Question about Maytag MDBH945AWW / MDBH945AWQ / MDBH945AWB Built-in Dishwasher
Drying cycle doen't seem to turn off ....just seems to cook. Had to turn unplug the unit.
    Sergeant:
  • Maytag Expert
  • 211 Answers
If this is electric dryer your heating element had short to ground cause element to stay on even if the dry turn off
Posted on Apr 25, 2010
I have a Kitchenaid YKHMS147HW microwave that started turning on by itself, and will not shut off unless I unplug the unit. If I put food in to cook, the food starts cooking as soon as I plug the unit in,...
Sounds like stuck relay contacts. Magnetrons need a high voltage source which is controlled by a micro to relay and then from relay to voltage source. Even the turntable works via a relay.
Oct 14, 2013 | Microwave Ovens
How do you replace the door switch in a Kenmore 70 Series 68702 electric dryer?
What is the model number of your unit? Look inside the door area.
Nov 19, 2012 | Dryers
After the dishwasher has finished its cycle and the unit has sit for 24 hours, should there be water all over the sides of the inside stainless steal? It seems as if it is not drying. We just purchased...
I have looked at the users manual for this machine and it is not equipped with a drying cycle, so you need you used a Rinse Agent, like Jet Dry to get the result you desire.
Joe
Sep 20, 2011 | LG LDF6810ST Stainless Steel Built-in...
Dishwasher does not dry dishes. dishes are not hot at end of cycle. seems like heating element is not heating
Connect a volt meter one lead at each terminal of the heater. Read the voltage when it is in the drying cycle. If you get about line voltage the heating element is bad. If you get no or very little voltage it is the timing unit. If you are uncomfortable measuring voltage remove one of the wires from the heating element, after unplugging it, then connect a ohm meter across the heater. If it reads above about 50 ohms it is bad, if not probably the timer. Of course you could always connect a light bulb across the two heater terminals and if it lights during the drying cycle the heater is bad.
Good Luck,
Gil
Mar 01, 2010 | Dishwashers
I have a Cooks stand mixer and cannot get the beater off. I need an owners manual
You didn't oil yhe beater stems. Pour some wesson oil doen the stem sockets and sorta wiggle the beaters and work the release while doing so. First unplug the unit.Pour a tad bit around the release also.
Oct 26, 2009 | Food Mixers
Vibrating noise when cooking
In order to try to set your mind at ease I will have to explain the Basics on how a Microwave Oven Functions.
When a Microwave Oven is set to COOK ...START. It cooks at 100%. There is no lowering of the heat as with a Range ( Cook Top) Control. So in order to do the other things such as DEFROST, WARM, or anything other than 100% COOK. A COOK ON- COOK OFF system was utilized. To DEFROST, the Microve COOKS at 100% for 30% of the TIME, then IDLES for 70% of the TIME. COOK ON 30% of the TIME, COOK OFF 70% of the TIME = DEFROST This is why you can hear the CYCLE. More power is required during the ON CYCLE, thus the lower vibration. The Vibration occurs when the High Voltage Transformer is turned ON ( COOK ON).
The VIBRATION seems to have got louder with age. This is somewhat normal as there is a vibration from the High Voltage Transformer present every time the Microwave is used. screws and other metal parts seem to get loose with this vibration. There is no solution, unless you can tighten EVERY screw, nut, and bolt in the unit.
Sorry!
Dec 07, 2007 | Kenmore 62642 / 62644 / 62649 Microwave...
Hotpoint Aquarius+ WD645
Yes, you will need a test meter. unplug machine, remove to, in the middle on top you will see a heater, you will need to test this. there is also a fusable link, that is incorprated in one of the wires that go to the heater. you will also find to thermostats linked through the wiring, one of these may have a reset button on it.
Dec 07, 2007 | Washing Machines
It just seemed to turn off
yes,unplug the unit ,remove the outer case ,follow the plug inside to the fuse ,read the amperage ,test the fuse with an ohm meter should read shot or 0 ohms if not replace whit same type and amperage,
Dec 01, 2007 | Emerson MW8168B Microwave Oven
Maytag MDBH945AWW / MDBH945AWQ / MDBH945AWB Built-in Dishwasher Logo
83 people viewed this question
Top Maytag Dishwashers Experts
Charles T Nevin
Charles T Nevin
Mike
Are you a Maytag Dishwasher Expert? Answer questions, earn points and help others
