Question about Vehicle Parts & Accessories
I have a UNGO Pro Security SR6000 install on a loaded 2005 Nissan Atima. Every once in a while when my arm the system, the windows role down. How is this happening?
  • 3 Answers
SOURCE: rear window, door wont open from inside
i dont know if ur door is electric or manual.as for the door not opening from the inside it could be a rod has come off from the inside of the door to the handle you have to take inside door panel off and have a look.
Posted on Dec 26, 2008
  • 25 Answers
SOURCE: How do you arm the factory security system?
push the button twice to dissarm the system, it will arm itself after about 30 seconds you should be able to see that its armed by the indicators flashing or if you have a siren fitted it will chirp twice . this function can removed but it will automatically self arm
hope this helps
kind regards
bert31000
Posted on Mar 19, 2009
SOURCE: All the windows on 2000 Cabrio roled down when i
Try disconnecting the battery terminals as this may reset the cars computer. This worked when one of my rear windows would not go down flush.
hope this works for you
Posted on Jun 15, 2009
SOURCE: windows on my dodge durango won't role down after battery died
My 2007 dodge durango has a light on in the dash what is it and what do I need to do it looks like a horse shoe with a ! in the middle
Posted on Sep 14, 2009
byteguy
  • 2229 Answers
SOURCE: xp pro sp1,2,3 installed. cannot install kb953297,
You can ask Microsoft about these errors. There is no charge when asking for help with updates. When you open Microsoft Update and look at update history, click on the updates that failed and they often give you instructions on how to solve the problem.
Posted on Dec 22, 2009
Car won't start
Car Won't Start?
This procedure usually works:
·Check the battery cable connections:
Make sure the positive cable, makes a good connection at the battery and at the starter. Make sure the negative cable makes a good ground connection at the battery and (preferably) at the engine.
·Check the battery the simple way, like this:
Turn on the headlights, then try to start the car.If the headlights do not dim or go out, then the battery is likely ok.
·Check the starter and solenoid:
If the wiring looks ok, then look at the starter solenoid for a good connection, and proper voltage at the starter(10 volts minimum while cranking).
If the starter spins and no crank, the problem is most likely the Solenoid's pinion gear is stuck.
Have someone hit (not too hard) the starter while you try to start the car. This usually works by dislodging a stuck pinion gear.
·Make a simple test of the alternator:
If you can, somehow get the engine running, measure the voltage at the battery. It should be at least 13.6 volts to properly charge the battery.
Apr 27, 2015 | Ungo SR6000 2 Way Security with Remote...
Nissan atima 2008 all four window not working
cheack the switches on the drivers door if switches are bad they wont work
May 20, 2011 | Nissan Altima Cars & Trucks
Hi, i have a clarion ungo command start on my 99 f350 diesel truck, and i have no owners manual or setting instructions. i want to set it to start and run at 4 hr intervals cause i live in sask, canada...
Hey I happened to find this while searching for the same part number on the back of my remote. Mine is a Clarion Ungo SR6000 and the product manual is here: http://www.clarion.com/us/en/MungoBlobs/669/603/SR6000.pdf
My remote is broken and I'm trying to buy another online without having to go through a local dealer b/c they all want me to come by and I just want to order the stinking FOB.
Nov 30, 2010 | Clarion GPS
I have an ungo remote start/alarm. This AM the car would not start and the alarm went haywire- kept going off, took control of the car, A/C going on and off, etc. Had to disconnect the battery to get it to...
i have a ungo sr 6000 i missed placed my lcd 2-way remote so i only have the secondary 4- button remote. How can i disable the timer auto start!!!!!!!!! PLEASE HELP ASAP !!!!!!!!! GOIN BROKE ON WASTED GASSS!!!!!!!!!!!!!!
Jul 30, 2010 | Ungo SR6000 2 Way Security with Remote...
1100F DEI bypass module on a 2003 sport trac
if nothing else just use the "key in the box" method for bypassing the explorer, only thing is you will loose a key, good luck
Nov 23, 2009 | Directed Electronics 1100f Ford Pats...
I got a used jeep grand cherokke
if the remote batteries died simply replace the batterys and all is well. the factory remote isnt programable btw
Jul 30, 2009 | Ungo SR6000 2 Way Security with Remote...
2006 tacoma will not unlock when remote started. also dash lights and parking lights flash when remote started.
May not be programed to lock in remote start, secondly if programmed lights will flash while in remote start.
Jun 28, 2009 | Ungo SR6000 2 Way Security with Remote...
Anti virus
100% positive, Windows Update is needed. (Known exploits can only be patched by the operating system update)
Oct 10, 2008 | Trend Micro PC-cillin Internet Security...
Vehicle Parts & Accessories Logo
169 people viewed this question
Top Vehicle Parts & Accessories Experts
Thomas Perkins
Thomas Perkins
Are you a Vehicle Part and Accessory Expert? Answer questions, earn points and help others
