Question about Encore Garden
Trying to replace the pump belt on an Encore Z52 lawn mower. If the idler spring is hooked up the belt is to small to thread onto pulley. With out the spring the belt goes on but do not have a way to attach the spring.
5 Suggested Answers
SOURCE: Weedeater Clutch Spring Replace
Counter man at the local mower repair shop said to use a thin rope. Tried it and it works great. Think I over engineered this problem.
Thanks for your help.
Wayne
Posted on Sep 23, 2008
mowerman1857
  • 389 Answers
SOURCE: CRAFTSMAN Tractor Model%23 917257643 adjust idler
First things first! Before you installed the new belt, did you check the blades and idler pulleys to see if they all turned freely with no resistance while the belt was off and the blade brakes released? Release the blade brakes by engaging the handle with the engine off!
When you installed the new belt, did you put the back side of the belt against the flat pulleys and the inside of the belt in the V-pulleys? Did you double check to make sure you didn't inadvertently miss a belt guide getting the belt on the outside of it instead of underneath it. Did you look at the picture in your owners manual to make sure you had it routed correctly and make sure it is not rubbing against anything when you have the blade lever engaged? CHECK THIS WITH THE ENGINE OFF If you don't have your owners manual, look under the foot boards on the tractor, many of the Sears tractors have the routing diagrams there. If it is not there you can go to searspartsdirect.com , enter model number 917.257644 (NOTE the number difference) and look at the picture of the deck, it shows what the belt should look like when it is installed. You can also download an owners manual there. As best as I can remember, there is no adjustment for the idler pulleys.
Posted on Oct 25, 2009
  • 146 Answers
SOURCE: 609 yard machine tractor idler pulley spring broke
Here's a diagram, not a great copy, but it may help:
The spring hooks to the idler arm on the opposite end from where the pulley is mounted. The other end of the spring looks like it hooks to a raised tab on the deck, straight behind the left mower spindle. Hope this helps you, please rate my solution if so, thanks!
Posted on Jun 08, 2010
  • 14 Answers
SOURCE: murray riding lawn moweer Need a diagram of how to attach a drive belt on a murray riding lawn mower 425613X8A DIAIGRAM
search google for diaigram
Posted on Sep 22, 2012
I need help putting rear end back together on a 10 hp30 Murray riding lawnmower
Safety and Preparation Serious injury can occur if the engine or mower blades accidentally start while you are working with lawn tractors. To prevent this, drive the Murray lawn tractor onto a flat work surface and disengage the mowing deck cutting blades. Engage the parking brake to keep the mower from moving; chock the wheels with a wooden block or brick. Adjust the mowing deck to the lowest position. Turn off the engine and remove the key from the ignition. While not necessary, you may even wish to disconnect the spark plug wire from the spark plug. Mowing Deck Removal You must remove the mowing deck on a Murray lawn tractor to gain access to the belts. Remove the adjustment rod hairpins, followed by the adjustment rod pins from the front left and right sides of the mowing deck. At the rear on the left and right sides, pull out the retaining hairpins and slide the mowing deck suspension links from the adjuster plates to separate the rear mowing deck from the frame. Remove the blade control rod stud, including the hairpin and washer, from the top of the blade control lever shift linkage at the left rear of the deck. Remove the front hanger rod, including the hairpin and flat washer that hold the rod in place. Loosen the belt guide retaining bolts with a socket wrench and remove the engine stack pulley belt so you can slide the mower deck out from under the tractor Transmission Drive Belt Installation Slide the new transmission drive belt between the engine stack pulley belt guides, over the belt guide plate and under the engine stack pulley. Fit the transmission drive belt around the top engine stack pulley. Push the free end of the transmission drive belt up through the transmission shifter hole in the lawn tractor floorboard. Slip the transmission drive belt loop over the transmission shifter. Pull the transmission drive belt down through the transmission shifter hole. Fit the transmission drive belt around the transmission drive pulley and tighten the transmission drive pulley belt guide retaining bolts to hold it in place. Fit the transmission drive belt flat side around the idler pulley. Slide the idler pulley onto the idler pulley stud while holding the belt in place. Tighten the transmission idler pulley retaining nut with a socket wrench to secure the idler pulley to the idler pulley stud. Mowing Deck Drive Belt Installation Pull back on the right side mowing deck mandrel pulley spring-tensioned belt retainer. Guide the new mowing deck drive belt around the right side mandrel pulley and release the belt retainer. Pull the drive belt spring-tensioned retainer away from the mowing deck idler pulley, guiding the deck drive belt around the idler pulley. Fit the mowing deck drive belt around the left side mandrel pulley and under the rear mowing deck cross link rod between the right and left side mandrel pulley. Slide the mowing deck under the right side lawn tractor frame, reconnecting the deck to the frame in reverse order of removal. Engage and disengage the mower deck while driving the mower to test the belt for proper operation.
Sep 28, 2016 | Murray Garden
Removed mower deck with no problems. Cannot re-attach. Do you have a step by step instruction for this process?
1. Raise attatchment lift lever to its highest position
2. Slide the mower deck under the tractor with deflector shield (grass Chute) to right side of tractor
3. Lower lift lever to its lowest position
4.. Connect the front links to the mower deck and secure with the retainer springs.
5. Connect thye suspension arms to the rear deck brackets and secure with their retainer springs.
6. Connect the anti-sway bar to the chassis bracket and secure with the retainer spring.
7. Push the clutch cable housing guide into the bracket, and slide the collar onto the guide and
secure it with the large retainer spring.
8. Place the flat washer and clutch spring on the idler pulley bolt and secure them with the small
retainer spring.
9. Re-install the blade belt onto the engine pulley it goes on.
Apr 23, 2011 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
I have a riding lawn mower that i am trying to replace belt when i did i knocked off a spring and need to know where it goes
without being there, I am guess it is the tensioner pulley spring, it is in the middle of the deck and hooks to that pulley and then there is a metal brace with a hole in it, the spring is heavy duty if this is the spring, you will need to pull/pry on that pulley once the spring is connected, you may want a ratchet strap, but once the belt is on an you release the tensioner pulley it will tighten up the belt. Good Luck Tim
this thread might help if I confused you:
http://www.howtomendit.com/answers.php?id=142623
Apr 19, 2011 | Garden
I'm attempting to replace the primary belt on a John Deere x500 w/ 54'' deck. Is there a pully adjustment or do I just ''force'' the belt onto the pulleys?
There is an idler pulley that puts tension on the belt. You unhook the spring from the idler arm, put the new belt on (it will be loose, not tight) then hook the spring back onto the idler by pulling hard on the spring with a pair of visegrip or channellock pliers. Here's a parts diagram. Good luck! Please rate my solution if helpful, thanks.
Aug 02, 2010 | John Deere Garden
I have a Toro LX466 riding mower. The drive belt
How to replace the drive belt on a Toro LX466 Lawn Tractor
1. Jack up the front of the mower-place a couple of blocks under the front wheels (retaining wall blocks from your flower bed work great). Block the back wheels so the mower won't roll off the front blocks.
  1. Remove the battery and battery compartment from under the seat. You can now see the cooling fan blade under the seat. The belt runs from the pulley directly under the fan to the front of the tractor.
  2. Lower the mower deck to its lowest position. Remove the deck hanger rod from the slots in the front of the mower deck.
  3. Remove the metal rod guard below the engine pulley. It's held in place on one side with a bolt, and the other side with a cotter pin.
  4. Take a large pair of channel lock pliers (about 18 in long work great) and clamp them down directly on the engine pulley, but not so tightly you distort the pulley.
  5. Remove the bolt from the pulley. It's a right-handed bolt, so turn it counter-clockwise to remove.
  6. Slide the pulley down the shaft until you can work the belt off. If the belt is too tight, then remove the spring from the idler pulley under the tractor. It's hooked on a bolt near the side of the tractor. You can remove it by grabbing the end of the spring with a pair of needle-nose vise-grips and slipping the end off the bolt. Then remove the old belt from the tractor.
  7. Take a new belt (preferably Kevlar) and start at the back of the tractor (with the pulley under the cooling fan) and thread it through to the front of the tractor. The flat side of the belt rests against the idler pulley with the flat sides.
  8. Work the belt over the engine pulley and slide it back on the shaft. Tighten the bolt on the engine pulley hand tight. Then check the belt to make sure it hasn't slipped out of the groove on the cooling fan pulley.
  9. Clamp the engine pulley with the channel lock pliers and tighten the bolt.
  10. Make sure the belt is routed correctly on the idler pulleys. If you had to remove the spring on the idler pulley, replace it. You can do this by grabbing it with the needle-nose vise-grips and placing it on the bolt-make sure it's above the washer. Then remove the vise-grips and gently pry it over with a small screwdriver until it slips into place.
  11. Replace the metal guard below the engine pulley. Hook the mower deck back onto the deck hanger. Replace the battery compartment and battery. Unblock the mower.
Jun 15, 2010 | Toro LX466 22HP Lawn Tractor 13RT61RH244
I need to replace a mower deck belt on my exmark zero turn mower and there is a place where the belt is trapped by a metal plate bar that connects 2 pulleys. Do I have to remove a pulley to release the...
There will be one or two "idler pulleys" besides the spindles that turn the blades. Usually one idler pulley is mounted on a plate that swivels, pulled by a strong spring, to put tension on the belt. The other idler pulley is usually fixed in place. Use strong pliers (vise-grips or channellock) to pull the spring out of its notch at one end, releasing the tension. Then the belt can be threaded. Now you have to restore tension by by pulling on the spring and anchoring it on that swivel plate again.
Jun 06, 2010 | Garden
I don't know how to get the belt on the small pulley
If the design of this unit is the water pump is in the front directly below the motor, you have to install one of the pump plastic legs between the belt. when installing new belt. There are torex screws holding the pump onto the motor. This is assuming your belt burnt off or broke and you are replacing the belt. The small idler pulley can be worked on by running the belt on the big pulley when reinstalling the motor Try not to stretch the spring for the idler pulley,
hope this helps
May 27, 2010 | Amana DLW330RA Top Load Washer
I have a craftsman LT1000 19.5 hp mower that is losing power. It won't even go up a small hill anymore. I've replaced the belt but that didn't help. Any advice?
Some basic ideas
1) did you use an OEM (Sears or AYP) belt
2) is there spring tension on the belt
3) are idler pulleys free and with noise when turning
4) is the engine 'stack' pulley free of oil and is the mating groove worn
Nov 10, 2009 | Craftsman Garden
Owners manual
Maintaining Riding Mowers Regular maintenance can reduce repairs. pagetools_04a.gif spacer.gif spacer.gif
Components of a typical riding lawn mower. (click to enlarge)
It's fun to ride around the yard on the mower, watching scrubby grass (and weeds) turn into trimmed lawn. However, when the grass looks as bad after you mow as it did before, or the mower doesn't want to start, riding mowers aren't as much fun. That's when it's time to put on your Fix-It Club hat and have some more fun.
A riding lawn mower is a gas-powered machine for cutting grass. The engine turns a rotating blade that cuts the top off the grass blades to a specified height. The operator sits atop the mower on a tractor-type seat with speed and height controls nearby. Riding mowers also can be used to pull small utility carts for other yard jobs.
To remove the mower deck:
  1. Make sure that the parking brake is locked.
  2. Place scrap lumber under the front and rear of the deck.
  3. Use the deck lever to lower the deck.
  4. Remove attachments from the deck.
  5. Remove the blade drive belt from the front pulley.
  6. Remove the front and rear deck fasteners, following instructions in your owner's manual.
  7. Use the deck lever to raise the deck.
  8. Remove the scrap lumber.
  9. Remove the deck from under the mower.
To adjust the drive belt:
  1. Remove the belt from the large idler pulley.
  2. Remove the belt from the adjustable idler pulley.
  3. Carefully remove the spring-loaded large idler pulley.
  4. Loosen the adjustable idler pulley and move it slightly toward the rear of the mower to tighten it[md]or move it toward the front to loosen it—and retighten the pulley.
  5. Replace the belt.
  6. Check belt tension and readjust as needed.
Apr 12, 2009 | Garden
Garden Logo
438 people viewed this question
Top Encore Garden Experts
Roland W VanLue
Roland W VanLue
Mike Carew
Are you an Encore Garden Expert? Answer questions, earn points and help others
