-XVC27U DVD Player/VCR
Washing mashine dispalys symbol not in users manual.Where time is displayed it shows a symbol that look like a padlock.The machine does have a key symbol on side panel. Door is showing unlocked. Cannot...
Try buttons "dry" & "spin" together for a few seconds. This could be the child lock display.
Or press "end of cycle" for over 3 seconds.
Or press "options & select" till the light goes off.
Works for other machines..............
Mar 30, 2009 | Electrolux EW1000i Front Load Washer
Power problem
Three blinks - B+ over voltage protection (OVP), unit goes to the standby mode then displays the 3 blink fault. This is also a problem in the power supply circuit, check T603 and R672.
Jan 30, 2009 | Panasonic PT-47WX42 47" Rear Projection...
Unit turning off after displaying red pc chip icon
Hi whitiezn
If you say that this unit is very new , it should on all accounts still be under warranty.
Contact your local Toshiba Service Centre and have this problem sorted out on their account - the machine should still be under warranty.
May 05, 2008 | Toshiba TLP-ET1 Multimedia Projector
Tomtom GO 710 Car GPS Receiver Logo
81 people viewed this question
Top Tomtom GPS Experts
Martin Murray
Jon Piercy
Are you a Tomtom GPS Expert? Answer questions, earn points and help others
