Question about Polk Audio PA250.2 Car Audio Amplifier
Light on remote wont turn on and it is connected to the amplifier
Light on remote wont turn on but it is connected to the amplifier
  • 344 Answers
Neg terminal to ground, positivew terminal to 12volt and jump a wire from posiitve to remote wire on amp to see if it turns on
Posted on Apr 26, 2010
Theres a light on inside my amp, but the power light wont come on. ive rewired it several times and it still wont work, i really dont want to buy a new amp. what do i do?
First and foremost, check your fuse at the battery terminal. Then make sure you are getting your 12V from your remote turn on, and lastly make sure all of the connections are properly terminated.
Sep 19, 2010 | American Pro VS1404 Car Audio Amplifier
The portection light on my alpine mrv-1507 wont let me get any sound
remove the rca wires and the speaker output wires and just leave the 12volt power/ remote/ and ground connected. turn on the radio and see if the light goes off. if it does then one of your speaker or rca wires are shorted, plug in one at a time and see which one gets you the red protect light, then find the short for that speaker/rca wire. if the red light turns on with only the 12volts/remote/ground, then the short is in the amp.
Feb 26, 2010 | Ohm Crystal Mobile Sound CADT 600.2...
My kenwood amp wont turn on all the way i just hooked it up to my truck. the blue lights and the fan come on but the red light wont come on to power my subs
REMOVE THE RCA INPUTS AND DISCONNECT THE SPEAKERS, THEN POWER THE AMPLIFIER UP WITH THIS NO INPUT, NO SPEAKER LOAD CONDITION. IF IT STILL DOES NOT POWER UP, VERIFY THAT THE POSITIVE AND ESPECIALLY THE GROUND CONNECTIONS, ALONG WITH THE REMOTE CONNECTIONS ARE 100%, THEN TRY AGAIN. IF STILL NOT POWERED UP, MEASURE THE REMOTE WIRE VOLTAGE TO INSURE THAT IT IS NOT LOWER THAN 11 VOLTS. IF YOU CANNOT MEASURE IT, THEN DISCONNECT THE REMOTE LEAD FROM THE AMPLIFIER AND TEMPORARILY INSTALL A JUMPER WIRE FROM THE POSITIVE POWER TERMINAL TO THE AMPS REMOTE TERMINAL WHICH WILL FORCE IT TO TURN ON. IF IS STILL DOES NOT POWER UP, THEN IT WILL HAVE TO BE SERVICED. LET ME KNOW IF YOU NEED FURTHER ASSISTANCE.....V
Nov 20, 2009 | Kenwood KAC-7203 Car Amp
Amp will not come on ,no light
Yes!!!!!!!!!! Your remote wire is what tells your amplifier to turn on and off it won't work without it. Assuming your stereo headunit is an after market unit it has the correct wire for this. what you have to do is pull out you headunit, and in the back of the headunit where all the wires plug into your unit there is blue wire with a white stripe. this is the remote turn on wire. connect a wire to that blue n white wire and run it back to your amp, insert it into to the spot marked remote. turn your head unit on and your amp will power up... if you have all the rca cables hooked up your amp should be ready to go.... btw good choice on the amp, kenwood is the way to go!
Aug 31, 2009 | Kenwood KAC-9152D Car Audio Amplifier
Car amp not turning on
double check your remote wire or the ground. make sure you have atleast 9vs to the remote.
May 07, 2009 | Kenwood KAC-7251 Car Audio Amplifier
Amp neon lights wont turn off
There are two types of power that feed your amplifier. There is a constant power that connects directly to the battery and there's a remote power that usually connects to the remote power output of your deck. Some decks do not have the remote power output, but they have a power antenna output that works just as well.
The remote power is what enables the amplifier to turn off when the car's power turns off.
Either way, it sounds like you have the remote power input on the amp connected to your constant power source.
That would prevent the light from turning off with the car.
If you don't have a remote power or power antenna output on your deck, I would invest in a new one.
However, it is relatively easy to find a remote and a constant power source in your fuse box.
Purchase a fuse tap for a few cents and connect the remote power input on the amp to a power source in the fuse box that turns on and off with the ignition.
Some of the power sources you can find in your fuse box that go on and off with the ignition may be labeled something similar to the following:
ignition, power windows, radio, accessory, etc.
The constant power sources in your fuse box are the ones that don't power off with the car, such as the dome/interior light, power locks, battery, etc.
I hope that some of this helps out a little.
Dec 04, 2008 | Car Audio & Video
Car amplifier wont turn on
Your best bet is to call Alpine directly at: 1-800-832-4101
Jul 15, 2008 | Alpine PDX-1.1000 1000W x 1 Car Amplifier...
Xm 1002 hx
1. What type of head unit are you using
2. does the head unit have a Loud feature?
- Sometimes you have to press the loud button on certain head units to engage the amplifier.
Try disconnecting your remote wire from the amplifier, grabbing a piece of small 12 or 16 gauge wire and bridging the remote wire with the (+) on the amplifier. if your light does not turn green, then check your fuse and the ground for the amplifier itself and the subwoofers.
When you connect the remote wire to the (+) it should automatically turn the amplifier on even if the cd player isnt on. The reason I want you to try to connect the remote and power is because sometimes the remote wire for the cd player is bad. If it does end up being a bad remote wire from the head unit, then your best fix would be to connect the red wire (ignition 12v) on your head unit to an on/off switch to the remote on your amplifier. You can then turn your amplifier on and off by flipping the switch. If you go to autozone or advanced auto parts you can pick up a toggle switch for about $3.00.
Feb 20, 2008 | Sony Xplod XM-1652Z Car Audio Amplifier
Blown amp
hi, try connecting the power b+ and gnd and remote turn on cables only (dont connect rca input or any spks), if amp doesnt turn on you will have to take in for repair. no need to buy new amp, coz problem could be a burnt pcb track or even a faulty remote or FET circuit.if amp turns on then connect other cables slowly and monitor the power lite as you do connections. you may have a faulty spk load that will cause amp to stay off or in protection mode. cheers
Jul 22, 2007 | Kenwood KAC-7202 Car Audio Amplifier
Connecting remote cable to other port from the car stereo
You can tap the amplifier's remote wire into the accessory power lead at the back of the head unit. On most head units this is a red wire. Doing this will make your amplifier turn on and off with the key switch, rather than the deck power.
Jul 01, 2007 | Sherwood XCM-6870R CD Changer
Polk Audio PA250.2 Car Audio Amplifier Logo
117 people viewed this question
Top Polk Audio Car Audio & Video Experts
xxxxxx xxx
Are you a Polk Audio Car Audio and Video Expert? Answer questions, earn points and help others
