Question about Boating
I have a 1989 evinrude outboard 225,that shut downonme on my way in. after my tow ini waieted a moth and turned the key again. itwould not start. after 5 minutes of random tries, it started and ran for 30 seconds then dies again. I checked all the inline fuses,as well as the gas line from the tank to the carbs and all is good. what shouldIlook for next.
    Renaissance:
    An user who is expert in 3 categories / brands.
  • 1,508 Answers
Check for water or contaminants in the fuel tank and carbys. If a fuse was gone it wouldnt let it start again.So you must have spark, which only leaves the fuel system, unless it is internal engine damage or wear
Posted on Apr 25, 2010
I have a 50 hp Johnson outboard or do I disconnect the shift linkage to get the lower unit off
have a look at the videos
How to remove the lower unit on a outboard engine - YouTube
? 3:24
https://www.youtube.com/watch?v=R6wVMc8GD0w
Mar 29, 2015 - Uploaded by Greg Drinkwater
How to remove the lower unit on a 1989 Johnson 88 SPL Help me remove lower unit. Johnson 90 hp ...
Johnson 50hp Outboard Lower Unit - YouTube
? 2:15
https://www.youtube.com/watch?v=DnU7vKcJkeE
Apr 9, 2016 - Uploaded by Stacy Wyoming
Removing Bearing Housing From a 50 HP Evinrude - Duration: 2:15. Brandon's Garage 274 views · 2:15 ...
how to remove lower unit on johnson outboard - YouTube
? 0:47
https://www.youtube.com/watch?v=_ygxZSxU6-I
May 24, 2016 - Uploaded by 2222buster2222
How to remove your lower unit on a 1984 Johnson Outboard 70HP.
60 HP Johnson Evinrude VRO Lower Unit Removal and Water Pump ...
? 24:26
https://www.youtube.com/watch?v=Hv8gXqsO2fg
Jun 3, 2015 - Uploaded by Ralph Pierre
60 HP Johnson Evinrude VRO Lower Unit Removal and Water Pump Service. ... Just bought a Bass Tracker ...
50 hp Johnson outboard remove lower unit Google Search
Jul 07, 2017 | Johnson Boating
2003 2 stroke evinrude 225 hp outboard will run at high speed about 5-7 min than starts shaking seems like not all cylinders are firing. if i shut off the motor and restart it will run another 5 min.
check the plugs if they wet its getting too much oil in the mix. if dry and black plugs then it could be not enough oil or fuel in mix.
Jun 21, 2017 | Cars & Trucks
What should the compression be on a 1988 evinrude 185hp outboard?
The compression on your Evinrude outboard should be at least 100 with no more than 10% difference between cylinders. Keep in mind gauges can give very different results. Also, remember the test should be run when the engine is warm!
Hope this helps!
Jun 13, 2016 | Johnson Evinrude Ignition Kit, Digital,...
Evinrude 40hp outboard
First, the over heating alarm is for YOU to shut the motor down...
Replace the water pump assembly..(have a different mechanic do it!!!!!!!!!!!!!!)... they are NOT all created equal!!
May 17, 2017 | Boating
I have no spark on 1989 7.5 evinrude outboard motor
Hi have you tried it with the stop switchl/button disconnected, if so you have only got the stator under the flywheel left to replace, regards Phil.
Jun 04, 2012 | Boating
I have a 86 17 foot ebbtide with a 110 evinrude outboard. i am getting a continuos beeping buzzing sound which comes from the hand throttle/ drive lever area. could someone please tell me what this means?...
Hello. Most likely your evinrude has a separate oil reservoir that is empty or approaching empty. Look for the reservoir, pour in a quart or more of outboard motor oil and that buzzing will stop. J. happy boating and good luck fishing!
Jul 09, 2010 | Boating
Need online repair manual for evinrude 50hp outboard
how can I adjust the shifting linkage on my 50hp evinrude. I have the cable adjusted all the way out but it will not go into reverse
May 10, 2009 | Boating
Boating Logo
104 people viewed this question
Top Boating Experts
Steve
Steve
ray gallant
Andrew Taylor
Andrew Taylor
Are you a Boating Expert? Answer questions, earn points and help others
