Question about Dryers
My dryer has a sort circuit somewhere and I need to figure out where. The heater turns on without the switch being hit. It also does not adjust it's heat. In other words it does not change between Low, Medium or High. Instead it stays high.
  • 3 more comments
  • deyoung5 Apr 25, 2010
    Th problem is I have replaced the heating element. I want to make sure I am headed in the right direction because we have replaced the timer, the high limit thermostat, and we still have the short.
    I meant short circuit
    I removed the wires from each element one wire at a time. I then tested the terminal and tested the body of the dryer. For each element it read Infinity. Not sure where to go from here.
    All of the parts mentioned read infinity to the chasis. Not sure where to go from here.
    What switch?
    President:
  • 949 Answers
If the heater comes on without the dryer running it can be one of two things that have failed.
The most common would be the element itself is shorted to ground. If something gets caught in the element or the element breaks and touches ground it has a path to always be on. In this case you could removed the element and replace it.
The second thing that can cause it would be the centrifugal switch internal to the motor. The heater is not suppose to come on with out the motor running and the centrifugal switch tells the heater the motor is on. This has to be checked with an ohmmeter and we have to have the wiring diagram.
Posted on Apr 25, 2010
  • Philip Apr 25, 2010
    Do you have the wiring diagram to follow? What we are looking for is a set of switch contacts on the motor that are in the heat circuit.
  • 10,865 Answers
Replace the switch and your problem should be solved. J.
    President:
  • 1,218 Answers
Good day,
That event usually occurs when a part of the heating element is touching the canister or some part of the cabinet.
However, if that checks out to be not true then.....
The heating element has 2 terminals. One normally goes right to one side of the 230 volt supply.
The other goes thru a series of controls, including all safety thermostats, control thermostat, heat selector switch and finally the timer itself.
All of the items described above are on and off switches which control the heater as to when and how it should be powered up.
If any one of those items shorted internally to the frame or chassis of the machine it would hold the power to the dryer all the time.
Each one would have to be tested with an ohm meter with it's separate wires removed to see if it is the culprit. The electrical terminals should read infinity to the chassis.
Lastly, a frayed shorted wire can create the same event. It would be a step by step procedure using an ohm meter and visual inspection.
The trouble shooting should be done in the order as described above.
  • John Hall Apr 25, 2010
    Good day,
    I would assume that one of the components or the wiring harness would be at fault. In fact it must be one of them.
    What is the history of this event. In other words what was happening to the machine to cause you to start this trouble shooting event ??
    What make, model and style of machine are we working on here, and as well, have you seen it working properly in the past ???
  • Dryers Master
  • 8,220 Answers
Your heater element is broken and welded to ground. To repair it you will need to know how to access the innards. More Here
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
  • 1 more comment
  • Dan Webster
    Dan Webster Apr 25, 2010
    Thanks
  • Dan Webster
    Disconnect each component till the short goes away. It is as simple as that.
  • Dan Webster
    Post your model number. That way I can consult the schematic. By knowing what brand you have and the model number I can do some research for you. You question is very generic in nature.
Tripping ELCB (RCB)
sounds to me like a short circuit in the heating coil circuit. One would have to ohm out the coils.
Jan 30, 2014 | Miele T8005 Tumble Dryer
Dryer heats but doesn't completely dry clothes.
See if you could turn the machine and remove the vent hose on the back.
Then, after you are sure it is clear, try a load of clothes with the vent hose blowing out into the air, not hooked to a vent hose pipe through the wall.
Very often, a plugged pipe will cause this behaviour. The pipe could be plugged in the wall or somewhere else.
Be blessed.
Feb 18, 2013 | Dryers
Amana electric dryer LE8317W2 tripped circuit breaker. Orange wire fried at end by heat element and was off terminal end. Also the purple wire was fried at thermostat end. I cleaned up connections and...
These units are totally repairable and will run for ever. Need to assume that other damage has occurred as a result of the failed shorted terminal connections.
Possible that the circuit breaker is defective caused by the dryer failure.
Assume that one of the components has shorted to the grounded frame of the dryer.
The 11 ohms of the heater is about right.
Confirm that heater element is not shorted to the dryer frame (heater housing)! This condition would have caused the initial wire terminals to fail and now trip the circuit breaker!
Use an ohm meter and check resistance between hot leads on back of dryer. Check resistance between each hot and neutral.
There is a switch located on the motor that connects power to the heater. When the motor is running the centrifugal switch closes. This saftey circuit confirms that the blower is running before heat is turned on. Check that the switch is not damaged from prior terminal short circuit failure, Repair kit is p/n WPL-501218
Timer is the next check. Same thing confirm that no damage to the switch circuits has occured. Last check thermal fuses and thermostars for short to netural.
Hope this helps?
Jun 25, 2017 | Amana ALE643RB Electric Dryer
Model 100HFL...with the light switched on I turn on the exhaust fan and the light dims a bit and the exhaust fan works. with the light switched on I turn on the heater and the light goes completely dark. ...
I'm not sure what is going on without full and complete description of wiring and switches:
Add a comment with exact information for possible help.
Specs say 20 amp circuit is needed: so 20 amp circuit breaker + 12 gauge wire are required.
Heater uses 1500 watts, so it pulls a lot of power if same circuit breaker is used for several other rooms and a TV etc. Turn off everything else and see if problem persists.
Sell sheet for product says: Energy efficient lighting - uses one 27-watt (max.) high efficiency GU24 based fluorescent lamp.
Turn off power, and disconnect ground wire. Turn power back on and switch on the heater-lite and see if there is a fault to ground.
Use a different switch.
Aug 11, 2011 | Broan-NuTone Broan...
Dryer is 10 years, keeps turning off breaker
Short circuit somewhere, could be heater/motor/ you need to disconnect the heater 1st to see if this is causing it if not then motor unplug it underneath.
Jun 24, 2010 | Dryers
The dryer will not turn on. I know I have power because the light is on. But nothing happens when I hit start
Check for a tripped circuit breaker (a ganged double breaker), sometimes only one breaker trips without tripping the other. Switch breakers off and then back on. If you have access to a voltmeter, check for 220 volts AC at the the two slanted slots in the dryer socket. Occasionally, one breaker of the pair will fail internally--replace the pair. If 220 volts is present, then problem is internal to the dryer. Usually, it is a short circuit in the heating element which causes the circuit breaker trip.
Jul 16, 2009 | Dryers
The reverse lights and heater stay on after the car is off.
It isn't a fuse. A fuse will break the circuit if it is drawing too much power. What you have is circuits that are connected by the ignition switch, that should be disconnected when the key is off. This means that the ignition switch is not operating correctly, and either needs adjustment or replacement.
Mar 14, 2009 | 1999 Ford Expedition
Dryer won't turn on
the heater element on the drier has gone short circuit.without a model no. its impossible to give more info.contact me on dazzie@blueyonder for more assistance.
Dec 29, 2007 | Dryers
Dryer is on and tumbling, but not heating up
Its very hard testing without a test meter.. volts and ohms. The Casing & heater is on the right side facing the back of the dryer. Metal silver in color, the heater is inside of the caseing. You can take the heater out and look for broken coils on the heater to see if it needs replacing. You have a to lift the top up to get at the top screw of the heater casing, take the 2 screws out of the flap where the lint filter goes. Use a putty knife to push the clips in on the front of the dryer and look to the back on the left side to remove the top screw of the casing. check the heater a post results.. theres many more things to check if the heater is good.
Aug 24, 2007 | Whirlpool LER5636P Electric Dryer
Dryers Logo
41 people viewed this question
Top Dryers Experts
