I have a HP pavilion a320n desktop. I decided to upgrade the RAM so I installed two 512 chips, as per instructions. When I turned the unit back on nothing happened, as if there were no power at all, no fan, no lights not a thing, almost as if the power supply were bad... any suggestions??
The easiest way is to add more RAM memory. More RAM = faster computer.
Go to WWW.CRUCIAL.COM and run their SCAN MY COMPUTER option.
This will tell you excatly how much RAM you currently have installed in your system as well as how much room you have to add more if you want. It will tell you all the specs you will need to buy new RAM memory sticks and easily upgrade your computer's performance.
Good luck and please post back if this was helpful or if you need further assistance.
Pavilion ze4910us Memory SpecificationsStandard Memory
512 MB (removable)
Maximum Memory
1.0 GB
Memory Expansion
2 sockets
Memory Comments
PC2100/2700 DDR SDRAM SODIMMs
CPU Type
1.4GHz Intel Celeron M 330
Model Comments
400MHz FSB
Memory Upgrade for
HewlettPackard Pavilion ze4910us Laptop, the HewlettPackard Pavilion
ze4910us Laptop takes the PC2100/2700 DDR SDRAM SODIMMs Memory Type, and
comes installed with 512 MB (removable) of
Memory. You can upgrade your HewlettPackard Pavilion
ze4910us Laptop to up to a maximum of
1.0 GB Memory, the system has 2 sockets to install
Memory, already with 512 MB (removable) standard Memory
installed. For best Laptop performance use the maximum amount of allowed
Memory per slot for your Laptop.
Choose the following Memory Upgrade for HewlettPackard Pavilion ze4910us Laptop.
Upgrading RAM on your Gateway 700X (DDR) Computer is easy, Gateway 700X (DDR) Computer takes the PC3200 DDR SDRAM DIMMs. Supports Dual Channel DDR. RAM Type, and comes installed with 512 MB (removable) of RAM. You can upgrade your Gateway 700X (DDR) Computer to up to a maximum of 2.0 GB RAM, the Computer has 4 sockets to install RAM, already with 512 MB (removable) standard RAM installed. For best Computer performance use the maximum amount of allowed RAM per slot for your system.
Is it a High Density memory? There are two different types of memory, High and Low. Low density is the universal but High density, may be cheaper but the motherboard needs to be compatible with High density memory. Although your memory fits in the slot, I think you have High density memory hence why it won't boot up and does when you remove the memory.
its that 512 mb total capacity for your computer memory?? if so read this:
To find the total amount of RAM that can be added , subtract the amount of RAM currently in the computer from the maximum amount of memory the computer can hold. For example, a computer has 256 MB of RAM. If the maximum amount of memory the computer can hold is 512 MB, then 256 MB is the amount of RAM that can be added. this info from the HP website , to find out more , go to http://www.hp.com/support , enter the model number , and look for more information about your computer specs, hope this helps , please rate & thanks AJ
