Question about GE Â 17.9 Cu. Ft. Top-Freezer Refrigerator
How do I get the icemaker to re-start after hooking up water line
Refrigerator was in storage, moved and hooked up new water supply line.
Now the ice maker won't cycle on. How do I get it to start making ice again?
    Scholar:
  • 126 Answers
THE FILL VALVE MAY BE STUCK CLOSED.
Posted on Apr 25, 2010
I have an Amana Side by Side Refrigerator with an icemaker and water dispenser. I don't have a water line to hook up to the refrigerator. Is there an on/off switch for the icemaker?
There should be a stop control near the icemaker where it collects ice in the tray. It should be an L-shaped lever. move it to the stop position.
Oct 02, 2012 | Amana Refrigerators
Ice maker won't work
Your inlet tube that goes to the icemaker may be frozen. To Check: Shut off water supply to Fridge, disconnect the water line that goes to the icemaker at top back. Use a flexible item to insert in the water line connection. I used a zip tie. If the flexible item won't all the through to the ice maker, the line is frozen. Thaw out the tube from inside the freezer with a hair dryer. Re-connect everything, you now have ice . . . Solution #2: You may have to replace your "Water Inlet Valve" located at bottom right rear of Fridge. Easy to do, just follow the color codes, be sure and shut off the water.
Jun 06, 2010 | Maytag MFD2562KES Stainless Steel Side by...
We recently moved and hooked up the water/ice. It
Replace the icemaker.
If the ice maker mold is tan or silver they are defective.
Moisture gets into the head unit and jams the gears.
You can remove the icemaker and let it dethaw for a day and it might start working for awhile.
The new redesigned icemakers are brown in color.
Hopefully the switch on the side of the I/M is turned on..
Jan 09, 2010 | LG LRFD25850 French Door Refrigerator
Hooked up waterline to side by side frigiedaire,
Jun 12, 2009 | Frigidaire GLRS264ZA Side by Side...
HOOK UP OF ICE MAKER TO THE WATER LINE
What you have in the back is a 1/4 tube which will feed cold water to the icemaker.
go to any hardware store and ask for an icemaker supply line kit. It will consist of a tapping valve, about ten feet of 1/4 inch tubing and a straight connector.
it will also contain step by step instructions.
You will have to determine what cold water line to tap into that is accessable. Perhaps the kitchen sink cold water supply if it is on the same wall as the refrigerator. Many times the line is run up from the basement.
enjoy your new icemaker.
May 21, 2009 | Kenmore 57029 Side by Side Refrigerator
Whirlpool refrigerator stopped making ice.
If there are ice cubes in the icemaker sitting there waiting to be dumped then the problem is in the icemaker. If the icemaker is dry then you have a water supply problem, even if you have a water in the door working.
1.Check the fill line inside the freezer at the icemaker, if it is clogged with ice then remove this ice and replace the water valve.
2. Check the water supply. Turn the water supply off, disconnect the water line from the Ref, turn the water back on an fill a small glass. If the water supply is good the solenoid on the water valve should be checked. This is done with an OHM meter.
If you got this far and need more info to DIY - ronbuice.com
Dec 13, 2008 | Whirlpool 25.6 cu. ft. Side-by-Side...
Kenmore ice maker
yes you need to hook up a line froun the cold water supply of the house to the water valve that is located at the back of the ref to the water valve that is down at the botton right corner
follow the water line from the top going into the icemaker down to the bottom there is where the valve is located behind the back cover
Apr 11, 2008 | Refrigerators
Ice maker not getting water in the line
The only other component stopping the valve from putting water into your icemaker is the icemaker itself. Replace your icemaker and you should solve your problem.
Nov 14, 2007 | Amana ARS2464B Side by Side Refrigerator
GE Â 17.9 Cu. Ft. Top-Freezer Refrigerator Logo
110 people viewed this question
Top Refrigerators Experts
Sal DeAngelo
Charles T Nevin
Charles T Nevin
Andrew Taylor
Andrew Taylor
