Question about Nokia N95 Cellular Phone
N95 incoming caller id issue
I upgraded to N95 from N73 and immediately updated the phone software to v20. I have contacts I transfered from from my N73 and the numbers are either stored with the counry code or without (eg +268 for Swaziland).If I have a number stored as (+268) 6029173 which is a local number, when I receive calls from a local number the name does not appear despite being stored in my contacts. If I however receive an sms from such a number, the name will reflect as recorded in my contacts. Vise versa applies. This is similar to the Samsung issue. Is this a settings issue on my phone or part of the n95 software? I have checked that I do not have duplicated contacts either on the phone memory or sim card.
    Brigadier General:
  • 7,752 Answers
You should try and add your contacts to your phone memory........remove the + from the number
Posted on Mar 24, 2008
If your phone freezes, hangs up unexpectedly, vibrates continuously ,touch screen wont respond or in other similar ways doesn't perform as it should, this can often be solved by performing a software update. Software may perform incorrectly for many reasons without there being a fault in the phone. Some problems may be fixed by re-updating your current software, while others may require installing a new software version.
To keep your phone performing at its best, it's a good idea to perform a software update regularly. You might not always notice what an update has done, but it can prevent future problems.
To update or reinstall the software please go to nearest authorized service centre of your mobile make and they will update or reinstall the software as required.
Note: Reinstalling the software will delete all the content in your phone like contacts, calendar entry etc.
Thank You
Feb 25, 2011 | Nokia N95 Cellular Phone
Frozen N95
kindly reset like below or pls update ur phone firmware from NOKIA download update application from for ur mobile N95 and it will help u in this software issue
but pls first try to reset the device like this it may resolve it
Option 1
Press Call + 3 + * simultaneously during the bootup phase, forces the N95 to do a complete wipe of internal memory.
This will reset the phone back to 100% standard factory configuration.
Option 2
Master reset
1) *#7370#, then enter 12345 (This is the default security code unless the user has changed it) and then Yes. The phone then wipes all apps and phonebook contacts on the internal memory.
May 19, 2009 | Nokia N95 Cellular Phone
Nokia N95 will turn on but not work
You may erased settings possibly a database on your phone. Best bet is to take the phone into provider.
Although you can go to either or your providers webpage and see if they offer an upgrade for the OS on the phone. I would then download the upgrade or even the original if no upgrade is found and this should fix the issue.
To update your firmware/os you will need to go to the nokia software site and connect your phone to your computer via a data cable or if it's available you can update your N95 directly over-the-air. Here is the link:
Try one of the above to see if it resolves your issue. let me know if it does.
Jan 14, 2009 | Nokia N95 Cellular Phone
My nokia n95 8gb doesnt display some incoming callers names?
Call ID must be activated in your phone. Your cell phone provider customer service must help you with that.
Jul 20, 2008 | Nokia N95 Cellular Phone
N95 always hang after update to V 20.
when it is hang just open the phone that is open the slide one it work normally and same for the video ply
May 22, 2008 | Cell Phones
Connection problem between a nokia n95 8gb and zumo 550
I have recently purchased a Zumo 550 and successfully copied across selected phone book entries from a Nokia N95 without the need to use any additional apps:-
1) Assuming the N95 and Zumo are paired via BlueTooth
2) In N95 Contacts - use 'Mark' / 'Mark All' as necessary to select the contact entries you wish to transfer to the Zumo 550
3) In N95 Contacts - select 'Options' then 'Send Business Card' then 'Via Bluetooth'
4) Select the Zumo 550 device from the list of paired Bluetooth devices
5) Contact data is transferred from N95 phonebook to Zumo 550 phonebook
Interestingly, Garmin don't seem to list the Nokia N95 as being a supported device on their website, but the above process worked for me!!
Feb 15, 2008 | Garmin zumo 550 GPS Receiver
Error code 9999
okay, if i were you i would try to upgrade to the latest firmware, v20 using the software updater!! apparently they have fixed loads of bugs, including the front camera!!
hope this helps
Dec 03, 2007 | Nokia N95 Cellular Phone
My phone keep freezing from time to time
the phone itself has many gliches similar to this. only solution would be to get an upgraded firmware, or get a new phone. if all fails, contact nokia services, or your cell provider.
Sep 11, 2007 | Nokia N95 Cellular Phone
Nokia N95 Cellular Phone Logo
87 people viewed this question
Top Nokia Cell Phones Experts
Computer Repairing
Computer Repairing
