Question about Dishwashers
How to shorten Dishwasher running time
I have Maytag Quiet Series 300 and have had this about 5 years and love it but the short clean takes 82 minutes. Is there anyway to shorten this time? I of course can't find my manual and have not been able to find a manual on line.
Thank you
    President:
  • 2,651 Answers
No way to shorten the cylces, they are what they are, this machine (all newer machinces for that matter) use far less water and much smaller more efficent motors than years past, however to clean the same the tend to run much longer 90 min normal for normal cycle, nothing can be done sorry!
Posted on Mar 23, 2008
Aborcas is WRONG ... there are special sequences for the buttons that can be pressed and it will move on or shorten the phase that it is in. I can't remember and that is why I am here. I can't remember the sequence for our Kenmore UltraWash...
Posted on Oct 31, 2009
How should I clean the Maytag Quiet Series 300 with vinegar?
just fill it with water no soap and drop in vinegar right in the water and let it run its cycle
Jan 27, 2015 | matag Maytag QuietSeries 300 Dishwasher...
The latch is sticking on my dishwasher. How can I
replace the door latch and the handle check to see if the console loops that hold the latch are broken if so replace the console
Jun 02, 2010 | Maytag 24 in. MDB9750AW Dishwasher
1.5 year old Maytag Legacy Series Quiet Series 300 Lock Light on
Hold down the heated-dry button for 3 seconds and the light will clear.
Nov 07, 2009 | Maytag 24 in. MDB9750AW Dishwasher
Foul smell coming from Maytag Quiet Series 300
Hello jscott,
It is typical nowdays for most dishwashers not to drain all water out of the bottom tub (Even where you cant see) due to siphon design and energy efficiency. Try using about a liter of vinegar and throw it on the bottom tub of the dishwasher. Let it run through a full cycle and see how that works. Has worked for me
Sep 07, 2009 | Dishwashers
Maytag Quiet Series 300 dishwasher, dishes come out dirty
A water softner will not make the dishes any cleaner, it just makes it so they don't have water spots on them.
If the dishes are dirty, it is most likely that the nozzles (holes) in arms may be plugged.
Also check to make sure you are getting plenty of water to dishwasher. Make sure all water valves are full turned open.
If the control panel does not work all the time, it is very likely you have either a shorted wire, or a fualty main board which is very common in newer machines.
Jun 01, 2009 | Maytag 24 in. MDB5601AWS Stainless Steel...
Maytag Quiet Series 300 Dishwasher will not turn off after it com
MY DISHWASHER KEEPS RUNNING, IT IS A WHIRLPOOL GOLD QUIET PARTNER IV
Apr 05, 2009 | Dishwashers
Maytag dishwasher legacy 300 quiet series
Check for foreign objects like glass or plastic at the grinder blades. Some dis assembly will be required. See appliancepartspros.com for diagram.
Mar 22, 2009 | Maytag 24 in. MDBH955AW Built-in...
Maytag quiet series 300 leaks from front
check the float switch on the righthand side on the bottom in the corner it should click and move freely
Dec 16, 2008 | KitchenAid 24 in. KUDI02IRBS Stainless...
Maytag Quiet Series 300. The lights flash in sequence starting from the outside traveling inward. The timer counts backwards from 50 to 1. Then the sequence starts over. and continues over and over. I'm able to clear it when the time reaches 1 or 2. It stays off for a while (3-4 hours) then starts over. I can not clear the countdown until it reaches 1 or 2. After I clear it the dishwasher will work, but until then, no way. This happens with the door open or closed.
Sep 15, 2008 | KitchenAid 24 in. KUDI02IRBS Stainless...
Dishwashers Logo
1,315 people viewed this question
Top Dishwashers Experts
