Question about Tecumseh Ov691ea 22 Hp 22hp Lawn Rider Mower Engine Bn
Fuel will not go to carb.take fuel line off and crank it over the fuel pours out of the line, the only way it starts is if you pour gas into it directly
    Top Expert:
  • Tecumseh Master
  • 13,723 Answers
Carb float valve stuck not letting fuel into carb body sometimes a light tap on carb may free it up or may have to be removed and cleaned and or float may need to be repaired or replaced
Posted on Apr 25, 2010
Atv not getti g gas to bowl, new carb petcock lines new gas ?
With the pet **** hooked up and in the open position from tank and vacuum line attached to carburetor and fuel line detached from intake of carb and in clear bottle crank engine. Does fuel go in bottle while cranking. Pour a few drops of fuel into in sparkplug hole reinsert the plug and plug wire to plug hook fuel line back to tank and carb turn on ignition and crank in neutral of course.
Oct 11, 2017 | GAS Motorcycles
1972 ford truck 36o engine turns over wants to
that's a fuel supply problem test fuel pump remove fuel line place end in a bucket and crank engine and watch amount of fuel and flow coming out.
Oct 19, 2014 | Cars & Trucks
Hard to start, no fuel to carb
If you take the fuel line off at the carb and crank the engine, does the pump push fuel out of the line ?
Apr 11, 2013 | 1984 Ford F 150
When i start the lt1042 cub cadet riding mower it smokes from the exhaust and oil is in the carb
sounds like the needle valve inside the carb has failed dumping gas into the crankcase and into the cylinder this overfills the oil and dumps it change the valve and seat change the oil a couple times add a fuel line shut off and run the carb out of gas when your done using it the newer fuel we get melts the rubber seal
Apr 25, 2012 | Cub Cadet Riding Lawn Garden Tractor 25hp...
Engine stalled out,would not start, pour gas in carb,cranks,keeps running,until idle falls below 12to1500rpm,than stalls out again and will not crank,repeat gas or starting fluid in carb,cranks runs and...
This truck is fuel injected, the problem sounds like a weak fuelpump, it runs when you pour gas into it until that gas runs out, the first thing is to test the fuel preasure, if the pump is weak it may run with gas poured into it but wont idle, also a common problem is the coolant temp sensor and the ground wires to thermostat housing bolt but i wont bet its the pump inside the fuel tank, if you put a fuel gauge on it there should be at least 55-61 psi if its a few pounds lower it can cause problems, you have everything else and it runs with gas poured so its a fuel problem check the preasure, theres a valve up top on the fuel line to connect a fuel gauge to it, start there hope this is helpful.
Dec 27, 2010 | 1993 Chevrolet C1500
Won't stay running
I took the carb apart and found that it needed rebuilt, I installed the new carb and fuel pump kit and it runs great again.
Apr 05, 2010 | Briggs & Stratton Briggs Stratton Intek V...
Briggs and statton carb pouring fuel out
Could you have possibly lost a plug in the carb ?
Jun 07, 2009 | Poulan 42-Inch Steel Deck 17.5 HP Briggs &...
Gas pouring out of air filter
carb is gummed up from the old fuel turning to varnish and clogging the jets. while trying to start, its trying to inject fuel, but its clogged and taking the path of least resistance (coming out the air filter).
you'll need to drain the gas tank and remove the carb to clean it out. if unfamiliar or uncomfortable doing this, then take it to someone to do a carb cleaning.
Jan 29, 2009 | Garden
Tecumseh Ov691ea 22 Hp 22hp Lawn Rider Mower Engine Bn Logo
241 people viewed this question
Top Tecumseh Garden Experts
Mike Squire
Jim Parker
Jim Parker
lnbn1975
Are you a Tecumseh Garden Expert? Answer questions, earn points and help others
