Hitachi 50V500 light blue shadow problem follow-up: Hi, I just wanted to explain the sequence of events that led to the "light blue" shadow problem to rule out anything else other than the light engine replacement for this unit. Three weeks ago the TV was working perfectly fine with great color and clarity then all of a sudden the lamp light came on solid red. I tried turning the TV on and no picture. I read the manual and replaced the bulb. Still did not work. I asked fixya and was advised it was the ballast. I replaced the ballast and everything is working great except that the picture is good not great. Light blue shadow now appeared which was never there before. Light engine was replaced previously 4 years ago when TV was under warranty. Can this still be the light engine again? Thanks.
  • chinds840 Apr 25, 2010
    Thanks for your reply.I never did actually replaced the lamp. I bought a new lamp thinking that was the problem, but actually learned it was the ballast. So, I kept the new lamp in my garage and have my original lamp in my TV.I can't figure out why this blue shadow appeared when I never had it before.All I really did was replace the ballast and test both lamps (new and old) to see if they were working in another Hitachi TV 50V500. If it still sounds like the engine lamp to you my question is how many years do engine lamps last? I ask because at this point it might more sense to purchase a new TV rather than replacing engine lamps every few years.
    Thanks again.
    When you say displaced mirror do you mean a mirror that needs adjusting rather than a mirror that is damaged and needs to be replaced? Also, the shadow problem is very light blue in color for an Hitachi 50 in LCD TV. I believe the link you sent said that the shadow had to be dark and for a projection TV. Bottom line it sounds like the light engine is failing, correct?
    Thanks.
  • 1,869 Answers
Yes it can be the light engine but, before you spend money you may not need to: look at the old ballast part # make sure the # matches the new ballast also check the electronic label for the correct values: volts watts amps etc. If you know how, safely: check your power supply to the ballast, as; I have gotten the "blue halo" before on a hitachi set when the ballast manufacturer was changed and, the replacement part was not made by the manufacturer.
Posted on Apr 25, 2010
  • 19,396 Answers
Hi.
Shadows are not caused by lamp faults. It is a problem related to the optical group, usually a displaced mirror in the light tunnel.
I have written an article on the problem here: Rear projection TV displays a shadow on one...
The light tunnel is an expensive part. As first thing call Hitachi at the number listed on the manual, and ask conditions for repair.
Here the contact: Contact Support.
Please do not forget to leave feedback.
Regards.
  • 10,594 Answers
I think picture was not so bright with old lamp and that is why blue shadows in picture were not noticeable.
After lamp replacement, picture becomes brighter and blue shadows become more prominent.
It is just my opinion.
Required light engine is available HERE. Click that link to see an image and price info.
Thanks.
  • Shahid Electronics
    Shahid Electronics Apr 25, 2010
    Yes, its light engine problem because it consist of 3 lcds and few color filters.
    Blue lcd and related filter got marks due to heat of lamp and you see it as blue shadows.
Blue shadow around the screen middle kind of yellow color please help me
50v500 or similar set that uses a lamp: damaged optical light engine is most likely--got a model number?
May 21, 2012 | Hitachi Televison & Video
Hitachi LCD TV, Problem with the image
I am having the same problem with my 50v500 as well. Please let me know if you find a solution.
Apr 20, 2010 | Hitachi 50V500 50 in. HD-Ready LCD...
Red in Color Shadow
contact authorized servicer to do a memory initialization in the service mode
Apr 02, 2009 | Hitachi 50V500 50 in. HD-Ready LCD...
Blue half moon shadow on top of screen
We had this same problem with our 60+ inch Hitachi. Except our tv had a red hue in the center of the tv before we replaced the bulb and then the blue hue joined the red one after the replacement. It ended up that our light engine was defective (which is an extremely common problem in Hitachi tvs). You should read through some of the forums on here to see if you can find your solution exactly (that is how I figured out my problem was our light engine). You might have the light engine problem also, but I am not sure since you don't have a red hue. Hitachi pays for the replacement light engine part (worth $1200). I just finished the process and now my tv is like new. If you want me to go more in-depth with the light engine repair process let me know.
-kdubb
Nov 20, 2008 | Hitachi 50V500 50 in. HD-Ready LCD...
Hitachi 50" Ultravision too much yellow, not much blue
First of all sorry for delay.
can you provide a image of yello shadow.I believe it seems to be technically say "ghost image"
If it is ghost image we can try by entering SERVICE Menu and adjust RGB level of the light engine.
Good luck
Dals123
Oct 04, 2008 | Hitachi 50V500 50 in. HD-Ready LCD...
Ghosts or shadows around images
I always start my Hitachi research at their website.........
www.HitachiServiceUSA.com...................T.
Nov 28, 2007 | Hitachi 50V500 50 in. HD-Ready LCD...
Hitachi 50v500 blueing problem
I am not expert but before you go to a lot of trouble, read all of the post on the infamous "red cloud", "red blob" and "blue streaking". In evey case, it appeared that the light engine was the problem. We just had our light engine replaced and the TV looks perfect. We dealt only with Hitachis Customer Relations Department 800-654-7013. You will have to have a certified tech come out and diagnos the problem. Hitachi will then call and verify, with the dealer, that the problem is a defective light engine and will send out a brand new one.
We were told the part cost around $1500 (Hitachi covers that) however, they will ask you to pay for the install. Our install cost $400. Worth is to us as we paid $3600 for this set 3+ years ago and we have loved this TV. When you first call Hitchi, they will act like they've never heard of this problem but they will give you names of certified techs in your area. Once the tech confirms that it's the light engine, Hitachi will own up to the problem and send out the part.
You really should only deal with Customer Relations ( I listed their 800 number above as you will be chasing your tail so to speak with their regular customer service department. Good Luck!
Nov 24, 2007 | Hitachi 50V500 50 in. HD-Ready LCD...
Hitachi 50V500 tv blue shadows
If it's a ghosting problem that looks like this:
it's probably something you can correct yourself...
Nov 21, 2007 | Hitachi 50V500 50 in. HD-Ready LCD...
Shadow problem
More explaining needed as I dont know what shadow means?
Jun 27, 2006 | Hitachi 50V500 50 in. HD-Ready LCD...
Televison & Video Logo
60 people viewed this question
Top Televison & Video Experts
Electro Med Services...
