Question about Jandy Stealth 2 HP UR Pool Pump SHPM2.0 SHPM20
Our pump has lost its prime. How do I prime it again?
    Renaissance:
    An user who is expert in 3 categories / brands.
  • Jandy Master
  • 1,448 Answers
Fill pump basket with water put top on and turn pump on
Posted on Nov 12, 2014
Recently purchased a goulds pump mod #c48a93a06. Lost power for about hour. Electric returned but water never came back on. Should I have to prime the pump again on a new unit?
See if the motor is running. You should be able to hear it. If it is then you need to check the prime. If it is a prime issue then the motor runs the risk of never shutting off and could overheat.
Nov 20, 2017 | Plumbing
How do I prime the pump on my VS500
The pump will prime when you turn on the circuit breaker. There is a prime cycle that will run for a couple of minutes to get all the air out of your spa system before the heater will engage.
Rod
US Parts Center
888-521-6183
Apr 05, 2013 | Pool & Spa
How do i reprime ?
Close the supply valve to the tank. Open the priming port of the pump, (plug on the upper most part of the casing) pour in water until the pump is filled -up. Close the plug just finger tight. Run the pump. slightly open the plug just to bleed the air with little water. If all water is coming out, the pump motor should cut-off indicating the pump is already primed. Gradually open the supply valve. Pump motor will restart again.
Nov 12, 2012 | Fresh Water Systems WellMate Tank Fittings...
WATER WELL WILL NOT PRIME OR PUMP WATER
replace the mechanical shaft seal. check impeller and diffuser for damage . prime pump after any repair
Dec 19, 2011 | Sta Rite Pool & Spa
Pump does not pump anything. motor is running and getting hot, no water being pumped. i have to prime this stupid thing?
If you are trying to draw water from a lower place, you may have lost prime. It is also possible there is a reason for this loss of prime, maybe a leak on the suction piping. Remove some fitting on or near the discharge of the pump, fill the body completely with water. If it goes in, fill the entire suction piping with water, too. Open a faucet nearby, turn on the pump and wait up to 5 minutes. It should spit and sputter, sound will change, some water will discharge, but eventually, you should get steady flow.
If you lose prime again, look for leaks in the suction piping from the inlet of the pump to where the piping goes into the ground.
Your FixYa Texpert,
Gary
Aug 16, 2011 | Flotec Corrosion Resistant Shallow Well...
I cannot get the pump to draw water. I have made sure the line is clear and that there are no leaks.
sounds like the pump has lost its prime there for it will not pick up the water it kinda like a fuel pump on a vehicle so u should try filling pump were its suction is an reprime it manually until and start it but dont run all the water out or it will lose prime again its lot easier if i was doing it my self than telling someone hw but just try wat im telling u and u should b able to get it back on track and running like new once again
Sep 13, 2010 | Sta Rite StaRite DuraGlas Pump 34 HP...
I replaced CVA-24 VALVE....now when I turn on pool filter no water being pulled through..no water being pulled through to pump
Your pump has probably lost its prime. This is either because it got too much air or not enough water. Try priming. This should make your pump start working again. Any time pool pumps have to be services, they need to be re-primed. In case you are not sure how, remove the pot lid and fill the pot with water. Re-add and clamp the pot lid. Open the air release valve on the filter and stand clear. Turn on switch or time clock. When water comes out of the air release valve, close the valve. If it is a two speed pump, make sure it is on high speed.
Aug 20, 2010 | Pentair 3hp Whisperflo Pool Pump In -...
2 hp Swimming Pool - Jet / Well Pump Motor / Century B124: Water pump from swimming pool to filter lost it's ...
NOT THE MOTOR ,THE SEAL... JET PUMPS ARE NOT FOR POOLS.. LOW FLOW HIGH PRESSURE.. YOU NEED HIGH FLOW LOW PRESSURE ... IF NOT YOU MAY HAVE A SUCTION LEAK OR A BAD SHAFT SEAL... VOTE JAY
May 17, 2010 | AO Smith 2 hp Swimming Pool - Jet / Well...
I have a Sta-Rite Max-E-Glas II (1.5hp) Pool pump and a Hayward Navigator sweep. The sweep was working then stopped. Pulled it apart found bad bearings replaced them. Ran sweep again worked at first...
Is the pump leaking water? If you lost the prime or are having trouble priming then there would be an air leak somewhere on the suction side of the pump. Poor suction would interfere with the sweep. One way to ell if the pump or suction line(s) are leaking is to examine the inlet basket once the pump is primed. Any air left in there after a few minutes of operation once primed would indicate a leak in the suction/pump.
Jan 04, 2010 | Zodiac BARRACUDA G3 IN-GRND CLEANER
Jandy Stealth 2 HP UR Pool Pump SHPM2.0 SHPM20 Logo
243 people viewed this question
Top Jandy Pool & Spa Experts
David Spradling
David Spradling
Craig Butler
Craig Butler
Jay Finke
Jay Finke
Are you a Jandy Pool and Spa Expert? Answer questions, earn points and help others
