Question about Whirlpool LER4634J Electric Dryer
Whirlpool dryer timer works but no heat or tumbler movement? what's wrong?
  • Whirlpool Master
  • 43,501 Answers
A dryerwhirlpool dryer timer works but no heat or tumbler - 2_bing.gif may not start for many reasons...
This tip that I wrote will help you to figure out what is happening...
http://www.fixya.com/support/r4422207-dryer_repair_dryer_not_turning
http://www.fixya.com/support/r4460438-dryer_repair_dryer_will_not_start
heatman101
Posted on Apr 25, 2010
My Whirlpool LEB6300PWO will randomly not start, or will start but only run briefly then stop. I know these types of problems are not usually related to the timer, but we have found that by either lightly...
Hello, we are sorry to hear that you are having this problem with the Dryer. We would recommend having a certified technician out to take a look at the Dryer and give a proper diagnosis. If you would like further assistance you can reach out to us with your name, phone number, address, model/serial number and the date on which you purchased the Dryer to Whirlpool_Reviews@Whirlpool.com.
Apr 17, 2017 | Whirlpool LEB6300 Electric Dryer
My whirlpool dryer stopped heating
If you are having problems with your gas dryer not heating the most common problem is that the ignitor goes bad. Even though it glows sometimes it is still not working properly.
if you dryer is gas check out this gas no heat tip....
If you have an electric dryer, you can have many different things that can go wrong causing the dryer not to heat.
check out this electric no heat tip...
heatman101
'0'0'0'0'0'0'0'0'0'0'0'0'0'0'0'0'0'0
Jan 17, 2011 | Major Replacement For Whirlpool Dryer...
Whirlpool LGR4634JQ2 no heat, tumbler spins, timer works
The control sends power over to the heat assemblyd28ae89.jpg742f281.jpgec7e68b.jpg1a010b4.jpgIf the ignitor is good and the flame sensor is good. The thermal limit is good AND the dryer works a little and quits then replace the solenoids. They get hot and fail with age. More here
Jul 26, 2010 | Dryers
Dryer will not heat, plus timer will not move
heatman101
Apr 09, 2010 | Whirlpool LGV4634JQ Gas Dryer
Whirlpool Dryer not heating
The motor has to be running for voltage to exit the motor going to the heater. With the back off the dryer and the motor running you should read 220 volts at the heater if all safetys and thermostats are good.
There is a thermal cut out relay on the heat canister. It must read continuity also.
Remember you must remove at least one wire from each component being tested to get a true open or closed reading. If a wire is left connected you get a false reading.
The heating element could be broken and part of the heater wire touching the canister. This would cause a continuity reading and still no heat.
Finally, yes,the centrifugal switch in the motor could be bad and not sending power to the heater on the red wire.
Oct 18, 2009 | Whirlpool LER4634J Electric Dryer
Tumbler spins, heat won't go on, timer won't work
It is your operating thermostat. It controls the heat and runs the timer down.
Jul 07, 2009 | GE DVL223GB Gas Dryer
Whirlpool Dryer
NEED A NEW TIMER NOTHING YOU CAN DO ABOUT THAT
STEVE'S APPLIANCE
516-300-3249
Apr 06, 2009 | Whirlpool LER5636P Electric Dryer
Dryer not heating up
If the timer knob does not turn in a clockwise direction, then chances are the timer is bad.
Heating is a different issue, although, if the timer knob will not turn, then it may not be at a position that turns the heat on.
Replace the timer, then check the heating. If the heater then works, then the problem was in the timer. If it doesn't, then we need to look at problems within the heater circuit.
Reply back what you find out.
Jan 23, 2009 | Whirlpool LER5636P Electric Dryer
Dryer stopping in middle of cycle but timer continues to run.
oK " It's your timer, it has to be replaced
it's not going threw all it cycles, will start but will not finish
not a big job, unscrew plate on back at the top you will see
timer , take it out and replace it
( can not stress enough that you have to unplug the electrical cord from the wall socket before working on a dryer or any appliance )
Jan 24, 2008 | Whirlpool LER3624JQ Electric Dryer
Whirlpool LER4634J Electric Dryer Logo
73 people viewed this question
Top Whirlpool Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal DeAngelo
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
