Question about Cell Phones
Lg keybo 2 cannot one step voice dial Ie: call bob home... i can only go call wait for her to ask name or number then continue... otherwise it goes to the first name on the contacts list. i have adjusted sensetivity etc.. and it still cant one step
Has the same issue and every tried every kind of reset possible with no luck.
THE FIX:
After you press the voice command key you will hear the system state: "please state the command or number to dial" (or something close to this) and then a beep.
YOU MUST WAIT FOR THE BEEP BEFORE STATING THE NAME!
This has been a huge headache for me and LG has not been a great help. On my other LG phones I would say:
"Call so and so" without a pause or waiting for a beep in continuous voice string.
You must wait for the beep on the Keybo 2 and apparently no one at LG knows this?!
Hope this help someone else.
Posted on Nov 05, 2010
How to reset an lg keybo
From Telus Mobility website at http://mobility.telus.com/en/AB/LG-9100-Keybo/device-details.shtml LG KEYBO 9100 Reset your phone to its original state There are several reasons that you may want to reset your phone to the original factory settings. For example, you may be giving it to someone else, or you may find yourself with no other way to resolve a serious issue such as a frozen screen. CAUTION:
Resetting your phone deletes your ringtones, contacts, pictures, messages, and other downloaded content.
  1. From the Home screen, press the OK key.
  2. Select Settings.
  3. Select Phone Settings.
  4. Select Security.
  5. Type your lock code. This is typically the last four digits of your phone number (unless you've changed it).
  6. Select Reset Defaults.
  7. Press the OK key to confirm.
  8. Select Revert.
Your phone is reset to its original factory settings.
If these steps are unsuccessful, visit a Product Care Centre to have your phone inspected. Use our Store Locator to find the closest location.
Nov 19, 2012 | LG Telus Keybo 2 CePhone Pink - Keybo 2
How do I change the number of rings on my lg phone before it goes to voice mail
This is usually set by your network provider, so you have 2 choices.
1) Call the network Customer Service number and ask them to extend the time before it diverts.
2) Try the following network code to change it yourself:
**61*XXXXX**TT# (then send/dial)
XXXXX = The number you dial to access your voicemail (if it starts with a zero remove it)
TT = The time in seconds before diverting. The maximum value is usually 30, although some people report problems when using 30 seconds. I believe the maximum is specified by the individual network, so try different value 15 / 20 / 25 / 30.
Jun 19, 2010 | LG RUMOR Cellular Phone
When sending a picture from my telus LG Keybo 2 - it says "send Media to Recent" - how do I delete those numbers and email addresses?
Go to Messaging> Send Message> Voice SMS> Recent List> Options.. then simply select the contacts you want to delete or delete all. :)
Jan 05, 2010 | LG KC910 Renoir Cell Phone
I am trying to connect my palm treo with my lg keybo 2 using bluetooh in order to transfer my phonebook. the keybo finds my treo but when prompted for the passkey at the pairing window it always fails. I...
LG has a couple bluetooth keyboards. do you have the model number?
by the way are you pairing the keyboard to the treo or the treo to the keyboard?
normally there are 4 zeros are the normal passkey numbers for the keyboard
Nov 29, 2009 | Cell Phones
Can't Set up Voice Dialing
Are you saying "name dial" first? Name dial works only with the contacts in the PHONE contact list/ address book, otherwise you have to say "digit dial" and repeat the number.Also make sure you have gone to settings>personalize>voice dial set up, first.
Aug 29, 2009 | Motorola Mobility RAZR V3x Cellular Phone
Voice Mail
If your voice mail is a Panasonic brand, from remote you dial #6 * and your extension. Then put in your password and it's just like you logged in from the phone at your desk.
Carl
Feb 05, 2009 | Panasonic KX-T7630 Corded Phone
Voice dial?
Voice Command
To activate voice commands:
1. In your menu, go to MY STUFF MENU
2. select TOOLS
3. select Voice Command
4. Enable the on/off option
How to use it:
Call <Name or Number>: This function is activated only when if user says command “Call” and name stored in address book or specified phone number. Handset, voice engine inside recognize users utterance handset, displays name lists from your phone’s address book or phone number, however noise might caused to display candidates. Additionally user can superimpose number type at the end optionally, such as “mobile”, “home” or “office”.
Hope this helps & happy holidays!
-TJ
Dec 15, 2008 | LG Vu CU920 Cellular Phone
LG 830 Vantage Cell phone voice dialling
With the slider up. Hold down the send key. Follow the instructions. The voice asks who you want to call. If you close the slider you can use the speaker phone.
Nov 06, 2008 | LG Cell Phones
RCA Model 25204 2 line speakerphone corded with call waiting caller ID
As bsmither said, how voice mail is accessed is very dependent on your phone company and how they've set things up. They would be the best place to ask about any problems you're having there.
As for programming the voice mail buttons on the 25204, I was confused by that one as well until I finally figured it out. Specializations aside, they're just speed dial buttons, and are programmed in exactly the same way as the ones along the right side of the phone. RCA could have documented that detail better than they did.
In my case, with Vonage, I just programmed the buttons with the numbers for the lines that they're associated with. When they dial and I'm connected to the voice mail system, I'm prompted for my VM password, which I then enter manually.
Jan 30, 2008 | RCA 25414RE3 Corded Phone
What is voice tag of H350 headset?
Voice tag is what enables you to call by speaking. So say you have a contact named Bob on your phone. You press the button and the phone beeps and you say "Bob" to call him. If you say it clearly, the phone will display Bob (and possibly any other contact that is close in name to Bob). If you don't do anything within a few seconds, it will start dialing Bob. That is the voice tag. My guess is your phone does not support voice tag or you dont have any voice tags assigned to your contacts. You will have to call from the handset, not the headset.
Dec 26, 2007 | Motorola Mobility Bluetooth Hands Free...
Cell Phones Logo
273 people viewed this question
Top Cell Phones Experts
Computer Repairing
Computer Repairing
William Alequin
Are you a Cell Phone Expert? Answer questions, earn points and help others
