Question about HP Photosmart C5180 All-In-One InkJet Printer
Photos are printing with poor tone and color. cartridges are new. how do i adjust?
  • 4 Answers
Take the cartridges out and see if the ink is coming out evenly on the tape. It can also be the quality of photo paper you are purchasing. I found Kodak brand works best.
Posted on Apr 25, 2010
Have put new cartridges in and only prints yellow lines
Remove all cartridges, make sure any tape has been removed from over the nozzle. Ensure that everything has been installed properly, then use your printer (prompts on device, or in printer>control panel) to print some test pages, realign heads, etc.
May 05, 2011 | Canon Computers & Internet
Canon Pixma yellow color problem
Either the ink you are using is not going to give the color you want, or you have print heads that are blocked.
Mar 11, 2010 | Canon PIXMA iP4200 InkJet Photo Printer
Prints are green
bad or poorly refilled ink cartridge, and possible color misalignment at setup of new ink cartridge. Redo your ink settings thru ur alignment and cleaning service for your cartridge and try it again. Ive had poorly refilled ink cartridges and do reely suspect urs as having been poorly refilled...
Jan 18, 2010 | Canon SELPHY DS810 InkJet Photo Printer
Poor photo printing quality with new color cartridge
Shaking these cartridges does nothing except give you a little exercise. If this is a brand new HP cartridge you are having problems with I would return it to the store you purchased it from. HP brand cartridges should not give you these problems right out of the box. The print defects you are seeing are due to a dried up or clogged print head. If you like you can try hydrating the print head on a water soaked paper towel until the ink starts flowing, but there's a risk you will cross contaminate the colors.
Oct 08, 2009 | HP PhotoSmart C4480 All-in-One Printer ...
I put in a new photo color print cartridge in Photosmart CA4280 and my pictures print out in pink tones only
take the cartridge back and get it replaced with a new one. most dealers will replace a faulty cartridge without too much question.
Jul 15, 2009 | HP Office Equipment & Supplies
MP610 with poor photo printing, colors off, low quality
Adjust the driver settings and you will have success.
Jul 08, 2009 | Canon MP610 Photo All-In-One Printer
Oh, it's the colors you are having a problem with. Then you probably want to perform an Auto Gradation Adjustment. It's on pages 162-163 of the manual found here: http://download.support.xerox.com/pub/docs/DocuColor_3535/userdocs/any-os/en/3535_User_Guide.pdf
Here is what it says:
Auto Gradation Adjustment is a color calibration for the copier and printer. An Auto Gradation Adjustment compensates for differences between the actual and the expected toner densities for each color. An Auto Gradation Adjustment should be performed whenever there is a noticeable change in the appearance (quality) of the output, particularly changes in color
tones or densities. Performing an Auto Gradation Adjustment on a regular basis will help to maintain consistent color quality over time.
NOTE: Since an Auto Gradation Adjustment can affect all jobs for all users, it is recommended that this procedure be performed only by the Machine Administrator.
Copy Job - Text Compensates tones when a text original is copied.
Copy Job - Photo Compensates tones when a photo original is copied.
Print Job Compensates tones when printing with controller line screen.
Network Controller - 1 Compensates tones when printing with Network Controller screen type 1.
Network Controller - 2 Compensates tones when printing with Network Controller screen type 2.
NOTE: Printing the chart for Auto Gradation does not increase the meter count.
NOTE: When gradation adjustment is executed, the following
changes will be made to default copy settings set in System Settings mode: Copy density = Normal or Auto, Color Shift = Normal, Saturation = Normal, Color Balance = 0, Sharpness = 0.
NOTE: When Print or Network Controller gradation adjustment is executed, the printer’s output profiles for the available screen types are compensated.
1 On the Image Quality Adjustment screen, select Auto Gradation Adjustment.
2 Load 8.5x11 inch or A4 paper into Tray 5 (Bypass). Move the paper guide to gently touch the edge of the paper.
3 Select the desired gradation adjustment screen:
• Copy Job - Text
• Copy Job - Photo
• Print Job
• Network Controller - 1
• Network Controller - 2
Press Start. The Adjustment Chart is output.
4 Place the Adjustment Chart face down on the Document Glass with both Magenta color patches against the left side of the glass.
5 Place 5 sheets of white paper on top of the Adjustment Chart and close the DADF. Select Start.
6 To continue Auto Gradation Adjustment with other screens, repeat steps 2 to 5. When you are finished, select Close until the System Settings screen is displayed.
7 Select Exit to exit the System Settings mode.
Jun 24, 2008 | Xerox DocuColor 3535 Copier
Poor color printing quality
do you have the canon print management software installed? it's located in the maintenance tab on that software.
www.canon.com has that by model number
Jun 16, 2008 | Canon PIXMA iP3000 InkJet Photo Printer
Color is way off
Hi , need head cleaning , until the color will have true color .
use original canon ink cartridge you will satisfy sharp colors.
Jan 13, 2008 | Canon PIXMA iP1500 InkJet Photo Printer
HP Photosmart C5180 All-In-One InkJet Printer Logo
57 people viewed this question
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
