Question about Zonet ZSR1134WE Wireless Router
WAN connected, but no internet (light not flashing)
Not problem with ISP - connection is fine when router is bypassed
  • Harleen Nash May 11, 2010
    1. What is the router connect to. 2. Check your wireless configuration. 3. Check your RJ45 cable 4. I will need more information as to your issue to give further assistance.
    Problem Solver:
  • 15 Answers
You know i have lot of fun with this myself and I have found that I didnt have the DNS setting from your ISP on the network adapter settings TCP/IP hope that helps
Posted on Apr 27, 2010
I went through all the set up steps, but when i unhooked the ethernet cable from the router and my computer i could not connect to the internet. My computer is communicating with the router but the router...
You need ot make sure that the router WAN lights are on and its connecting to your ISP. You need ot have all the link and state lights on. The router will automatically connect to your ISP, unless someone has set the configuration to manual. You can try resetting to factory defaults and see what happens on the WAN side. You NEVER need to configure the WAN interface. You then need to reconfigure the LAN side.
Jan 13, 2011 | D-Link AirPlus DI-524 Wireless Router
My Netgear adsl router is not getting connected to Internet in pppOe mode ..
POPE configuration is logs into your ADSL system and connects to your ISP provider server to link , so one of the reason why it dosent is due to either password and username not correct. Log unto IP address of your Router and go to WAN configuration , Check your username and password and reset to the initial password and username your ISP provider gave you , when you signed up with them. Then apply changes , off your router for 1 min and then power it , then wait for the ADSL light on the router to be stable , connect to the IP address of your router again and "Volla" , it should be fine , if not , contact your ISP provider....
Oct 07, 2010 | NetGear DG834G 802.11G Wireless ADSL...
How do i install my router i have one care on my computer and it wont let me install my router. How do I bypass this?
You may manually configure your Belkin router. Make sure that the computer is connected to the ethernet port (gray) of the router. Then the modem is connected to the WAN port (yellow) of the router.
On your computer's browser, type: 192.168.2.1
It will prompt you for your password. By default, just leave the password field blank.
Once in the setup page of the router, go to Internet/WAN tab. Under connection type, you need to select the type of your connection depending on your ISP. If you are not sure, contact your ISP and ask them if they use PPPoE (you will also need the username and password for your connection) or DHCP, Static, etc.
Then next and then apply changes. Once the router has the correct settings from your ISP, you should be able to get online.
For the wireless settings, just go to Wireless in the setup page and you may change your settings like enabling wireless security.
I hope this helps!
May 15, 2010 | Belkin (F5D8231-4) Wireless Router...
Cannot connect to internet. router modem and globe lights blinking amber.
If the modem light is blinking it means that there is activity, so this is normal.
However, the globe/internet light needs to be solid green. If it is blinking it means it is attempting to connect to the internet.
Make sure first that the internet connection is working when directly connected to the modem. If yes, then the router might not be configured properly. To check the configuration on the router, access the setup page by using a web browser. Type 192.168.2.1 in the address bar.
By default the password should be left empty.
Once in the setup page of the router, go to Internet WAN. Select the connection that your ISP is using. Either, PPPOE (requires a username and password from ISP) or Dynamic, (the settings are obtained automatically from the ISP). If you are not sure, contact your ISP.
I hope this helps!
Mar 01, 2010 | Belkin (F5D5231-4) Router
Slow dsl
The cable modem should be connected to the WAN port of the router. Then the computers should be connected to any ports from 1-4 at the back of the router.
Once they are connected properly. Reset the router. Just hold the reset button for 10 seconds. Then turn off the modem, router and all computers.
Then you need to turn on the modem first, wait for the lights to become solid green, then turn on the router. Once the WAN light on the router is on, turn on the computers and check if there is internet connection.
If still no internet connection, contact your ISP. They might need to clone the mac address of router to their end.
Hope this helps! Good luck!
Feb 08, 2010 | Linksys EtherFast Cable/DSL Router
Flashing amber modem light on belking n wireless router
Actually there is no problem with the Modem
First Get the following Information from your ISP
1 ) The Connection Type
2 ) If it is PPPoE then Get the user name and Password
Step 1 : Connect Modem - Router - Computer (Wired)
Step 2 : Open RSP By typing 192.168.2.1 on the Address Bar of the internet explorer
Step 3 : On the Left Side Under Internet WAN Click
Connection type
Step 4 : Leave the Password Blank and click Submit
Step 5 : Select the connection type as given by the ISP
Step 6 : Click Next
Step 7 : Type Username And Password for PPPoE ,Click Apply Changes
Step 8 : There is no need to type Any Host Name for dynamic Click Apply Changes
Step 9 : If it is A Cable connection then
Step 10 : On the left side Under Internet WAN Click MAC Address
Step 11 : Click Clone
Step 12 : Click Apply Changes
Step 13 : Restart the Router
Step 14 : Check the Internet Status
Jan 11, 2010 | Belkin Wireless-N Wireless Router with...
Wireless router to modem problems
Since it says network cable unplugged on the computer when wired to the router, you need to check these first:
â Make sure that the Ethernet cable is connected from the modem to the router’s Internet (WAN) port and the computer to the numbered port of the router. The computer should used to be connecting to the Ethernet port of the modem, if not; you should contact your ISP first.
â Make sure that the Ethernet adapter/LAN card on your computer is working properly. You can check that on the device manager of your computer.
â If those are all working fine that would mean the router is not yet configured for Internet access or we can say that the settings for the provider are not synchronized with the router.
To configure the router, you can do these general steps:
1. Connect the computer to the numbered port of the router and the modem to the router’s Internet (WAN) port.
2. Turn off the computer, router and modem.
3. Turn on the modem first, wait for the lights to stabilize then turn on the router. As soon as the lights are stabilized, you can turn on the computer and check for internet connection.
However, if the Internet connection still does not work. That means there are additional settings needed to be done. You can message me about the name of your ISP and I will provide you the specific steps you need.
Sep 23, 2008 | Belkin (F5D7230-4) Router (587009)
No wan light
If no wan light bypass the dlink router and check if ethernet cable connected to wan port is working. Once you are able to go online through modem connect cable to WAN if light does not go on log into oruter and clone mac address and save settings.If doesnt work powercycle router and turn modem on first then router next if doesnt work upload latest firmware.
Sep 05, 2008 | D-Link AirPlus DI-524 Wireless Router
Can not connect to the internet in trying to setup the router.
Yes time warner is a cable connection and they dont require a username and pasword. You can set up the router manually by accessing its set up page. By default the router's IP is 192.168.2.1. Make sure to set the wan connection type to dynamic, change the wan mac address or clone your pc's mac. Then save the settings. Check your internet connection.
Aug 18, 2008 | Belkin Wireless G Plus MIMO (F5D9230-4)...
Belkin router
it is possible that the settings for your ISP is already gone or the router is not recognizing the settings.
Oh by the way who'se your ISP, is it cable or dsl internet?
For cable internet the router's internet/WAN connection type must be set to "Dynamic" for DSL internet there are some that will require you to setup your userID and password given to you by your ISP, to do this just change the connection type to PPPoE and fill out the required fileds(usually it just the userID and password from your ISP).
To access your router setup page, just open internet explorer on your computer(given that its connected wireless or wired to the router) and type http://192.168.2.1 . Type admin for the password and leave the password blank.
Jul 15, 2008 | Belkin (F5D5231-4) Router
Zonet ZSR1134WE Wireless Router Logo
207 people viewed this question
Top Zonet Computers & Internet Experts
Prashant M
Prashant M
KG John Justin
KG John Justin
Are you a Zonet Computer and Internet Expert? Answer questions, earn points and help others
