Question about Sirius Satellite Radio S50-TK1 Satellite Radio Receiver with Car Kit
Screen says invalid image. object loading failed
Screen says invalid image. object loading failed , please connect usb cable. did that did not work.
My Walkman NWZ-S544 connects but does not pass image that says walkman, and when I connect USB loads but says "the timer and alarm will become invalid," already did reset and still the same, that woul
It's supposed to say ")Connected USB)The timer and alarm will become invalid." I does that because it's charging when you plug it into your CPU. Hope this helped!
Mar 10, 2013 | Audio Players & Recorders
My Walkman.. is Loading forever and cannot open
1.Try resetting the Walkman by pressing the RESET button located on it. It looks like a small hole. You can use any pin or any sharp pointed object to reset it.
Then connect back the Walkman to check whether it works.
2. Use the supplied USB cable to connect the Walkman to the Computer.
3. Disconnect all other USB devices if you have connected to avoid conflict.
4.Connect the Walkman to the other USB ports on the Computer.
5.Check whether the USB Driver is installed in the Computer or if it is corrupted.
You can check whether the USB Driver is corrupted or not by following steps below(only for Windows Operating System).
Right-click on MyComputer icon and select "Manage".
Then, select Device Manager at the left plane.
Then check whether any "Unknown device" or "?" or "!" is listed under Universal Serial Bus Controllers at the bottom of the right pane.
If there is so, then right-click on it and select uninstall.
This will un-install the USB Driver.
Then, un-plugg the USB cable and plug-it in.
Now, the Walkman should be recognized as a removable device in My Computer.
If the issue persists, then connect the Walkman to a different Computer to check whether the issue is with the Computer or the Walkman.
If the issue persists even with different Computer,
If the issue persists you may try using a different compatible USB cable.
Jul 22, 2010 | Sony NWZB133F MP3 Player
When I plug it into the PC it does not show as connected
Try it in another computer (Mac, desktop, notebook).
It could either be the USB-to-disk-drive interface that has failed,
or the USB cable that has failed,
or the disk-drive inside the casing that has failed.
Try a different USB cable.
Open the casing, and remove the disk-drive, and temporarily connect it as a "slave" disk-drive in a computer, to see if it can be detected.
Jan 13, 2010 | Western Digital Elements powered by WD 320...
When connecting the Kodak C913 to the computer, the USB hub will not receive information from the Kodak. The driver is failing for some reason, giving the error message (during reinstallation of the...
Possible solutions:
Remember you need to turn the camera on when transferring.
Try a different USB outlet
Try a different cable
Try a different computer.
If all fails please contact KODAK in order to arrange a repair or order a new cable. Remember you cable is covered under the same warranty as the camera, so if covered you need the serial number of the unit:
http://www.kodak.com/eknec/PageQuerier.jhtml?pq-path=14563&pq-locale=en_US&_requestid=3490
Jan 08, 2010 | Kodak EasyShare C913 Digital Camera
(1) Cannot connect by USB to or from Macintosh MacBook OS10.6.2. Not visible in Disk Utility nor Unix /Volumes. (2) USB stick works if not partitioned to GUID first, i.e., a new FAT-32 stick works but GUID...
1) Obviously you can connect SOME devices over USB, as specified in your statement #2. If the problem is wider than that stated in #2, please be more specific.
2) The behavior you describe is symptomatic of counterfeit USB sticks. Some low-cost counterfeits accept formatting to their advertised capacity, but there is really no memory there. When formatted with formats that require data at the end of the address space, these drives will fail.
3) This is an artifact of moving Macintosh files onto a PC format disk. If you don't want this to happen, ZIP the files before moving them to the USB stick.
Nov 21, 2009 | Apple Computers & Internet
I had imaging studio for my last computer but when I loaded the peinter program on my new computer the imaging studio did not come in. What did I do wrong. I have vista
You will need to uninstall and reinstall the printer driver. Please follow the steps given below:
To uninstall, please follow the steps given below:
1. Click "Start" and "All Programs."
2. Go to the "Lexmark P4300 series."
3. Click "Lexmark Uninstall."
4. Click "Next."
5. Click "Finish."
6. Click "Restart Windows" and unplug the Usb cable.
You may copy and paste the web address below to access the Lexmark P4350 printer Vista driver again:
http://downloads.lexmark.com/cgi-perl/downloads.cgi?ccs=229:1:0:479:0:0&emeaframe=&fileID=11416&searchLang=en&searchLang=en&os_group=Windows%20Vista
To download the Lexmark P4350 Vista driver, please follow the steps given below:
1. Click on "Downloads." tab next to Publications and click on "Driver for Microsoft Windows Vista." Click on "Download.
2. On the "File Download" screen, choose "Save."
3. The next screen will be titled "Save As." Choose to "Save in Desktop" and click "OK."
4. You should see files being transferred.
****Note**** If your browser uses a different file downloading format than specified above, you will need to resort to your browsers help files for downloading instructions. The object of steps 1 - 4 is to download the driver to your desktop. This way it is easily accessible.
5. Once the files have completed downloading, double click on the icon with your file name.
6. On the "Win Zip Self-Extractor" screen click "OK." To unzip the downloaded file choose "Unzip."
7. A screen will then display the number of files unzipped successfully, click "OK."
8. Please follow the on screen instructions to complete installation of your Lexmark printer.
Note: Please plug the USB cable when prompted while installing the driver. The USB cable should still be removed from the system, and the on-screen prompts will remind you of this. Eventually, you will get to a screen asking you to plug in the USB cable. This screen also has an "OK" button. Do not hit this button yet. First, plug in the USB cable. The screen should automatically detect and install the Lexmark P4350 scanner and printer drivers.
Oct 18, 2009 | Lexmark P4350 All-In-One InkJet Printer
What kind of USB cable comes with Sharper Image 10x25 binoculars
Go onto the www.Sharperimage.com web site if you look it will tell you that Sharperimage are in receivership but they do point you in the direction of a support comapny called N.E.W.
In reality you should be able to buy those leads from any decent camera shop or a place like Tandy
Jun 16, 2009 | Sharper Image Optics
Sansa e280 Main Image Wont Load Problem, Plus firmware updater doesn't work
Do not worry! I had the same problem as you before and got it fixed perfectly! Go to this thread and read the instructions carefully.
http://www.anythingbutipod.com/forum/showthread.php?t=11233
Note that doing this will delete all files in your player, so I recommend you to save your files somewhere before doing this.
Dec 28, 2008 | SanDisk Sansa e250 MP3 Player
Load main image failed?
Hope this would help. Have you updated the firmware of your player? Try updating the firmware of your player. When the player is turn off slide the hold switch for it to show orange/red color. Then press the Record and the menu button until is shows on the screen welcome to recovery mode. Then go to sandisk website and download the firmware update and install it to your computer. When it ask you to connect a device connect the player and update the firmware of the player. If the update is successful then it would ask you to choose a language. Hope this helps
Jun 16, 2007 | SanDisk Sansa e250 MP3 Player
go to sandisk and go to support there you can find support the recovery software. hope it helps
Sirius Satellite Radio S50-TK1 Satellite Radio Receiver with Car Kit Logo
238 people viewed this question
Top Sirius Satellite Radio Audio Players & Recorders Experts
Colin Stickland
Colin Stickland
Tom Chichester
Justaguy
Level 1 Expert
Are you a Sirius Satellite Radio Audio Player and Recorder Expert? Answer questions, earn points and help others
