Question about Troy-Bilt 4-Cycle Curve Shaft Gas String Trimmer #41ADT41C966
Fuel primer bulb broken
Can I replace just the fuel primer bulb on a troy-bilt tb425cs?
StickyBeets
SOURCE: put string on tb425cs troy bilt trimmer
there are two ways to install the string..the cool way is without pulling the inner reel off the trimmer..just leave it in place..cut (2) approx.two arms length (thats spreading your arms out like airplane wings) of .095 string..now, align the arrow of the inner reel (it turns counter clock-wise..the arrow points outward) with the arrow on the outer spool (pointing inward)..holding the spool and reel together so the inner reel doesnt move, push one of the cut strings through the eyehole in the side of the outer spool, and it should come up to the right, through a slot next to a small round hole the diameter of the string..if it doesnt, it just missed the exit (as i call it)..pull out and try again..let about an inch come thru..now take that end of the string and push the line into the little round hole until it stops, which should be about a little more than 1/8 of an inch..hold it in while pulling the excess line outside the spool to keep it in place..now do the same with the other string for the other side..once you have both lines in place, turn the inner reel counter clock-wise to draw in both lines through the eyeholes of the outer spool..you may or may not get all of the line to wind in..not a problem..you will still have enough to do what you need to do..just cut off the rest..one problem you may or may not have that i do most of the tyme is that it gets hard to turn the inner reel..one solution is to bump the top of the 'bump knob' with your fist, then pull both strings at the same tyme, then continue to turn..this method is quicker and easier than the second way of having the inner reel out and trying to wind both lines at the same tyme and trying to place the reel back in the spool..hope this works for you...
Posted on May 19, 2009
#1 Taper
  • 1040 Answers
SOURCE: Troy Bilt TB 465SS Pony 4 cycle weed trimmer won't start
Sounds like you need to take the carb. apart and clean it. I like to use a Den Tek Brush, (used for cleaning teeth), to clean the small ports in carb. they work great for this job. Make sure to either clean or replace the small screen in thcarb. as well.
Jim
Posted on May 26, 2009
  • 199 Answers
SOURCE: primer bulb won't prime
it sounds like the filter on the fule line is cloged try to remove the filter and then try to prime the trimmer. it it does you need to replace the filter. just about any filter that will fit will do.
Posted on Jun 10, 2009
s_s_m_o_k_i_
  • 162 Answers
SOURCE: My troy-bilt TB425CS gas string trimmer gas lines
far enough so that you can reach through filler cap and pull the line out to attatch fuel filter.
then you can pull it back in and let it rest on the bottom of the tank
Posted on Aug 15, 2009
  • 1206 Answers
SOURCE: My kill switch on my troy bilt TB425CS doesn't
its just a switch that grounds out the coil remove the switch and replace it with any that connects two wires to currentso when on the two wires are connected that should fix it if not follow the wires to where they end and check the connections.
Posted on Mar 09, 2010
How to replace troy built tb25cs primer bulb?
The primer bulb has two clips that fit into a slot. You will have to squeeze both clips to pull it out. Make sure you remember which fuel hose went on each nozzle of the primer. There are two nozzles. Make sure you put the fuel line back on the same way. The part # for the bulb if you need it is a Walbro 188-512-1.
May 27, 2014 | Troy Bilt Tb70ss Gas Trimmer
Which fuel line is the intake line at the carburetor?
The fuel line goes:
  1. From the filter in the tank to the carb, usually the bottom most connector.
  2. From the carb to the Primer. The tube in the center of the primer bulb.
  3. From the primer, outer tube to the fuel tank.
Get the manual online from Troy-bilt herehttp://www.troybilt.com/equipment/troybilt/tb146-ec-4-cycle-garden-cultivator
j
May 07, 2014 | Troy-Bilt TB146 EC 4-Cycle Garden...
PRIMER BULB ON TROY BILT 144 TILLER WILL NOT FILL
look for a cracked fuel line or a split in the primer bulb
May 17, 2012 | Troy Bilt Tiller/Edger 26cc, Model No....
Primer bulb does not work
if you have gas in the primer bulb its working. gas is sucked from tank to carb , out return tube to primer bulb and back to the tank from the primer bulb. most likely dirt in carb or hard diaphram not opening needle valve allowing fuel to be sent. carb kits are around 12 bucks . but carbs for troybilts are usually only 20 bucks. I would just replace the whole carb if the case. if the bulb stayed empty I would look for broken fuel line in the tank that holds the fuel filter. they rot and break off within a year or two.
Apr 20, 2012 | Troy-Bilt Mtd Troy Bilt TB4218CC 42cc 2...
Need to replace fuel lines on my Troy Bilt 4 cycle weed eater model number TB575CS. Where do the green and clear lines go into the tank?
Hi plomelino...
Maybe this diagram will help determine which fuel line goes to what connection
Please take time to rate me
Sep 13, 2011 | Troy Bilt Tb425cs 26cc 4 - Cycle Curved -...
Troy-Bilt TB425CS Grass Trimmer. The purge/primer bulb does not pull fuel from the fuel tank.... There is no visible fuel in primer bulb when the bulb is pushed.
You may have a fuel line, fuel filter problem. I recommend inspecting and/or replacing old fuel lines as they get old, brittle, flaky, and develop pin hole leaks in the fuel tank and around the carburetor fittings. If you choose not to replace them, problems will surface down the road. Sometimes the check valves in the carburetor that open and close to keep the fuel moving in the proper direction malfunction. They can sometimes be cleared with a lubricant such as WD-40 but real strong solvent tends to ruin them. A primer bulb on the carburetor is easier to service as you can remove the primer bulb base assembly (mounts on carburetor with screws) and spray WD 40 liberally into the pump area. A remote bulb is a little trickier, as you have to either inject the lubricant spray into the fuel lines and attempt to get the bulb to draw it to the carb to free check valves inside. This is if you don't want to remove the lines and service the carburetor. Also, a new bulb may be needed. Thet deteriorate the way the fuel lines do. They are rather inexpensive and you can get kits that include the new fuel lines, filter and bulb all together. Some of these parts are available in the garden center at Home Depot and many are on Ebay. Post back if further instructions are needed.
Apr 28, 2011 | Craftsman 25cc Gas Line Trimmer
We have a troy bilt snow blower 1 yr old and we are trying to start it. When we try to prime it, the primer bulb does not seem to be moving any fuel. It just sounds like air. It will not start. We have...
Are there two tubes connected to the back of the primer bulb?
If it is connected, then the primer bulb itself could be cracked, allowing air to enter, but not fuel.
See if you can gently pry or possibly unscrew the bulb for replacement. They are readily available.
Gary
Dec 10, 2010 | Troy Bilt 5.5hp Self Propelled Mower
Engine willnot start
Try taking out the spark plug,see if its wet,is the primer bulb ok?does the bulb fill with petrol when you press it,if this is ok,check the carb for dirt,and or the tank,is your petrol mix correct,as this makes a big difference to the run ning of the machine,rgds
Sep 26, 2010 | Troy Bilt Tb425cs 26cc 4 - Cycle Curved -...
The fuel tank is cracked at the top by the cap.What site can I go
Can't help with the tank, but your better auto parts stores do sell an epoxy that is designed to seal plastic fuel cells.
Apr 26, 2010 | Troy Bilt Tb425cs 26cc 4 - Cycle Curved -...
Primer bulb won't prime
Jun 05, 2009 | Troy Bilt Tb70ss Gas Trimmer
Troy-Bilt 4-Cycle Curve Shaft Gas String Trimmer #41ADT41C966 Logo
134 people viewed this question
Top Troy Garden Experts
Matt Olenzek
Matt Olenzek
DROPNDEAL
DROPNDEAL
Wade Mobley
Wade Mobley
Are you a Troy Garden Expert? Answer questions, earn points and help others
