Power problem! Technika ECO1STBA08 just stop working one day,
My Technika ECO1STBA08 just stop working one day - it will not even turn on! When I plug it in I can hear the machine attempting to power up and can feel it vibrating (weakly). The 'power' light, however, does not light up. Is there anything I can personally do to fix this?
SOURCE: Cuisinart programmable espresso maker em-200C
Currently, both my manual and steam button are flashing. No idea why. Any help?
Posted on Feb 29, 2008
SOURCE: Dell SX260...Wont Boot...Power Button Flashing Amber....grrrr!
Try these (un order of degree of difficulty) 1. Try replacing the battery on the system board. it is  typically a CR2032 button-style battery. This helps if the computer has been off for a long time.  2. Make sure all dust has been blown or vacuumed out of the computer. 3. Check to see if the USB pins are bent inside the connector on the back and the front of the computer. Straighten if possible. 4. Remove add-in cards, fans, shrouds, and heatsinks, then check the system board for leaky or mushroomed capacitors. If you would like, this may also be a good time to see if the processor is seated correctly or possibly short-circuited (burned black on the bottom, burnt or missing pins, etc). If it is any of these, you may need a new system board (motherboard) 5. It may be that you need a new power supply. Do your best to make sure that it will fit your computer case and have all the power connectors you need; they are not created equal.
Posted on Aug 30, 2008
SOURCE: machine will not work, i plug it in and press the power, but nothing happens.
I have the same problem with my shark. I dismantled it and found that a thermal fuse on the bottom of the tank is blown. I am trying to locate the part now. I will post when found.
Posted on Oct 03, 2008
  • 233 Answers
SOURCE: Medion Desktop won't boot. Flickering power light????
I agree with the hard drive solution. I would check that first.
Posted on Dec 25, 2008
localwonder
  • 6784 Answers
SOURCE: Dryer is getting Power but not coming on.
Check the following---
1. No power to the dryer
Make sure there's power getting to the dryer. Check for a tripped circuit breaker or a blown fuse. Check the wall socket for power with a voltmeter or by plugging something else in. Sometimes the power cord disconnects or burns at the dryer, if this is the case, the wiring and the terminal block must be repaired or replaced.
2. Door switch / Door switch actuator lever
The dryer would not start with a broken door switch. Replace the door switch if found defective.
Most dryers have a door switch actuator lever - when you close a dryer door, it presses against the lever, which actuates the door switch. If the lever is broken, the switch would not activate and the dryer would not start. Replace the lever, if broken.
Note: Door switch actuator lever usually comes with the door switch assembly and it is recommended to get the whole assembly since there is almost no price difference between the door switch assembly and just the lever. Check your model for more details.
Posted on Jun 01, 2009
How do i get my wireless technika mouse wm110pk to connect to my laptop?
Insert the USB dongle that came with your technika wireless mouse into a USB computer port on your machine.
This dongle, which resembles a regular flash drive in appearance, can be plugged into any available USB port.
Once inserted, it immediately turns on.
Insert the required amount of batteries (typically two AA batteries, though it changes depending on the model) into the compartment on the bottom of your HP wireless mouse.
Flip the "ON" switch on the bottom of your technika wireless mouse.
Press the "Sync" button on the bottom of your technika wireless mouse.
The mouse will now sync with your computer and will be immediately usable.
hope this helps
i have read some good and bad reviews on this mouse one stated the wireles stopped working several times and it had to be replaced
Oct 12, 2012 | Computers & Internet
No sound on Technika LCD 42-8533D
Go to first time installation.Complete process and sound will return.
Jun 06, 2012 | Televison & Video
Why can't i turn on my dvd with the remote control its a technika 22-212i
Please make sure your remote control is working properly.
It is pretty common for remote control buttons to stop working after a certain time period or due to excessive usage.
Feb 04, 2012 | Televison & Video
Technika 23" dvd combo DVD just shows no signal.
I also have this problem but the DVD will not eject.
Dec 27, 2011 | Televison & Video
Ite mate I have a technika flat screen 32" and I
the output power of your inverter is not constant... it needs constant input...
Apr 27, 2011 | Inverter 1000-2000w Peak Surge Power
Technika flat screen: Will not switch on, the blue standby light just flashes
Technika flat 32 screen: Doesn't not switch on, the blue standby light just flashes.
Apr 14, 2010 | Televison & Video
Technika optical wireless mouse not working
Make sure the mouse is linking to the wireless receiver on you have plugged into the computer (there should be a reset button on the mouse to establish a new link).
May 13, 2009 | Casio Parts Cash Register PC Desktop
Toshiba Satellite A200 -AH9 Wont Turn On.
maybe you have power conection problem
your problem maybe on the circuit after the battery
so you must check your circuit
or you can contact your Laptop manufucturers
Jan 21, 2009 | Toshiba Satellite A15-S129 Notebook
Televison & Video Logo
94 people viewed this question
Top Televison & Video Experts
